MEDB00008FC-optimized
Certificate no.:
EC-TYPE EXAMINATION MEDB00008FC
CERTIFICATE (MODULE B)
that the Penetrations through “A” class divisions: electric cable transits
WGS ES
issued to
Regulation (EU) 2023/1667,
This Certificate is valid until 2029-04-22.
Issued at Høvik on 2024-04-23
Denmark CMC
Tessa Biever
Marcin Tobiasz Notified Body on behalf of
No.: 0575
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job ID: 344.1-012742-1
Certificate no.: MEDB00008FC
“WGS ES”
is designed for routing non-metallic fiber optic cables into a shielded enclosure with maintaining the enclosure’s
electromagnetic integrity.
The Roxtec WGS ES are available in both welded and bolted version and could be installed with single, multiple or
without any cables.
For more details, see drawings listed under Type Examination documentation below.
Approved for use as empty, single or multiple cable penetration system in A-60 steel bulkheads/decks. Other
applications are subject to case-by-case approval.
around the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead.
Size Seal Type Cable Max. cable Sleeve Sleeve Sleeve Sleeve insulation
type diameter length thickness position
25 - 70 WGS ES Fiber optic 12 87 - 130 N/A Either Fully insulated.
(S1590970 Rev. A)
Table 2: Approved cable penetration in A-60 steel deck.
25 - 70 WGS ES Fiber optic 12 87 - 130 N/A Top side Fully insulated.
(S1590970 Rev. B)
Test report No. PGB10174A dated 13 July 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-338/E dated 28 October 2022 from CTO, Gdansk, Poland.
Drawing No. S1590970 Rev. A dated 25 April 2023 from maker.
Drawing No. S1574166 Rev. A dated 17 December 2021 from maker.
Drawing No. S1574122 Rev. A dated 17 December 2021 from maker.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Appendix
“WGS ES”
without any cables.
Approved for penetration in steel bulkheads or decks limited to a pressure of 2.5 bar watertightness and 0.67 bar
For bolted versions the pressure are limited to 1 bar watertightness and 0.67 bar gastightness.
Test report No. N142G51R dated 11 November 2022 from DNV, Sweden.
Test report No. N142G5DF dated 14 November 2022 from DNV, Sweden.
Test report No. N142VRRD dated 29 February 2024 from DNV, Sweden.
Pressure tests with water and helium according to DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
