MEDB00008WS-optimized
Certificate no.:
EC-TYPE EXAMINATION MEDB00008WS
CERTIFICATE (MODULE B)
that the Penetrations through “A” class divisions: pipe, duct, trunk, etc penetrations
“Roxtec sealing system with multidiameter technology: TB-series (Steel divisions)”
issued to
Regulation (EU) 2023/1667,
IMO MSC.1/1488
This Certificate is valid until 2029-07-09.
Issued at Høvik on 2024-07-10
DNV local unit: Digitally Signed By: Bukarica,Dalibor
Denmark CMC Location: Høvik, Norway
Signing Date: 12.07.2024
Marcin Tobiasz Notified Body Mydlak-Röder, Christine
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job ID: 344.1-013306-1
Certificate no.: MEDB00008WS
Consisting of a steel sleeve welded into a steel division which is containing Roxtec rubber seals with two half circle
metallic front fitting plates. These are locked into a groove in the sleeve and are fixed with four axial compression bolts.
TB-sealing with multidiameter technology has peelable layers making the center adaptable to single pipe.
Approved for use as a single pipe penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads and decks.
Other applications are subject to case-by-case approval.
around the penetration.
Table 1: Approved pipe penetration in A-60 steel bulkheads
Pipe Sleeve
material position
[mm] [mm] [mm]
Fully insulated + 310 mm along pipe on
TB 65 Steel
(S1601624 ID1)
TB 65 – 105 Steel
(S1601624 ID2)
Table 2: Approved pipe penetration in A-60 steel decks
Pipe Sleeve
material position
[mm] [mm] [mm]
TB 65 – 105 Steel
(S1601624 ID3)
Test report No. RS-22/B-153/E dated 4 May 2022 from CTO, Gdansk, Poland.
Test report No. RS-23/B-225/E dated 30 August 2023 from CTO, Gdansk, Poland.
Test report No. PGB10218A dated 10 July 2023 from DBI, Hvidovre, Denmark.
Drawing No. S1601624 Rev.B dated 5 July 2024 from maker.
Drawing No. S1601625 Rev.B dated 5 July 2024 from maker.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Additional application/information for watertightness/gastightness and
vibration (Not part of the Marine Equipment Directive requirement)
Approved for penetration in steel bulkheads or decks limited to a pressure of 11 bar watertightness (tested pressure
16.5 bar) and 2 bar gastightness (tested pressure 3 bar).
Penetration systems are generally not to be used for penetrating boundaries of tanks. When a penetration system is
requested for penetrating tanks, an approval may be given on a case-by-case basis.
Each product is to be installed with its manual for installation and use.
Statement No N141Z9F4 dated 2020-04-29 from DNV Sweden
Statement No N141ZEM3 dated 2020-05-15 from DNV Sweden
Pressure tests with water and helium according to Class Programme DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
