MERB00000NV-Rev-0-optimized
MERB00000NV
Roxtec sealing system: Roxtec SPM seal series / Roxtec SPM Blind seal series (steel divisions)
MSC.1/1488
This Certificate is valid until 2025-10-01.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 4
Certificate No: MERB00000NV
“Roxtec sealing system: Roxtec SPM seal series / Roxtec SPM Blind seal series (steel divisions)”,
Consisting of Roxtec SPM rubber seal in size 39 to 279 attached through expansion to steel sections and Roxtec SPM
Blind rubber seal in sizes 39/0 to 92/0 attached through expansion to steel section.
Approved for use as a single pipe penetration system in A-class steel divisions according to below tables. Other
applications are subject to case-by case approval.
For A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-60
insulation for a minimum distance of 200 mm around the penetration.
Pipe Seal Sleeve
material position insulation
SPM 39 – 279 Steel
SPM 39 – 279 Copper
SPM Blind 39/0 – 92/0 NA
Pipe Seal Seal
material position Insulation
SPM 39 – 279 Steel
SPM 39 – 279 Copper
Table 3: Approved pipe penetration in A-0 steel bulkhead
Pipe Seal Sleeve
SPM 39 – 279 Steel
SPM 39 – 279 Copper
Table 4: Approved pipe penetration in A-0 steel deck
Pipe Seal Sleeve
SPM 39 – 279 Steel
SPM 39 – 279 Copper
All seals shall be installed in accordance with Roxtec’s SPM seal Installation Instructions, including aperture dimensions
and tolerances, tightening torque, etc.
Penetrations through structural divisions should not impair the structural strength of the division.
Special consideration should be given to bulkheads and decks with high stress locations
(IMO MSC.1/Circ.1488).
of Conformity.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 4
Test Report No. 5P03451 dated 3 November 2015 from SP, Borås, Sweden.
Test Report No. 5P03457 dated 12 November 2015 from SP, Borås, Sweden.
Test Report No. 5P08343 dated 21 December 2015 from SP, Borås, Sweden.
Test Report No. 5P08346 dated 21 December 2015 from SP, Borås, Sweden.
Test Report No. 5P08395 dated 17 March 2016 from SP, Borås, Sweden.
Test Report No. 6P05989 dated 24 October 2016 from SP, Borås, Sweden.
Test Report No. 6P05990 dated 16 November 2016 from SP, Borås, Sweden.
Test Report No. PGA1087A dated 13 December 2016 from DBI, Hvidovre, Denmark.
Test Report No. RS-17/B-177/E dated 6 May 2017 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-022/E dated 29 January 2018 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-023/E dated 29 January 2018 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-181/E dated 7 May 2018 from CTO, Gdansk, Poland.
Test Report No. PGA11302A dated 16 January 2019 from DBI, Hvidovre, Denmark.
Drawing No. S1518359 Rev. A dated 22 December 2016 from maker.
Drawing No. S1518384 Rev. A dated 22 December 2016 from maker.
Drawing No. S1518385 Rev. B dated 28 September 2020 from maker.
Drawing No. S1518386 Rev. A dated 22 December 2016 from maker.
Drawing No. S1518398 Rev. B dated 28 September 2020 from maker.
Drawing No. S1518399 Rev. A dated 22 December 2016 from maker.
Drawing No. S1518400 Rev. A dated 22 December 2016 from maker.
Drawing No. S1553706 Rev. A dated 28 September 2020 from maker.
Drawing No. S1553712 Rev. A dated 28 September 2020 from maker.
Drawing No. S1553744 Rev. A dated 28 September 2020 from maker.
and the Mark of Conformity (see page 1).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 4
SPM 39 – 279:
Approved for penetration in steel bulkheads or decks limited to a pressure of 1.00 bar watertightness and 0.67 bar
SPM Blind 39/0 – 92/0:
Test Report No. N1417RRN dated 29 January 2016 from DNV GL Malmö.
Test Report No. N1419WS4 dated 22 June 2016 from DNV GL Malmö.
Test Report No. N14805C dated 22 November 2017 from DNV GL Malmö.
Tested according to Class Programme DNV-CP-0165 Chapter 4, February 2016.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 4 of 4
