MERB00000NX-Rev-0-optimized
MERB00000NX
Roxtec sealing system with multidiameter technology: RS PPS and RS PPS/S (AL)
MSC.1/1488
This Certificate is valid until 2024-08-04.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 4
Certificate No: MERB00000NX
“Roxtec sealing system with multidiameter technology: RS PPS and RS PPS/S (AL)”
RS PPS 31-450:
consisting of an aluminium sleeve, bolted or welded to an aluminium section. The sleeve is fitted at both ends with
Roxtec RS seals (standard or EMC versions) including intumescent material in between.
RS PPS/S 31-150:
consisting of an aluminium sleeve, bolted or welded (including SLX-type sleeve) to an aluminium section. The sleeve is
fitted in with Roxtec RS PPS/S seal (standard or EMC versions) with integrated intumescent material.
Approved for use as single plastic pipe penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkhead and
deck for approved thermoplastic pipes as follows:
Table 1: Approved pipe penetration in aluminium bulkhead
material position insulation
Thermo-
RS PPS 31 - 200 16 - 160
plastic*
Thermo-
RS PPS 225 - 450 160 - 355 400 4-7 Symmetric S1541191 Rev. A
plastic*
RS PPS 31 - 150 PE/ALU/PE 16 - 110 156 4-7 Symmetric
Thermo-
RS PPS/S 31 - 150 16 - 110 35 - 65 4-7 See drawing S1017153
plastic*
* PP, PVC, PB, ABS, PE, PVDF
Table 2: Approved pipe penetration in aluminium deck
Pipe Sleeve Seal
Thermo- Top and
plastic* Symmetric
Thermo- Top and
plastic* Symmetric
Thermo-
plastic*
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge of the aluminium
frame. See insulation drawing specified in the Type Approval Documentation. For fire class A-0, A-15 and A-30, the
sleeve and pipes are to be insulated as for class A-60.
The pipe penetrations are not approved for use in watertight bulkheads on passenger ships and special purpose ships
(SPS).
The penetration system shall not be used for penetrating boundaries of tanks.
of Conformity.
Each product shall be supplied with its manual for installation and maintenance.
Test Report No. 103070.33A dated 15 November 2004 from SINTEF, Trondheim, Norway.
Test Report No. P403634 dated 30 December 2004 from SP, Borås, Sweden.
Test Report No. PG11898 dated 17 April 2009 from DBI, Hvidovre, Denmark.
Test Report No. PG11955 dated 17 April 2009 from DBI, Hvidovre, Denmark.
Test Report No. PGA10801A dated 29 August 2016 from DBI, Hvidovre, Denmark.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 4
Test Report No. PGA11370A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test Report No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test Report No. RS-19/B-020/E dated 27 May 2019 from CTO, Gdansk, Poland.
Test Report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Assessment No. 103201.89 dated 4 August 2004 from SINTEF, Trondheim, Norway.
Drawing No. S1017153 dated 30 April 2009 from maker.
Drawing No. S1541191 Rev. A dated 26 November 2019 from maker.
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8 or IMO 2010 FTP Code Part
3.
Mark of Conformity (Page 1).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 4
RS PPS 31-450:
RS PPS/S 31-150:
RS PPS 31-450:
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.67 bar
RS PPS/S 31-150:
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.00 bar
For bolted versions with gasket and self-tapping screws the pressure is limited to 3.33 bar watertightness and 1.67 bar
(SPS).
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Test report No. MLM 070656 dated 18 April 2007 from DNV Malmö.
Test report No. N142299W dated 9 November 2020 from DNV GL Malmö.
Pressure tests with water and Helium according to DNV Type Approval Programme 8.471.19-1 and Class Programme
DNV-CP-0165 Chapter 4, October 2017.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 4 of 4
