MERB0000128-Rev-0-optimized
MERB0000128
Roxtec sealing system with multidiameter technology: RS-series (steel divisions)
MSC.1/1488
This Certificate is valid until 2025-04-15.
Gothenburg FIS
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 4
Certificate No: MERB0000128
“Roxtec sealing system with multidiameter technology: RS-series (steel divisions)”
consisting of a steel sleeve, bolted, welded or attached through expansion (RS X) to a steel section. Sleeve is filled with
a Roxtec RS or RS OMD seal (standard or EMC) in sizes 23-644 and Roxtec RS OC in sizes 75-400.
Approved for use as single and bundle pipe penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads and
decks as follows:
a) Steel and titanium pipes
with diameter 6-558 mm for bulkhead, 6-558 mm for deck
b) Copper pipes
with diameter 6-108 mm for bulkhead, 6-225 mm for deck
c) Fibre glass composite pipes*
with diameter 32-89 mm for bulkhead, diameter 32-275 mm for deck
d) Bundle pipes
− for steel pipes: OD 16-50 mm
− for copper pipes: OD 18 mm
e) Fiber glass composite FR pipes*
with diameter 75-375 mm for bulkhead, diameter 75-375 mm for deck
f) CuNi (90:10)
pipes with OD: 10-270 mm for deck & bulkhead
*The pipes under ‘c’ and ‘e’ tested in accordance with IMO Res. 753(18).
Other applications are subject to case-by-case approval.
Deck and bulkhead to be insulated with approved insulation according to classification covering the edge of the steel
frame. See insulation drawings specified in the Type Examination Documentation. A-0 RS X penetrations are to be
insulated as for class A-60.
Cold service piping insulated with Armaflex rubber insulation layer may be used with approved penetrations but is to be
locally interrupted through the penetration system.
Please note Installation instruction for Roxtec RS X attached through expansion: Aperture irregularities are acceptable
within min and max diameters. (Max Ø = Min Ø + 2mm)
Penetrations through structural divisions should not impair the structural strength of the division.
Special consideration should be given to bulkheads and decks with high stress locations
(IMO MSC.1/Circ.1488).
Mark of Conformity.
Test report no. P701755 dated 12 June 2007 from SP, Borås, Sweden. (A-60 deck)
Test report no. 09-345E dated 11 December 2009 from RIME, Tokyo, Japan. (A-60 Bulkhead)
Test report no. 09-346E dated 11 December 2009 from RIME, Tokyo, Japan. (A-60 deck)
Test report no. PX05454 Rev. 1 dated 8 September 2011 (original 15.12.2010) from SP, Borås, Sweden. (A-60
Bulkhead)
Test report no. PGA10141 dated 10 July 2012 from DBI, Hvidovre, Denmark. (A-60 deck)
Test report no. 4P06068 dated 17 January 2015 from SP, Borås, Sweden. (A-60 bulkhead)
Test report no. 4P07023 dated 5 February 2015 from SP, Borås, Sweden. (A-60 deck)
Test report no. PGA10649 dated 18 May 2015 from DBI, Hvidovre, Denmark. (A-60 bulkhead)
Test report no. PGA10650 dated 18 May 2015 from DBI, Hvidovre, Denmark. (A-60 bulkhead)
Test report no. PGA10800A dated 26 May 2015 from DBI, Hvidovre, Denmark. (A-60 steel deck)
Test report no. 4P08662 dated 8 July 2015 from SP, Borås, Sweden. (A-60 steel bulkhead)
Test report no. 6P04351 dated 22 June 2016 from SP, Borås, Sweden. (A-60 steel bulkhead)
Test report no. 6P02249 dated 17 August 2016 from SP, Borås, Sweden. (A-60 steel deck)
Test report no. PGA10871A dated 9 December 2016 from DBI, Hvidovre, Denmark. (A-60 steel deck)
Test report no. RS-18/B-022/E dated 29 January 2018 from CTO, Gdansk, Poland. (A-60 bulkhead)
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 4
Test report no. RS-18/B-023/E dated 29 January 2018 from CTO, Gdansk, Poland. (A-60 deck)
Test report no. RS-18/B-181/E dated 7 May 2018 from CTO, Gdansk, Poland. (A-60 bulkhead)
Test report no. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland. (A-60 deck)
Test report no. RS-18/B-485/E dated 10 December 2018 from CTO, Gdansk, Poland. (A-60 bulkhead)
Assessment no. P701755 dated 12 July 2006 from SP, Borås, Sweden.
Assessment no. P602999 dated 23 January 2007 from SP, Borås, Sweden.
Assessment no. P603000 dated 23 January 2007 from SP, Borås, Sweden.
Assessment no. 9P02428 dated 13 September 2019 from SP, Borås, Sweden.
Drawing no. S1006159 Rev. A (A-15, A-30 and A-60 copper pipe RS X)
Drawing no. S1006160 Rev. A (A-15, A-30 and A-60 copper pipe RS X)
Drawing no. S1011906 Rev. A (FGC pipes)
Drawing no. S1011907 Rev. 0 (Bundle pipes)
Drawing no. S1017433 Rev. B (with Armaflex)
Drawing no. S1040668 Rev. B (RS OC)
Drawing no. S1503926 Rev. A (A-15, A-30 and A-60 GRE FR deck/bulkhead)
Drawing no. S1510043 Rev. C (RS/RS OMD with CuNi 90:10 pipe in class A steel deck)
Drawing no. S1511583 Rev. A (RS/RS OMD with CuNi 90:10 pipe in class A steel bulkhead)
Drawing no. S1511683 Rev. C (RS/RS OMD with copper pipe in A-60 deck/bulkhead)
Drawing no. S1530506 Rev. A (RS/RS OMD with CuNi 90:10 pipe in class A-0 steel deck)
Drawing no. S1530507 Rev. A (RS/RS OMD with CuNi 90:10 pipe in class A-0 steel bulkhead)
Drawing no. S1551073 Rev. A (A-0/A-60 deck/bulkhead)
Drawing no. S1551097 Rev. A (A-0/A-60 deck/bulkhead)
Drawing no. S1551208 Rev. A (RS/RS OMD with steel or titanium pipe in class A-60 steel divisions)
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and in compliance with IMO 2010 FTP Code Ch. 8 and
IMO 2010 FTP Code Part 3.
and the Mark of Conformity (Page 1)
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 4
Sleeve is filled with a Roxtec RS or RS OMD seal (standard or EMC) in sizes 23-644.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4 bar watertightness and 2.67 bar
gastightness as follows:
a) For steel and copper pipes in sizes 10-558 mm.
b) For bundle of steel and copper pipes 16-50 mm.
c) For fibre glass composite pipes with diameter 32-410 mm.
Pipe penetrations with plastic or composite pipes are not approved for use in watertight bulkheads on passenger ships
and special purpose ships (SPS).
Test report No. MLM 010247 dated 28 September 2002 from DNV Malmö.
Test report No. MLM 030473-1 dated 27 January 2003 from DNV Malmö. (RS X)
Test report No. MLM 060561 dated 1 December 2006 from DNV Malmö. (Bundle)
Pressure tests with water and Helium according to DNV-CP-0165.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 4 of 4
