MERB0000130
Roxtec sealing system with multidiameter technology: S-series (Al)
Regulation MSN 1874 Amendment 7,
This Certificate is valid until 2027-03-10.
Issued at London on 2023-03-30
| Approval Engineer: | Approved Body No.: 0097 |
| Karolina Kusmider | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | AA002B54 | ||
| Certificate No: | MERB0000130 | ||
| Revision No: | 0 |
“Roxtec sealing system with multidiameter technology: S-series (Al)”
consisting of Roxtec S-series aluminium frames (S, SO, SF, SFO, SR, SK, SRC r20, SRC r40 and SBTB) in sizes 2 - 8
and combinations thereof, welded to an aluminium section. The S frame is filled with Roxtec (standard or EMC) halogen
free RM modules. Assembled with Roxtec wedge kit (standard or EMC).
Approved for use as a single or multiple cable penetration system in class A-60 aluminium decks and bulkheads. Other
applications are subject to case-by-case approval.
around the penetration.
Table 1: Approved cable penetration in A-60 aluminium bulkhead
| Sleeve | Sleeve | |
| Type | Size | diameter |
| position | insulation | |
| [mm] | [mm] | [mm] |
| S | 2-8 | 88 |
Table 2: Approved cable penetration in A-60 aluminium deck
| Sleeve | Sleeve | |
| S | 2-8 | 83 |
The insulation material used has to be approved according to the UK Marine Equipment Regulation and bear the UK
Mark of Conformity.
Test report No. P603001 dated 23 January 2007 from SP, Borås, Sweden.
Test report No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-180/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Drawing No. S1571925 Rev. B dated 21 February 2022 from manufacturer.
Tested in accordance with IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8, and in accordance with
IMO 2010 FTP Code part 3.
The product or packing is to be marked with name and address of manufacturer, type designation, UK Mark of
Conformity (see first page).
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
| Revision No: | 0 |
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.67 bar
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
