MERB00001Y7
Roxtec sealing system with multidiameter technology: S-series (steel)
This Certificate is valid until 2027-06-13.
| DNV local unit: | Digitally Signed By: Mydlak-Röder, Christine |
| Denmark CMC |
| Approval Engineer: | Approved Body No.: 0097 |
| Roland Priebe | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 1 of 5 |
| Job Id: AA001WJW | |||
| Certificate No: MERB00001Y7 | |||
| Revision No: | 0 | ||
“Roxtec sealing system with multidiameter technology: S-series (steel)”
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SFOHK, SR, SK, SRC r20, SRC r40, SRC r60 and SBTB)
in sizes 1-8, and combinations thereof, welded or bolted to a steel section.
The S frame is filled with Roxtec (standard or Ex, FOC, EMC, PE, ES, BG, BGB) halogen free RM modules. Standard
RM, FOC, BG and BGB modules can be mixed in the same frame. Assembled with Roxtec Wedge kit, Roxtec ES
Wedge kit or Roxtec EX Wedge kit.
For more details, see drawings listed under Type Examination documentation below.
Approved for use as empty, single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 steel
bulkheads and decks for approved ship cables, inc. continuously welded aluminium clad cables (e.g., CLX type)
according to the tables below. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead.
| Frame | Cable | Sleeve |
| Size | diameter | length |
| type | type | position |
| (OD) [mm] | [mm] | [mm] |
| 1–8 | Marine | 86 |
| 1 – 8+8x3 | Marine | 86 |
| 1 – 8+8x10 | Marine | 86 |
| S-series | ||
| 1 – 8+8x3 | Fiber optic* | 18 |
| 1 – 8+8x10 | Fiber optic* | 18 |
| 1 – 8+8x3 | CLX | 98 |
| 2–8 | Marine | 82 |
| SFOHK | ||
| 2–8 | Fiber optic* | 18 |
| 2–8 | Marine | 82 |
| SK | ||
| 2–8 | Marine | 82 |
| SBTB | ||
- Fiber optic cables can only be installed in FOC-modules.
Table 2: Approved cable penetration in A-0 steel bulkhead.
| S-series | 1 – 8+8x3 | Fiber optic* |
| 2–8 | Marine | 82 |
| SFOHK | ||
| 2–8 | Marine | 82 |
| SK | ||
| 2–8 | Marine | 82 |
| SBTB | ||
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 2 of 5 |
Table 3: Approved cable penetration in A-60 steel deck.
| 1 – 8+8x2 | Marine | 86 |
| Top side, | ||
| 1 – 8+8x5 | Marine | 90 |
| S-series | Symmetric | |
| 1 – 8+8x5 | Fiber optic* | 18 |
| 1 – 8+8x2 | CLX | 98 |
| 2–8 | Marine | 82 |
| SFOHK | 2–8 | Fiber optic* |
| 2–8 | CLX | 60 |
| 2–8 | Marine | 82 |
| SK | 2–8 | Fiber optic* |
| 2–8 | CLX | 60 |
| 2–8 | Marine | 82 |
| SBTB | 2–8 | Fiber optic* |
| 2–8 | CLX | 60 |
Table 4: Approved cable penetration in A-0 steel deck.
| Top side, | ||
| 1–8 | Marine | 88 |
| Symmetric | ||
| 1 – 8+8x3 | Marine | 88 |
| Top side, | ||
| Symmetric | ||
| S-series | Top side, | |
| 1–8 | Fiber optic* | 18 |
| Symmetric | ||
| 2–8 | Marine | 82 |
| 2–8 | CLX | 60 |
| 2–8 | Marine | 82 |
| 2–8 | CLX | 60 |
| 2–8 | Marine | 82 |
| 2–8 | CLX | 60 |
Mark of Conformity.
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 3 of 5 |
Test report No. 09-344(E) dated 11 December 2009 from Research Institute of Marine Engineering, Tokyo, Japan.
Test report No. PX05454 dated 15 December 2010 from SP, Borås, Sweden.
Test report No. PGA10024 dated 21 December 2011 from DBI, Hvidovre, Denmark.
Test report No. PGA10025 dated 22 December 2011 from DBI, Hvidovre, Denmark.
Test report No. PGA10452 dated 28 May 2014 from DBI, Hvidovre, Denmark.
Test report No. PGA10453 dated 28 May 2014 from DBI, Hvidovre, Denmark.
Test report No. 4P07023 dated 4 February 2015 from SP, Borås, Sweden.
Test report No. 4P08662 dated 8 June 2015 from SP, Borås, Sweden.
Test report No. PGA10652 dated 3 July 2015 from DBI, Hvidovre, Denmark.
Test report No. PGA 10871A Rev.1 dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P02516 dated 29 August 2016 from SP, Borås, Sweden.
Test report No. PGA10871A Rev.2 dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P07563 dated 20 December 2016 from SP, Borås, Sweden.
Test report No. 6P10022 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. RS-17/B-176/E dated 25 May 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-177/E dated 26 May 2017 from CTO, Gdansk, Poland.
Test report No. 8P04039 dated 6 August 2018 from RISE, Borås, Sweden.
Test report No. 8P04040 dated 13 August 2018 from RISE, Borås, Sweden.
Test report No. RS-18/B-293/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test report No. PGA11301A dated 22 November 2018 from DBI, Hvidovre, Denmark.
Test report No. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. PGA11302A dated 19 January 2019 from DBI, Hvidovre, Denmark.
Test report No. RS-19/B-355/E dated 16 October 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-356/E dated 18 October 2019 from CTO, Gdansk, Poland.
Test report No. RS-20/B-409/E dated 21 December 2020 from CTO, Gdansk, Poland.
Test report No. PGB10119A dated 15 November 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10172A dated 17 June 2022 from DBI, Hvidovre, Denmark.
Drawing No. S1578672 Rev. A dated 12 April 2022 from maker.
Drawing No. S1578373 Rev. A dated 12 April 2022 from maker.
Drawing No. S1578674 Rev. A dated 12 April 2022 from maker.
Drawing No. S1578589 Rev. A dated 12 April 2022 from maker.
Drawing No. S1578574 Rev. A dated 19 April 2022 from maker.
Drawing No. S1578669 Rev. A dated 19 April 2022 from maker.
Drawing No. S1578712 Rev. A dated 19 April 2022 from maker.
Drawing No. S1578800 Rev. A dated 19 April 2022 from maker.
Drawing No. S1474720 Rev. B dated 19 April 2022 from maker.
Drawing No. S1574575 Rev. B dated 19 April 2022 from maker.
Drawing No. S1574576 Rev. B dated 16 May 2022 from maker.
Drawing No. S1574713 Rev. B dated 16 May 2022 from maker.
Drawing No. S1575199 Rev. B dated 16 May 2022 from maker.
Drawing No. S1575200 Rev. B dated 16 May 2022 from maker.
Drawing No. S1581027 Rev. B dated 27 June 2022 from maker.
Drawing No. S1581922 Rev. A dated 2 August 2022 from maker.
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8 and according to IMO 2010
FTP Code part 3.
and the Mark of Conformity (see first page).
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 4 of 5 |
Appendix
in sizes 1-8, and combinations thereof, bolted or welded to a steel section.
The S frame is filled with Roxtec (standard or FOC, EMC, PE, ES, BG, BGB) halogen free RM modules. Assembled with
Roxtec Wedge kit or Roxtec EMC Wedge kit.
For penetrations incorporating FOC-modules, the pressure is limited to 2.00 bar watertightness and 0.67 bar
For penetrations incorporation SFOHK frames, the pressure is limited to 2.67 bar watertightness.
Test report No. MLM 020106 dated 19 December 2001 from DNV, Malmö, Sweden.
Test report No. MLM 020133 dated 26 February 2002 from DNV, Malmö, Sweden.
Test report No. MLM 020408 dated 3 June 2002 from DNV, Malmö, Sweden.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV, Stockholm, Sweden.
Test report No. N141CR4U Rev.1 dated 23 March 2017 from DNV, Malmö, Sweden.
Test report No. N141805F dated 27 February 2018 from DNV, Gothenburg, Sweden.
Pressure tests with water and helium according to DNV-CP-0165 Sec.2 Ch.4.
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 5 of 5 |
