MERB0000453
Roxtec sealing system with multidiameter technology: SE PPS S-series (aluminium)
item No. UK/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276 and IMO 2010 FTP Code
This Certificate is valid until 2023-06-13.
Gothenburg
| Approval Engineer: | Approved Body No.: 0097 |
| Roland Priebe | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 1 of 3 |
| Job Id: AA001WJW | |||
| Certificate No: MERB0000453 | |||
| Revision No: | 0 | ||
“Roxtec sealing system with multidiameter technology: SE PPS S-series (aluminium)”
consisting of Roxtec S-series aluminium frames (S, SO, SF, SFO, SR, SK, SRC r20 and SRC r40) in sizes 2-6, and
combinations thereof up to x4, to be used together with SE PPS extension frames, bolted or welded to the aluminium
sections. The extension frame is equipped with intumescent material strips. The S frame is filled with Roxtec (standard
or EMC) halogen free RM modules. Assembled with Roxtec Wedge kit or Roxtec EMC Wedge kit.
Approved for use as a pipe penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkheads and decks for
approved pipes and cables as follows:
| Type of Pipe | Dia. pipe [mm] | S-series size | Deck/Bulkhead |
| Thermoplastic (PP, PVC, PB, ABS, HDPE, PVDF) | 16-99 | 2-6 | Deck/Bulkhead |
| PE/Alu flexi pipe | 16-99 | 2-6 | Deck/Bulkhead |
| Copper and steel pipes | 10-54 | 2-6 | Deck |
| Approved ships cables | Up to 60 | 1-6 | Deck/Bulkhead |
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge of the steel
frame. See insulation drawing specified in the Type Examination documentation.
Mark of Conformity.
Test Reports Nos.:
| - | 103070.27A (A-60 steel bulkhead) dated 4 July 2003 from SINTEF, Norway |
| - | 103070.27B (A-60 steel deck) dated 4 July 2003 from SINTEF, Norway |
| - | P403634 (A-60 deck Aluminium) dated 30 December 2004 from SP Sweden |
| - | P501943 (A-60 bulkhead Aluminium) dated 18 May 2005 from SP Sweden. |
Drawing No. S1015522 dated 7 November 2008 from Roxtec International AB.
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8.
and the Mark of Conformity (see page 1).
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 2 of 3 |
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SR, SK, SRC r20 and SRC r40) in sizes 2-6, and
Approved for plastic pipe and cable penetration in aluminium bulkheads or decks and copper and steel pipes in steel
deck limited to a pressure of 4 bar watertightness and 2.67 bar gastightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.3 bar watertightness and 1.7 bar
When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships (SPS), the
penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2009 issue). Penetrations
passing through watertight bulkheads are subject for separate examination and approval (water tightness after a
standard fire test). This product has not been tested according to Reg. 13.2.3.
Test reports No. MLM 020401 dated 25 March 2002 (screws), MLM020408 dated 3 June 2002 (steel pipes),
MLM0504010 dated 20 May 2005 (copper pipes) from DNV Malmø and No. SKM-04-4088 dated 16 June 2004 from
DNV Stockholm.
Inspection report No. MLM 020408 dated 3 June 2002 from DNV Malmö.
Pressure test with water and Helium according to DNV Type Approval Programme 8.471.19-1.
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 3 of 3 |
