MERB00005J9
Roxtec sealing system with Multidiameter , S-series (AL)
item No. UK/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276 and IMO 2010 FTP Code
This Certificate is valid until 2024-07-29.
| Approval Engineer: | Approved Body No.: 0097 |
| Roland Priebe | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 1 of 3 |
| Job Id: AA001WJW | |||
| Certificate No: MERB00005J9 | |||
| Revision No: | 0 | ||
“Roxtec sealing system with Multidiameter
, S-series (Al)”
consisting of Roxtec S-series aluminium frames (S, SO, SF, SFO, SR, SK, SRC r20, SRC r40, SBTB) in sizes 1-8 and
combinations thereof, welded or bolted to an aluminium section. The S frame is filled with Roxtec (standard or EMC)
halogen free RM modules. Assembled with Roxtec wedge kit or Roxtec EMC wedge kit.
Multidiameter
is a Roxtec technology based on sealing modules with removable layers.
Approved for use as a single or bundle pipe penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkhead
and deck as follows:
| Steel pipes: | OD up to 54 mm, deck and bulkhead |
| Copper pipes: | OD up to 57 mm. deck and bulkhead |
| Bundle pipes (Cu and steel): | OD up to 32 mm for bulkhead and OD up to 50 mm for deck. |
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge of the aluminium
frame. See insulation drawing specified in the Type Approval Documentation. For fire class A-0, A-15 and A-30, the
sleeve and pipes are to be insulated as for class A-60 and in addition the division is to be insulated at least 200 mm
around the penetration.
Mark of Conformity.
Test report No. PG 11898, Serial No. 11923 dated 17 April 2009 from DIFT,Copenhagen Denmark
Test report No. PG 11955, Serial No. 11979 dated 17 April 2009 from DIFT,Copenhagen Denmark.
Test report No. P603001 dated 23 january 2007 from SP, Sweden.
Test report No. P603000 dated 27 January 2007 from SP, Sweden.
Drawing No. S1017332 Rev. 0 dated 15 May 2009 from Roxtec International AB (Insulation drawing).
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8.
and the Mark of Conformity (see page 1).
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 2 of 3 |
to EC Type Examination Certificate, MEDB00005J9
, S-series (Al)”
Multidiameter
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4 bar watertightness and 2.67 bar
gastightness (Ref. page 2 of the certificate).
When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships (SPS), the
penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2009 issue). Penetrations
passing through watertight bulkheads are subject for separate examination and approval by actual flag administration
Test reports No. MLM 020133 dated 26 February 2002, No. MLM 020400 and No. MLM 020401 dated 25 March 2005
and MLM050410 dated 20 May 2005 from DNV Malmö.
Pressure tests with water and Helium according to DNV Type Approval Program 8.471.19-1
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 3 of 3 |
