MERB000065Z-Rev-0-optimized
MERB000065Z
Roxtec sealing system with multidiameter technology: GH-, RS- and R-series (sandwich panel)
This Certificate is valid until 2024-12-02.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 2
Certificate No: MERB000065Z
“Roxtec sealing system with multidiameter technology: GH-, RS- and R-series (sandwich panel)”
Cable transits consisting of the following:
Frame type Sealing type Size
GH Roxtec modules 2x1 to 8+8x3
SLFRS RS 31 to 125
SLFR R 50 to 200
All cable transits are fully insulated with A-60 mineral wool.
The frame flanges are sealed with fire rated sealant and bolted to the sandwich panel bulkhead.
For further details see approved drawings listed below.
The penetrations are approved for use as a cable penetration system for approved ship cables in class A-60/A-30
bulkheads made of sandwich panel type C.I.S-100 (A-60) manufactured by Norac AS with a thickness of 100 mm and a
density of 30.62 kg/m3, or equivalent sandwich panels. Other applications are subject to case-by-case approval.
Frame installation Penetration Max cable diameter
SLFRS RS 31 to 125
SLFR R 50
SLFR R 70 to 200
SLFR R 70 to 200
of Conformity.
Test report No. 3P07871 rev. 1 dated 2014-10-11 from SP Technical Research Institute of Sweden.
Drawing No. S1040644, rev. B: Insulation of GH frames dated 2014-05-05 from Roxtec
Drawing No. S1040645, rev. B: Insulation of RS / RS-OMD seals dated 2014-05-05 from Roxtec
Drawing No. S1040646, rev. B: Insulation of R frames dated 2014-05-05 from Roxtec
The product or packing is to be marked with name and address of manufacturer, type designation, fire technical rating
and the Mark of Conformity (see first page).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 2
