MERB00006BG-Rev-0-optimized
MERB00006BG
Roxtec sealing system with multidiameter technology: R-series (steel)
MSC.1/1488
This Certificate is valid until 2023-12-10.
Gothenburg FIS
Roland Priebe (Christine Mydlak-Röder)
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 1 of 3
Certificate No: MERB00006BG
“Roxtec sealing system with multidiameter technology: R-series (steel)”
consisting of a steel sleeve, bolted, welded or attached through expansion (RX) to a steel section. Sleeve is fitted with a
Roxtec R frame (standard, Ex or EMC) in sizes 50-200. The R frame is filled with Roxtec (standard, Ex or EMC) halogen
free RM modules.
Approved for use as a single or multiple pipe penetration system in A-class steel divisions according to below tables.
Other applications are subject to case-by case approval.
For A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-60
insulation for a minimum distance of 200 mm around the penetration.
material position insulation
R 50 – 200 Steel
R 70 – 200 Copper
R 70 – 200 CuNi
RX 70 – 200 Steel
R 50 – 200 Steel
R 50 – 200 Copper
R 50 – 200 CuNi
RX 70 – 200 Steel
Table 3: Approved pipe penetration in A-0 steel bulkhead
R 50 – 200 Steel
R 50 – 200 Copper
R 50 – 200 CuNi
RX 70 – 200 Steel
Table 4: Approved pipe penetration in A-0 steel deck
material position Insulation
R 50 – 200 Steel
R 50 – 200 Copper
R 50 – 200 CuNi
RX 70 – 200 Steel
of Conformity.
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 2 of 3
Please note Installation instruction for Roxtec RX attached through expansion: Aperture irregularities are acceptable
within min and max diameters. (Max Ø = Min Ø + 2mm).
Test report No. 10408 dated 16 February 2006 from Roxtec, Karlskrona, Sweden.
Test report No. P602999 dated 23 January 2007 from SP, Borås, Sweden.
Test report No. P603000 dated 23 January 2007 from SP, Borås, Sweden.
Test report No. PGA11955 dated 17 April 2009 from DBI, Hvidovre, Denmark.
Test report No. 4P8662 dated 8 June 2015 from SP, Borås, Sweden.
Test report No. PGA10724A dated 5 February 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10799A dated 25 May 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10800A dated 26 May 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P07563 dated 20 December 2016 from SP, Borås, Sweden.
Test report No. 6P10022 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. 8P04039 dated 6 August 2018 from SP, Borås, Sweden.
Test report No. 8P04040 dated 13 August 2018 from SP, Borås, Sweden.
Test report No. RS-18/B-292/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test report No. PGA11301A dated 22 November 2018 from DBI, Hvidovre, Denmark.
Test report No. PGA11302A dated 16 January 2019 from DBI, Hvidovre, Denmark.
Test report No. RS-19/B-225/E dated 8 August 2019 from CTO, Gdansk, Poland.
Drawing No. S1547187 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547188 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547196 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547197 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547218 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547220 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547223 Rev. A dated 29 September 2020 from maker.
Drawing No. S1547224 Rev. A dated 29 September 2020 from maker.
2010 FTP Code part 3.
and the Mark of Conformity (see page 1).
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 3 of 3
