MERB00006GS
Roxtec sealing system with multidiameter technology: RS-series (Al)
MSC.1/1488
This Certificate is valid until 2025-12-20.
| DNV local unit: | Digitally Signed By: Mydlak-Röder, Christine |
| Gothenburg FIS |
| Approval Engineer: | Approved Body No.: 0097 |
| Roland Priebe | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 1 of 4 |
| Job Id: AA001WJW | |||
| Certificate No: MERB00006GS | |||
| Revision No: | 0 | ||
“Roxtec sealing system with multidiameter technology: RS-series (Al)”,
consisting of an aluminium sleeve, bolted or welded or attached through expansion (RS X) to an aluminium section.
Sleeve is filled with a Roxtec RS or RS OMD seal (standard or EMC) in sizes 23-150.
Approved for use as single and bundle pipe penetration system in class A-0 to A-60 aluminium bulkheads and decks as
follows:
| Pipe | Sleeve | Sleeve |
| Type | Size | diameter |
| material | position | insulation |
| (OD) [mm] | [mm] | [mm] |
| Steel, | ||
| RS / RS OMD | 23 - 150 | 6 - 119 |
| Titanium | ||
| RS / RS OMD | 23 - 150 | Copper |
| Bundle | ||
| RS / RS OMD | 43 - 100 | 16 - 50 |
| (Steel) |
Bundle
| RS / RS OMD | 50 | 18 | 65 | 6 | Any | S1040796 Rev. C |
| (Copper) | ||||||
| RS / RS OMD | 68 - 125 | GRP | 32 - 90 | 65 | 6-7 | Any |
| Copper, | ||||||
| RS X | 25 - 125 | Steel, | 6 - 108 | 65 | 4-7 | Either |
| Titanium |
| Steel, | ||
| Titanium | ||
Other applications are subject to case-by-case approval.
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge of the aluminium
frame or fully insulated. See insulation drawings specified in the Type Approval documentation. For fire class A-0, A-15
and A-30, the sleeve and pipes are to be insulated as for class A-60.
Mark of Conformity.
Test reports No. P603001 dated 23 January 2007 from SP, Sweden.
Test reports No. PG11898 dated 17 April 2009 from DIFT, Hvidovre, Denmark.
Test reports No. PG11955 dated 17 April 2009 from DIFT, Hvidovre, Denmark.
Test reports No. RS-17/B-555/E dated 15 January 2018 from CTO, Gdansk, Poland.
Test reports No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test reports No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test reports No. RS-19/B-020/E dated 27 May 2019 from CTO, Gdansk, Poland.
Test reports No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Test reports No. PGB10016A dated 3 June 2020 from DBI, Hvidovre, Denmark.
Test reports No. PGB10031A dated 9 July 2020 from DBI, Hvidovre, Denmark.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 2 of 4 |
Assessment report No. 9P02428 dated 13 September 2019 from RISE, Sweden.
Drawing No. S1040796 Rev. C dated 17 February 2015 from maker.
Drawing No. S1040877 Rev. A dated 18 August 2014 from maker.
Drawing No. S1040943 Rev. A dated 12 August 2014 from maker.
Drawing No. S1552313 Rev. A dated 11 February 2020 from maker.
Drawing No. S1552354 Rev. B dated 2 December 2020 from maker.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and in compliance with IMO 2010 FTP Code Ch. 8 and
IMO 2010 FTP Code Part 3.
and the Mark of Conformity (see first page).
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 3 of 4 |
consisting of an aluminium sleeve, bolted, welded or attached through expansion (RS X) to an aluminium section.
Approved for penetration in aluminium bulkheads or decks for steel and copper pipes limited to a pressure of 4.00 bar
watertightness and 2.67 bar gastightness, and GRP/GRE pipes limited to a pressure of 4.00 bar watertightness and
2.00 bar gastightness.
The penetration system shall not to be used for penetrating boundaries of tanks.
When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships (SPS), the
penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2009 issue). Penetrations
passing through watertight bulkheads are subject for separate examination and approval by actual flag administration.
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Test report No. MLM 060561 dated 1 December 2006 from DNV Malmö.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 4 of 4 |
