MERB00006JA-Rev-0-optimized
MERB00006JA
Roxtec sealing system with multidiameter technology: S-series (steel)
MSC.1/1488
This Certificate is valid until 2023-10-18.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 3
Certificate No: MERB00006JA
“Roxtec sealing system with multidiameter technology: S-series (steel)”
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SFOHK, SR, SK, SRC r20, SRC r40 and SBTB) in sizes 1-
8 and combinations thereof, welded or bolted to a steel section. The S frame is filled with Roxtec (standard, Ex or EMC)
halogen free RM modules. Assembled with Roxtec wedge kit (standard, Ex or EMC).
Approved for use as a single or multiple pipe penetration system in class A-60 steel divisions according to below tables.
Other applications are subject to case-by case approval.
For A-0, A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-
60 insulation for a minimum distance of 200 mm around the penetration.
Table 1: Approved pipe penetration in A-60 steel bulkhead.
Min.
Pipe Frame
Pipe frame
Size diameter
material length
(OD) [mm] [mm]
[mm]
S1553237 Rev. A
1–8 Steel
S1502599 Rev. C
S1553238 Rev. A
1–8 Copper
S1502599 Rev. C
Bundle S1553239 Rev. A
1–8 16 – 50
(Steel) S1502599 Rev. C
1–8 20
(Copper) S1502599 Rev. C
Table 2: Approved pipe penetration in A-60 steel deck.
Min.
Pipe Frame
Pipe frame
Size diameter
material length
(OD) [mm] [mm]
[mm]
S1553237 Rev. A
1–8 Steel
S1502062 Rev. B
S1553238 Rev. A
1–8 Copper
S1502062 Rev. B
1–8 16 – 52
(Steel) S1502062 Rev. B
1–8 20
(CuNi) S1502062 Rev. B
of Conformity
Test Report No. P602999 dated 23 January 2007 from SP, Borås, Sweden.
Test Report No. P603000 dated 23 January 2007 from SP, Borås, Sweden.
Test Report No. RS-17/B-395/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-485/E dated 10 December 2018 from CTO, Gdansk, Poland.
Drawing No. S1553237 Rev. A dated 6 March 2020 from maker.
Drawing No. S1553238 Rev. A dated 6 March 2020 from maker.
Drawing No. S1553239 Rev. A dated 6 March 2020 from maker.
Drawing No. S1502599 Rev. C dated 10 March 2020 from maker.
Drawing No. S1502062 Rev. B dated 10 March 2020 from maker.
2010 FTP Code part 3.
and the Mark of Conformity (see first page).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 3
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SR, SK, SRC r20, SRC r40 and SBTB) in sizes 1-8 and
gastightness for steel and copper pipes.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.00 bar
gastightness for bundle pipes.
Test Report No. MLM 020133 dated 26 February 2002 from DNV Malmö.
Test Report No. MLM 020400 dated 25 March 2002 from DNV Malmö.
Test Report No. MLM 020401 dated 25 March 2002 from DNV Malmö.
Test Report No. MLM 050410 dated 20 May 2005 from DNV Malmö.
Test Report No. MLM 060561 dated 1 December 2006 from DNV Malmö.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 3
