MERB000074M
Roxtec sealing system with multidiameter technology: H seals series (steel divisions)
This Certificate is valid until 2023-12-17.
| DNV local unit: | Digitally Signed By: Mydlak-Röder, Christine |
| Sweden CMC |
| Approval Engineer: | Approved Body No.: 0097 |
| Roland Priebe | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 1 of 4 |
| Job Id: AA001WJW | |||
| Certificate No: MERB000074M | |||
| Revision No: | 0 | ||
“Roxtec sealing system with multidiameter technology: H seals series (steel divisions)”,
is a single or multicable penetration system consisting of a steel sleeve welded or bolted to the division and filled with a
H seal of size 31 to 150.
Approved for use as a multicable penetration system in class A-0 and A-60 steel bulkheads or decks for approved ship
cables. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead
| Sleeve | Sleeve | |
| Type | Size | diameter |
| position | insulation | |
| (OD) [mm] | [mm] | [mm] |
| H | 31 - 150 | 50 |
Table 2: Approved cable penetration in A-60 steel deck
| Sleeve | Sleeve | |
| H | 31 - 150 | 50 |
Table 3: Approved cable penetration in A-0 steel bulkhead
| Sleeve | Sleeve | |
| H | 31 – 150 | 50 |
Table 4: Approved cable penetration in A-0 steel deck
| Sleeve | Sleeve | |
| H | 31 - 150 | 50 |
of Conformity.
Test Report No. RS-19/B-424/E dated 27 November 2019 from CTO, Gdansk, Poland.
Test Report No. PGA11610A dated 10 January 2020 from DBI, Hvidovre, Denmark.
Test Report No. PGA11611A dated 11 January 2020 from DBI, Hvidovre, Denmark.
Test Report No. RS-20/B-081/E dated 31 March 2020 from CTO, Gdansk, Poland.
Test Report No. RS-20/B-083/E dated 20 April 2020 from CTO, Gdansk, Poland.
Installation drawing:
Drawing No. S1558191 Rev. A dated 7 December 2020 from manufacturer.
Product drawing:
Drawing No. S1559058 Rev. A dated 23 September 2020 from manufacturer.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 2 of 4 |
and the Mark of Conformity (see first page).
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 3 of 4 |
is a multicable penetration system consisting of a steel sleeve welded to the division and filled with a H frame of size 31
to 150.
Test Report No. N141XE2A dated 19 December 2019 from DNV GL Malmö.
Pressure tested according to Class Programme DNV-CP-0165, Edition October 2017.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 4 of 4 |
