MERB00007UC-Rev-0-optimized
MERB00007UC
Roxtec sealing system with multidiameter technology: H seals series (steel divisions)
MSC.1/1488
This Certificate is valid until 2027-06-27.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 4
Certificate No: MERB00007UC
“Roxtec sealing system with multidiameter technology: H seals series (steel divisions)”,
consisting of a steel sleeve welded to a steel division. Sleeve is filled with a H seal of size 31 - 644.
H seals comes in standard (EPDM) rubber and FKM rubber
Approved for use as single or multi pipe penetration system in class A-60 steel bulkheads or decks. Other applications
are subject to case-by-case approval.
around the penetration.
material position insulation
H 31 Steel
| H | 31 - 150 | Steel | 6 - 30 | 35 - 65 | 4-6 | Symmetric | S1559067, No. 2 |
| H | 31 - 644 | Steel | 6 - 558 | 35 - 65 | 4-6 | Symmetric | S1559067, No. 3 |
| H (FKM) | 25 | Cu, CuNi, Steel | 10 | 35 | 4 | Symmetric | S1571790, No. 1 |
| H (FKM) | 25 - 150 | Cu, CuNi, Steel | 10 - 108 | 35 - 65 | 4-6 | Symmetric | S1571790, No. 2 |
H 31 Steel
| H | 31 - 175 | Steel | 6 - 68 | 35 - 65 | 4-6 | Symmetric | S1559067, No. 5 |
| H | 31 - 350 | Steel | 6 - 256 | 35 - 65 | 4-6 | Symmetric | S1559067, No. 6 |
| H | 31 - 644 | Steel | 6 - 558 | 35 - 65 | 4-6 | Symmetric | S1559067, No. 7 |
| H (FKM) | 23 - 50 | Steel | 10 - 28 | 35 - 65 | 4-6 | Any | S1571790, No. 3 |
| H (FKM) | 23 - 150 | Steel | 10 - 114 | 35 - 65 | 4-6 | Any | S1571790, No. 4 |
| H (FKM) | 23 - 400 | Steel | 10 - 356 | 35 - 65 | 4-6 | Any | S1571790, No. 5 |
| H (FKM) | 25 | Cu, CuNi, Steel | 10 | 35 | 4 | Symmetric | S1571790, No. 7 |
| H (FKM) | 25 - 150 | Cu, CuNi, Steel | 10 - 108 | 35 - 65 | 4-6 | Symmetric | S1571790, No. 8 |
of Conformity.
Test report No. PGA10141 dated 10 July 2012 from DBI, Hvidovre, Denmark.
Test report No. PGA11611A dated 11 January 2020 from DBI, Hvidovre, Denmark.
Test report No. RS-20/B-017/E dated 23 January 2020 from CTO, Gdansk, Poland.
Test report No. PGB10046A dated 16 November 2020 from DBI, Hvidovre, Denmark.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 4
Test report No. PGB10112A dated 20 September 2021 from DBI, Hvidovre, Denmark.
Test report No. RS-21/B-444/E dated 6 October 2021 from CTO, Gdansk, Poland.
Test report No. RS-21/B-445/E dated 7 October 2021 from CTO, Gdansk, Poland.
Test report No. PGB10118A dated 11 November 2021 from DBI, Hvidovre, Denmark.
Drawing No. S1559067 Rev. B dated 15 June 2022 from manufacturer.
Drawing No. S1571790 Rev. B dated 15 June 2022 from manufacturer.
and the Mark of Conformity (see first page).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 4
consisting of a steel sleeve welded to a steel division. Sleeve is filled with a H seal of size 31 - 150.
Test report No. N141XE2A, Rev.02 dated 19 February 2020 from maker.
Pressure tests with water and Helium according to DNV Class Programme DNV-CP-0165.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 4 of 4
