Nippon kaiji kyokai
NIPPON KAIJI KYOKAI
Certificate OF APPROVAL
Certificate No. TA22964E(R)
  • Item: A-0/60 class pipe penetration (deck and bulkhead)
  • Product name: Roxtec Sealing System with Multidiameter™ Technology (pipe)
  • Specifications: See Annex.
  • Applicant: Roxtec International AB
    Box540, S-371 23 Karlskrona, Sweden
  • Manufacturer: The same as the Applicant.
  • Testing standards: IMO FTP Code Annex1 / Part 3
    2010 FTP Code Annex1 / Part 3
  • Test reports: See Annex.
  • Limitations: See Annex.
THIS IS TO CERTIFY that the above type of product has been approved by Nippon Kaiji Kyokai with type approval No. 08FPA2DA, and that the products of the above type will be accepted for use onboard ships classed with the Society as complying with the relevant requirements of the Society’s Rules for the Survey and Construction of Steel Ships and those of the International Convention for the Safety of Life at Sea, 1974, as amended, subject to conditional upon the manufacturer having a quality control system audited by a competent authority to ensure continuous compliance with the type approval conditions.
This certificate is valid until 9 August 2026.
Issued at Tokyo on 21 December 2022.
NIPPON KAIJI KYOKAI
Y. Takao
General Manager
Material and Equipment Department
NOTE: The design, construction and way of installation are subject to the Annex(es). Any significant changes to the product without our approval will result in this certificate becoming null and void.
Annex to the Certificate No. TA22964E(R)
1. Test Reports
Test laboratory (Test place) Report number Issued date
Swedish National Testing and Research Institute / SP Technical Institute of Sweden / RISE Research Institute of Sweden AB
(SP Box 857 SE-501 15 Boras, Sweden)
P603000 23 January 2007
P602999 23 January 2007
P701755 12 June 2007
8P04040 13 August 2018
8P04039 6 August 2018
P902394 25 May 2009
4P08662 8 June 2015
8P07094rev 1 16 January 2020
PX05454rev1 8 September 2011
4P06068 17 January 2015
4P07023 4 February 2015
6P02249 17 August 2016
P603001 23 January 2007
5P03451 3 November 2015
5P03457 12 November 2015
5P08343 21 December 2015
5P08346 21 December 2015
5P08395 17 March 2016
6P05989 24 October 2016
6P05990 16 November 2016
6P07565 20 December 2016
DBI - Danish Institute of Fire and Security Technology
(Jernholmen 12, DK-2650 Hvidovre, Denmark)
PGB10112A 20 September 2021
PGB10113A 23 July 2021
PGA10800A 26 May 2016
PGA10799A 24 May 2016
PGB10047A 30 November 2020
PGA10649 18 May 2015
PGA10650 18 May 2015
PGA10141 10 July 2012
PGA11301A 22 November 2018
PGA11302A rev1 16 January 2019
PGB10111A 27 April 2021
PGB10110A 27 April 2021
PGB10020A 5 May 2020
PGB10032A 1 July 2020
PGA11610A 10 January 2020
PG11955 17 April 2009
PG11898 17 April 2009
PGB10077A 10 December 2020
PGA10802A 29 August 2016
PGB10015A 8 June 2020
PGB10031A 9 July 2020
PGA10870A 13 December 2016
Research Institute of Marine Engineering
(Fujimi-cho, Higashimurayama-city, Tokyo, Japan)
09-346E 11 December 2009
Ship Design and Research Centre / Maritime Advanced Research Centre (CTO S.A.) / CENTRUM TECHMIKI OKRETOWEJ S.A.
(65 Szczecińska Street, 80-392 Gdańsk, Poland)
RS-17/B-395/E 30 October 2017
RS-18/B-485/E 10 December 2018
RS-18/B-484/E 10 December 2018
RS-18/B-022/E 29 January 2018
RS-19/B-356/E 18 October 2019
RS-21/B-241/E 30 June 2021
RS-19/B-256/E 20 August 2019
RS-20/B-083/E 20 April 2020
RS-21/B-240/E 30 June 2021
RS-18/B-291/E 20 August 2018
RS-19/B-355/E 16 October 2019
RS-19/B-225/E 1 August 2019
RS-18/B-293/E 13 September 2018
RS-20/B-081/E 31 March 2020
RS-18/B-181/E 7 May 2018
RS-18/B-292/E 13 September 2018
RS-21/B-189/E 4 June 2021
RS-21/B-446/E 7 October 2021
RS-18/B-179/E 25 June 2018
RS-17/B-555/E 15 January 2018
RS-19/B-020/E 27 May 2019
RS-20/B-408/E 17 December 2020
RS-19/B-224/E 01 August 2019
RS-17/B-177/E 26 May 2017
RS-17/B-209/E 2 June 2017
RS-17/B-210/E 2 June 2017
2. Specifications
【Steel Division】
Type Class Size Approved direction
S-series frames A-60 1 – 8 and as combinations,
Min. 1x1 to Max. 8x2
(See drawing No. S1005520, S1005518, S1005519, S1005525, S1019592 and S1001544)
Horizontal / Vertical
S-series frames with PPS E frame A-60 6 and as combinations,
Min. 6x2 to Max. 6x4
(See drawing No. S1006468, S1006469 and S1504195)
Horizontal
S-series frames with PPS E frame A-60 1 – 8 and as combinations,
Min. 1x1 to Max. 8x1
Vertical
R-series frames A-60 50mm - 200mm Horizontal / Vertical
RS/RS OMD seals A-0 23mm - 644mm Horizontal / Vertical
RS/RS OMD seals A-60 23mm - 644mm Horizontal / Vertical
RS/RS OMD seals with fiberglass composite pipe A-0 50mm - 1125mm Horizontal / Vertical
RS/RS OMD seals with fiberglass composite pipe A-60 50mm - 1125mm Horizontal / Vertical
RS PPS seals A-0 31mm - 150mm Vertical
RS PPS seals A-60 31mm - 450mm Horizontal / Vertical
RS PPS/S seals A-60 31mm - 150mm Horizontal / Vertical
RS X kit A-60 25mm - 200mm Horizontal / Vertical
RS OC seals A-60 75mm - 400mm Horizontal
RS OC seals A-60 75mm Vertical
R X kit A-60 70mm - 200mm Horizontal / Vertical
SPM seals A-0 39mm - 279mm Horizontal / Vertical
SPM seals A-60 39mm - 279mm Horizontal / Vertical
【Aluminum Division】
(See drawing No. S1005520, S1005518, S1005519, S1005525 and S1504109)
(See drawing No. S1006468, S1006469 and S1504138)
R-series frames A-60 70mm - 200mm Horizontal / Vertical
RS/RS OMD seals A-60 23mm - 150mm Horizontal / Vertical
RS PPS seals A-60 31mm - 200mm Horizontal / Vertical
RS X kit A-60 31mm - 150mm Horizontal
RS X kit A-60 25mm - 150mm Vertical
SPM seals A-60 39mm - 279mm (for steel pipe) Horizontal / Vertical
SPM seals A-60 39mm - 157mm (for copper pipe) Horizontal / Vertical
3. Limitations
  1. In case that A-60 class penetration is used as A-15/A-30 class penetration, such penetration is to be applied to the specification for A-60 class penetration described in the attached drawing.
  2. In case that A-60 class penetration is used as A-0 class penetration, any insulation fitted (on the penetration itself and 200 mm around) to be fitted also for A-0 class penetration, except Drawing No. S1568681 revA (deck/bulkhead) and S1568682 revA (deck/bulkhead) for RS/RS OMD seals, S1585876 revA (deck) for RS/RS OMD seals with fiberglass composite pipe, S1503480 rev.A (bulkhead) for RS PPS seals, and S1574650 rev.A (deck) for SPM seals.
