Nippon kaiji kyokai
NIPPON KAIJI KYOKAI
Certificate
OF
APPROVAL
Certificate No.
TA231371E(R)
Item “A” class cable penetration
Product name Roxtec Sealing System with Multidiameter™ Technology (cable)
Specifications See Annex.
Applicant Roxtec International AB
Rombvägen 2, Lyckeby, Sweden
Manufacturer The same as the Applicant.
Testing standards 2010 FTP Code Annex1 / Part 3
IMO FTP Code Annex1 / Part 3
Test reports See Annex.
Limitations See Annex.
THIS IS TO CERTIFY that the above type of product has been approved by Nippon Kaiji Kyokai with type approval No. 08FPA1DA, and that the products of the above type will be accepted for use onboard ships classed with the Society as complying with the relevant requirements of the Society’s Rules for the Survey and Construction of Steel Ships and those of the International Convention for the Safety of Life at Sea, 1974, as amended, conditional upon the manufacturer having a quality control system audited by a competent authority to ensure continuous compliance with the type approval conditions.
This certificate is valid until 2 March 2028.
Issued at Tokyo on 7 December 2023.
NIPPON KAIJI KYOKAI
Y. Takao
General Manager
Material and Equipment Department
NOTE: The design, construction and way of installation are subject to the Annex(es). Any significant changes to the product without our approval will result in this certificate becoming null and void.
Annex to the Certificate No. TA231371E(R)
1. Test Reports
Test laboratory Report number Date of issue
SP Technical Research Institute of Sweden
(SP Box 857 SE-501 15 Boras, Sweden)
4P06068 17 January 2015
6P02249 17 August 2016
6P02516 29 August 2016
6P10022 7 March 2017
6P10024 7 March 2017
RISE Research Institutes of Sweden AB
7P02167 7 August 2017
8P04040 13 August 2018
DBI-Danish Institute of Fire and Security Technology
(Jernholmen 12 2650 Hvidovre, Copenhagen Denmark)
PGA10651 3 July 2015
PGA10652 3 July 2015
PGA10723A 4 February 2016
PGA10800A 26 May 2016
PGA10871A rev.1 9 December 2016
PGA10870A 13 December 2016
PGB10118A rev.1 15 November 2021
PGB10167A 18 March 2022
PGB10172A 17 June 2022
PGB10176A 4 November 2022
CENTRUM TECHNIKI OKRETOWEJ S.A.
(65 Szczecińska 80-392 Gdańsk Poland)
RS-17/B-176/E 25 May 2017
RS-17/B-177/E 26 May 2017
RS-17/B-395/E 30 October 2017
RS-17/B-396/E 31 October 2017
RS-18/B-485/E 10 December 2018
RS-21/B-518/E 15 December 2021
RS-22/B-153/E 4 May 2022
RS-22/B-336/E 28 October 2022
RS-22/B-338/E 28 October 2022
RS-22/B-394/E 28 November 2022
RS-22/B-425/E 2 January 2023
RS-22/B-427/E 2 January 2023
Research Institute of Marine Engineering
(1-5-12, Fujimi-cho, Higashimurayama-city, Tokyo, Japan)
09-344(E) 29 January 2009
09-345(E) 11 December 2009
2. Limitations
  1. In case that A-60 class penetration is used as A-15/A-30 class penetration, such penetration is to be applied to the specification for A-60 class penetration described in the attached drawing.
  2. In case that A-60 class penetration is used as A-0 class penetration, any insulation fitted on a fire exposed side (on the cable transits itself and 200 mm around) to be fitted also for A-0 class penetration.
3. Specifications
* Cable filing ratio is calculated as follows.
Cable filing ratio
= (The sum of cross sectional of the cables) ÷ (the inside cross-sectional area of coaming)
・ Cross sectional of the cable = R² x 3.14 (R² = Radius of Cable and the Seal.)
Frame Type Frame Size Approved Direction
(Vertical /Horizontal)
Filling ratio for Cable/
Maximum cable size
Insulation Drawings
S-Series Frames
(Insulation method No.1)
1-8 and Combination
(Max. S8+8x3)
Vertical No more than 40%
(Max size OD = 53mm)
A60/ S1597115
S-Series Frames
(Insulation method No.2)
1x1 Vertical 27.2%
(Max size OD = 23mm)
A60/ S1597115
S-Series Frames
8x1 Vertical 42%
(Max size OD = 90mm)
A60/ S1597115
S-Series Frames
8+8x5 Vertical 39.8%
A60/ S1597115
S-Series Frames
(Insulation method No.3)
1x1 Vertical 0.5%
(Max size OD = 6mm)
A60/ S1597115
S-Series Frames
8x1 Vertical 29.4%
(Max size OD = 84mm)
A60/ S1597115
S-Series Frames
8+8x5 Vertical 29.4%
A60/ S1597115
S-Series Frames 1-8 and Combination
(Max. S8+8x5)
Horizontal No more than 28.4%
A60/ S1595719
R-Series frame with SLR Sleeves 70-200 Vertical / Horizontal 1.4% to 20.25%
A60/ S1587458
R-Series frame with SLA Sleeve. SLA 50/ R50 Horizontal 16%
(Max size OD = 10mm)
A60/S1529529
A0/ S1529530
R-Series frame with SLA Sleeve. SLA 50/ R50 Horizontal 12%
A60/S1529529
A0/ S1529530
R-Series frame with SLA Sleeve. SLA 75/ R75 Horizontal 18.2%
(Max size OD = 32mm)
A60/S1529529
A0/ S1529530
R-Series frame with SLA Sleeve. SLA 100/ R100 Horizontal 8% to 25%
(Max size OD = 50mm)
A60/S1529529
A0/ S1529530
R-Series frame with SLA Sleeve. SLA 50/ R50 Vertical 8%
A60/S1529529
A0/ S1529530
R-Series frame with SLA Sleeve. SLA 100/ R100 Vertical 25%
A60/S1529529
A0/ S1529530
RS/RS OMD Seals with SLRS Sleeve 23-125 Vertical No more than 18.9%
A60/ S1587471
RS/RS OMD Seals with SLRS Sleeve 125 Vertical No more than 51.84%
A60/ S1587471
RS/RS OMD Seals with SLRS Sleeve 150 Vertical 44.44%
(Max size OD = 100mm)
A60/ S1587471
RS/RS OMD Seals with SLRS Sleeve 23-125 Horizontal No more than 18.9%
A60/ S1587471
RS/RS OMD Seals with SLRS Sleeve 125 Horizontal No more than 51.84%
A60/ S1587471
RS/RS OMD Seals with SLRS Sleeve 150 Horizontal 42.68% to 44.44%
A60/ S1587471
RS Seals with SLA Sleeve. SLA 25/ RS25 Horizontal 16%
A60/S1529526
A0/ S1529527
RS Seals with SLA Sleeve. SLA 75/ RS75 Horizontal 18.2%
A60/S1529526
A0/ S1529527
RS Seals with SLA Sleeve. SLA 25/ RS25 Vertical 16%
A60/S1529526
A0/ S1529527
RS Seals with SLA Sleeve. SLA 75/ RS75 Vertical 18.2%
A60/S1529526
A0/ S1529527
