Patch notes - Android app
4 Oct 2022 - 1.3.20
  • Fixed an application crash that occurred when updating from a previous version.
3 Oct 2022 - 1.3.19
  • Opening list now contains log events from the latest status change
  • The variant field is no longer required when editing a transit and the product has no solution sizes.
  • Existing transit documents that have been updated should now sync properly
6 Sep 2022 - 1.3.18
  • Fixed an issue that occurred when transit tag was not assigned to all openings.
18 Aug 2022 - 1.3.17
  • Fixed the product presentation for transits exported from Roxtec Transit Designer
17 Jun 2022 - 1.3.15
  • The Scan QR button now appears on the floorplan
  • No validation required of a transit solution when a partNumber is configured
30 May 2022 - 1.3.14
  • The sync dialog has been moved and the list of assets has been updated.
  • Updated the links to the installation help section
31 Mar 2022 - 1.3.12
  • ‘Data Matrix’ and ‘Barcode 128’ has been added as scannable barcode formats
  • Now using Floor plan friendly names where it is available
15 Feb 2022 - 1.3.11
  • Aligned the app with updated configuration data
28 Jan 2022 - 1.3.10
  • Fixed styling issue with clear icon in dropdown menus
27 Jan 2022 - 1.3.9
  • Floor plan names are now visible in the transit list and can be used as a filter
  • Added checklists for Roxtec transit installations
  • Fixed a bug that caused crashes when double-clicking on the floor plan image
10 Dec 2021 - 1.3.8
  • Fixed sync issues related to removed tags, photos and error codes
  • Fixed an issue with the zoom behavior when using the floor plan after setting a status
29 Nov 2021 - 1.3.7
  • Its now possible to add transits from the floor plan view
  • Fixed a condition when setting area classification
27 Sep 2021 - 1.3.6
  • Floor plans will now always download when syncing
21 Sep 2021 - 1.3.5
  • Photos wont crop when viewed
  • Transit tags can now be added on new transits
  • Fixed an application crash related to the bottom sheet
13 Sep 2021 - 1.3.3
  • Fixed a sync error related to removed transits
9 Sep 2021 - 1.3.2
  • Installation instructions have been added
  • Added a “Me” page where users can edit their profile information
  • Floating action buttons now stay at the top of the bottom sheet
  • Added the option to add tags to transits
  • Added a button to clear filters
  • Added the ability to draw on pictures taken with the app
  • Added an instructional video
  • Fixed an error when viewing large photos in the bottom sheet
  • Photos are now scaled down if they width exceeds 2048
  • Now possible to search for QR values
28 Jun 2021 - 1.3.1
  • Added a loading indicator when filtering floor plans
  • Added indeterminate progress bar in the floor plan view to indicate that transits are loading
22 Jun 2021 - 1.3.0
  • Improved performance of data read / write
4 Jun 2021 - 1.2.16
  • Fixed a bug where it was possible to create transits with duplicated IDs
25 May 2021 - 1.2.14
  • Fixed a sync error that occurred after updating the tags on a new opening
  • Fixed an issue with disrupted syncs that caused duplicates to be created
11 May 2021 - 1.2.13
  • Do not include data when using send logs
10 May 2021 - 1.2.12
  • Added onboarding app intro
  • Added onboarding tap targets
  • Transits can no longer be placed outside of the floor plan
20 Apr 2021 - 1.2.6
  • Improved the performance when zooming and planning in the floor plan view
13 Apr 2021 - 1.2.5
  • Fetch transit logs with the bulk API
  • Fetch transit document lists with the bulk API
  • Use ML-kit for scanning barcodes
  • Logged possible sync error
23 Mar 2021 - 1.2.4
  • Various bug fixes
12 Mar 2021 - 1.2.3
  • Various bug fixes
11 Mar 2021 - 1.2.2
  • Added a function to share the application logs
  • Changed the app icon
  • Added an option to pick a photo from the gallery
  • Display short text description for each transit status in the filter
5 Feb 2021 - 1.2.1
  • Fixed filtering tags not retaining checked state when closing and reopening the filter
  • Fixed a possible crash when selecting discard changes from transit definition
  • Fixed an issue where the app could crash when signing out and data was being loaded
28 Jan 2021 - 1.2.0
  • New access management system
  • Send device info when initiating sync
  • Add certificate pinning
  • Added Google analytics
  • Secured navigation to avoid app crashes
  • Fixed a crash that occurred after creating a new transit
  • Fixed a crash that occurred when clicking the sort button rapidly in succession.
27 Nov 2020 - 1.1.7
  • Move sign out action to navigation drawer
24 Nov 2020 - 1.1.6
  • Automatic retry for network related sync errors
  • Renamed application
18 Nov 2020 - 1.1.5
  • Fixed status updates not getting deleted when a transit was removed.
28 Oct 2020 - 1.1.4
  • Filter transit statuses by user role
  • Improved sync performance when syncing transit logs and documents
14 Oct 2020 - 1.1.3
  • A warning is now shown when disk space is getting low
  • Edit demand specification comment in the transit definition
  • Show empty lists graphics
  • Automatically start feting data after first login
  • Edit transit tags from transit detail view
  • Show transit statuses on floor plans
  • Can use flash while scanning QR
  • Ability to delete transits
21 Aug 2020 - 1.1.0
  • First public version
