Roxtec Transit Designer — Release Notes - 4.45.0 (2026-04-17)
What’s changed in each update, explained in plain language.
4.45.0 (2026-04-17)
Summary: Deep linking for cables, better drawer scrolling, and a loading screen for improved reliability.
New Features
  • [Cables] Added shareable deep links that open cable details directly from a URL
  • [UI] Added a loading indicator and an error page shown when key resources fail to load
  • [Transits] Added the ability to right-click a transit on the project overview to open it in a new tab
Improvements
  • [Account] Improved email address changing when the new email already exists externally
  • [Logs] Changed the audit log sort order to show the most recent entries first
Bug Fixes
  • [UI] Fixed an issue where scrolling in a drawer would also scroll the background page
  • [Documents] Fixed an error when pushing documents larger than 20 MB to Build/Operate
  • [Transits] Fixed the “Set target” link for spare capacity being cut off in the sidebar
  • [Transits] Fixed an issue where obsolete part depth values could affect configuration selection
Changes
  • [Account] Disabled email address changes in Standalone mode
  • [Account] Required re-acceptance of Terms of Use after changing an email address
  • [Security] Resolved multiple security vulnerabilities
4.44.2 (2026-03-19)
Summary: Fixed a copy-paste regression on the packing page and improved error handling during navigation.
Improvements
  • [UI] Removed the bottom panel (Tell a Friend and community RSS feeds) from the dashboard page
Bug Fixes
  • [Packing] Fixed a regression in copy-paste between openings on the packing page
  • [Navigation] Fixed an error when quickly navigating away from a project before it has fully loaded
4.44.1 (2026-03-13)
Summary: Categorized certificate ratings and improved the “Used in project” list for existing-hole transits.
New Features
  • [Certifications] Added categorized ratings in the certificate rating selector when certificates support it
Improvements
  • [Transits] Filtered the “Used in project” list for existing-hole transits to show only configurations that fit the hole
Bug Fixes
  • [Tables] Fixed input of tabular data in nested data grid properties and improved undo handling in data grids
4.44.0 (2026-03-06)
Summary: Email address changes, improved BOM documents, and better single-solution document generation.
New Features
  • [Account] Added the ability to change your own email address
Improvements
  • [Documents] Included target and current spare capacity in Bill of Material documents
  • [Documents] Updated the DD cover opening menu item text to “Restore knockout” when applicable
  • [Documents] When requesting “Cable pulling and Packing plan” for a single-solution transit, a “Solution overview” page is now generated instead
4.43.0 (2026-02-20)
Summary: Undo support for cables/pipes, keyboard shortcuts, and better blueprint drawings for single-solutions.
New Features
  • [Cables] Enabled undo in the cables/pipes grid in detailed mode
  • [Keyboard] Added a button to show available keyboard shortcuts on the cables/pipes page in detailed mode
Improvements
  • [Documents] Included cable/pipe/conduit positions for single-solutions on the solution overview page in generated blueprints
  • [Documents] Hid the module legend block on drawings generated for single-solutions
Changes
  • [UI] Removed the old paste button from the cables/pipes page
4.42.0 (2026-02-09)
Summary: Better module validation, searchable location selector for moving transits, and improved audit log display.
Improvements
  • [UI] Preserved link color when hovering over link buttons, including sidebar headers
  • [Transits] Adjusted the message in the Move transits dialog to be more accurate
  • [Transits] Made the location selector in the Move transits dialog searchable
  • [Transits] Prevented rotation of a module that has a size limitation
  • [Transits] Changed module size limitation violations to non-stopping warnings instead of blocking errors
  • [Transits] Added a validation check for shallow modules that don’t touch the frame side
Bug Fixes
  • [Logs] Fixed rendering of the project’s “root location” in the audit log to show the project name instead of a code
  • [Transits] Fixed broken notification when trying to use a transit with an inaccessible solution
Changes
4.41.15 (2026-01-26)
Summary: Move transits to a new location, improved tooltips, and better read-only handling.
New Features
  • [Transits] Added the ability to move one or more transits to a new location on the project overview page
Improvements
  • [UI] Tooltips now appear even on disabled elements to help explain why an action is unavailable
  • [Transits] Disabled the edit dialog for read-only transits to prevent confusion
Changes
  • [Account] Required IFS Contract and Coordinator settings to be set before IFS quote is available
4.41.14 (2026-01-19)
Summary: Non-BG modules in BG contexts and an updated transit actions menu on the project overview.
New Features
  • [Modules] Allowed the use of non-BG modules in certain BG contexts when enabled for the project
Improvements
  • [Transits] Replaced the Remove button with a dropdown menu when transits have been selected on the project overview page
4.41.13 (2026-01-14)
Summary: Restored read-only state for read collaborators on the project overview page.
Bug Fixes
  • [Access] Restored read-only state on the project overview page for read collaborators
4.41.12 (2026-01-14)
Summary: Fixed a transit autosave regression that could cause errors during navigation.
Bug Fixes
  • [Transits] Fixed a regression in the transit autosave feature that could lead to errors during navigation
4.41.11 (2026-01-14)
Summary: Non-BG modules in BG+EX contexts when enabled for the project.
New Features
  • [Modules] Allowed the use of non-BG modules in certain BG+EX contexts when enabled for the project
4.41.10 (2025-12-17)
Summary: Fixed a wedge locking issue on the packing page.
Bug Fixes
  • [Packing] Fixed an issue where dragging the wedge over a corner module would lock it in place
4.41.9 (2025-12-16)
Internal improvements — no user-facing changes.
4.41.8 (2025-12-16)
Summary: Fixed an autopack error and improved Build/Operate push with project-wide cables.
Bug Fixes
  • [Packing] Fixed an autopack error showing “Found invalid module position after sorting”
  • [Cables] Fixed cable data not being included when pushing a transit with project-wide cables to Build/Operate
Changes
4.41.7 (2025-12-11)
Summary: Fixed a GH 3x1 autopacking issue and better error messages with context.
Bug Fixes
  • [Packing] Fixed an issue where a GH 3x1 opening could not be filled by the autopacker
4.41.6 (2025-12-02)
4.41.5 (2025-12-01)
Summary: Visual filter indicators, info icons for cable categories, and improved data table filtering.
New Features
  • [Cables] Added an info icon that explains the purpose of a cable/pipe category where applicable
Improvements
  • [Filter] Added a visual indicator showing when a filter is active in a data table
  • [Import] Added a tooltip explaining the “Enable project specific cable list” option in the project creation dialog
4.41.4 (2025-11-17)
Summary: Redesigned module editor, improved sorting icons, and better drag behavior on the packing page.
New Features
  • [Packing] Redesigned the module editor on the packing page for better usability
Improvements
  • [Account] Password managers now only appear where needed, reducing visual clutter
  • [Packing] When dragging selected modules, large modules can now be packed over small ones
  • [UI] Changed sorting icons in tables to show an up arrow for ascending and down for descending
  • [Packing] Added a message about default module selection in the module editor
4.41.3 (2025-10-23)
4.41.2 (2025-10-22)
Summary: Fixed a graphical bug on the Cables&Pipes page in narrow browser windows.
Bug Fixes
  • [Cables] Fixed a graphical bug in detailed mode on the Cables&Pipes page when the browser window is narrow
  • [Packing] Fixed a tooltip error for unknown modules during split-core checks
4.41.1 (2025-10-22)
Summary: Split-core improvements, better tooltips on the packing page, and improved user sync.
Improvements
  • [Packing] Updated tooltips for positioned modules to include split-core information
  • [Packing] Removed the module ID from spare tooltips since it has no meaning for users
  • [Packing] Improved split-core handling when checking if a transit has a hole
Bug Fixes
  • [Packing] Fixed an issue where split-core modules were incorrectly treated as regular modules
  • [Packing] Kept split-core modules when changing cables/pipes for a transit
4.41.0 (2025-10-03)
Summary: Split-core product support, multi-name transit filtering, and improved Design page performance.
New Features
  • [Modules] Added support for split-core products
  • [Transits] Added support for filtering by multiple transit names on the project overview page
Improvements
  • [Packing] Set the wedge background color based on the module family configuration
  • [Documents] Considered Inventor file for sleeve when enabling or disabling Kit model generation
  • [Errors] Improved error handling when deleting multiple transits
  • [Navigation] Restored the selected location after clearing search on the project overview page
  • [Performance] Improved performance of the Design page for transits with many solutions
Bug Fixes
  • [Packing] Fixed overlap snapping glitch when dragging a selected solution
  • [Packing] Fixed an opening with the wedge moved down not being completely filled during autopack
  • [Transits] Reset search state after deleting transits on the project overview page
  • [Documents] Updated dialog titles in Docs & Files and cart replacement dialogs
  • [Transits] Disabled the edit transit action when the current page has an error
Changes
  • [UI] Adjusted the view styling with a flex toolbar and collapsed content margins
4.40.3 (2025-09-10)
Summary: Snap-to-overlap for rotated solutions and improved transit restoration performance.
New Features
  • [Design] Added snap-to-overlap support on the Design page when solutions are rotated
Changes
4.40.2 (2025-09-04)
Summary: Quote request replaces Buy/Cart, improved Design page performance, and better tab navigation.
New Features
  • [Documents] Replaced the Buy/Cart button with a quote request dialog
Improvements
  • [Performance] Improved the performance of the Design page for transits with many solutions
  • [Documents] Made the Docs & Files dialog more consistent and restored button icons
  • [Navigation] Tab navigation now shows clickable arrows only when more tabs are available to scroll
Bug Fixes
  • [Documents] Prevented stalled document generation for transits with many solutions
4.40.1 (2025-08-20)
Summary: Fixed pasting issues in data grids with excessive columns.
Bug Fixes
  • [Tables] Fixed pasting in the data grid when the pasted data has too many columns
4.40.0 (2025-08-19)
Summary: Split-core support prep, better dimension text display, and mandatory warnings for cables without IDs.
New Features
  • [Import] Added a mandatory warning when importing transits with multiple cables or adding cables without IDs
Improvements
  • [Design] Improved dimension text visibility on the Design page even when solutions overlap
  • [Design] Included custom name on the Design page when set
  • [Packing] Included custom name and sleeve name in the information popover for a solution on the packing page
Bug Fixes
  • [Transits] Fixed an issue where changing to single-solution type would not update the sidebar
  • [Transits] Cleared the custom name when changing from multi-solution to single-solution
Changes
  • [Performance] Improved performance of soft-deleting many items and prevented database errors
4.39.3 (2025-07-24)
Summary: Fixed project backup with deleted locations and improved cable mutation prevention.
Improvements
  • [Import] Improved handling of importing a multi-move/rename file for the wrong project
Bug Fixes
  • [Projects] Fixed an issue preventing project backup when a deleted location contains a non-deleted transit
  • [Cables] Fixed a digest error on the cables/pipes page when pressing the browser back button
4.39.2 (2025-07-11)
4.39.1 (2025-07-11)
Summary: Added a transit migration to clean up dangling cable references.
Improvements
  • [Cables] Added a transit migration that removes dangling cable references from module instances
4.39.0 (2025-07-10)
Summary: Better error messages for cable diameter input, input validation, and improved collaborator search.
Improvements
  • [Cables] When entering cable diameter 0, the error now explains the size issue instead of showing a generic error
  • [Collaborators] Removed placeholder users from the collaborator search dropdown
  • [UI] Aligned the site header layout with other Roxtec applications and updated all dropdown menus
Bug Fixes
  • [Cables] Fixed an issue with tooltip and icon toggling in the project tree
Changes
  • [Validation] Rejected HTML characters in various input fields for improved security
4.38.2 (2025-06-21)
Summary: Fixed sorting issues on the project overview page.
Bug Fixes
  • [Transits] Fixed sorting on the Incomplete and Manually packed columns on the project overview page
4.38.1 (2025-06-19)
Summary: Fixed project sharing and improved sorting on the packing plan page.
Bug Fixes
  • [Collaborators] Fixed project sharing for email addresses not yet known by the system
  • [UI] Prevented the Go online/offline buttons from briefly appearing when navigating to the project list
  • [Packing] Fixed the packing plan page to sort by ID by default instead of a random order
4.38.0 (2025-06-10)
Summary: Replaced Expand/Collapse text with icons and discontinued Thin Client.
Improvements
  • [UI] Replaced “Expand/Collapse all” button text with an icon to fix spacing issues with certain translations
Changes
  • [Access] Users working with Thin Client are now redirected to a discontinuation notice page
  • [Security] Resolved a security vulnerability
4.37.41 (2025-05-23)
Summary: Added transit relocation, tooltips for disabled elements, and system message support.
New Features
  • [Transits] Added the ability to move transits to a new location on the project overview page
  • [Notifications] Added support for non-closable system messages to notify about planned downtime
Improvements
  • [UI] Tooltips now appear on disabled elements to help explain unavailable actions
  • [Transits] Disabled the edit dialog when a transit is read-only
  • [Account] Linked to the EULA on roxtec.com instead of opening a dialog for Terms of Use
4.37.40 (2025-05-07)
Summary: Fixed a broken multi-import file upload.
Bug Fixes
  • [Import] Fixed a broken file upload for multi-import
4.37.39 (2025-05-06)
4.37.38 (2025-05-05)
Summary: Fixed dropdown positioning, API key copying, and various visual issues.
Improvements
  • [UI] Changed dropdown items to span full width to fix partial background highlights
Bug Fixes
  • [UI] Fixed an issue where dropdowns could appear in the wrong place during fast clicks
  • [Settings] Fixed the copy button when copying an API key in project settings
  • [Transits] Excluded erroneous used-in-project configurations instead of showing an error
4.37.37 (2025-04-23)
Summary: Improved keyboard navigation for dropdowns and better collaborator search.
Improvements
  • [UI] Dropdown items that perform actions can now be disabled and are accessible via keyboard navigation
4.37.36 (2025-04-11)
4.37.35 (2025-04-11)
Summary: Doubled installation material for back-to-back singles in material lists.
Improvements
  • [Documents] Doubled the installation material for back-to-back singles in Bill of Material and other material lists
4.37.34 (2025-04-11)
Summary: Faster project loading, e-commerce problem detection, and reduced visual clutter.
Improvements
  • [Performance] Improved project loading speed on the dashboard and project list pages
  • [UI] Hid the tab bar when only one tab is present to reduce visual clutter
Bug Fixes
  • [Documents] Detected e-commerce problems related to inactive or incomplete IFS customers and showed a specific message
4.37.33 (2025-03-25)
Summary: Better collaborator search supporting email display format.
Improvements
  • [Collaborators] Supported email display format (e.g. “Some User user@example.com”) when searching for collaborators
  • [Collaborators] Trimmed whitespace around email addresses when adding a collaborator
4.37.32 (2025-03-14)
4.37.31 (2025-03-12)
Summary: Improved collaborator invitations for new users and up to 10x faster bulk updates.
New Features
  • [Collaborators] Added the ability to invite non-existing users as project collaborators with immediate access upon login
Improvements
  • [Performance] Improved performance up to 10 times for certain bulk update operations
  • [Collaborators] Showed progress when inviting a non-existing user as a collaborator
  • [Collaborators] Cleared the add-new-collaborator field after inviting someone
4.37.30 (2025-03-03)
4.37.29 (2025-02-28)
Summary: Fixed checkbox appearance, GK packing rules, and popover arrows.
Improvements
  • [Packing] Allowed placing solid RM 20 EX next to RM 40 EX in frames with 60 mm packing width
Bug Fixes
  • [UI] Fixed the appearance of a checkbox switch when disabled
  • [UI] Fixed an oversized arrow shown for popovers
  • [Packing] Fixed an error when editing multiple modules with parts that don’t fit the opening space
4.37.28 (2025-02-24)
4.37.27 (2025-02-21)
4.37.26 (2025-02-19)
Summary: Removed Thin Client references, improved error messages, and better read-only mode.
Improvements
  • [UI] Made all input controls disabled and hid the data management tab in read-only project settings
  • [UI] Restored mouse wheel scrolling in data grids
  • [Errors] Showed descriptive project and transit load errors instead of generic status code errors
Bug Fixes
  • [Navigation] Fixed rare rendering issues when deleting or adding locations
Changes
  • [UI] Removed the reference to Thin Client in the help menu
4.37.25 (2025-02-13)
Summary: Improved dropdown behavior on smaller screens.
Improvements
  • [UI] Dropdowns now stay visible within the viewport and scroll when needed on smaller screens
4.37.24 (2025-02-10)
4.37.23 (2025-02-10)
Summary: Rectangular logos for company accounts and improved read-only project settings.
New Features
  • [Account] Added support for rectangular logos for company accounts
Improvements
  • [Settings] Ensured selecting an asset enables the save button on the project settings page
  • [Settings] Made all controls disabled in read-only mode on the project settings page
4.37.22 (2025-01-28)
Summary: Better blueprint text layout and multi-transit move/rename for admins.
Improvements
  • [Documents] Added line breaks for long solution texts in generated blueprint files
4.37.21 (2025-01-21)
Summary: Audit log enabled by default for new projects, transit settings tab, and default spare capacity.
New Features
  • [Settings] Added a Transit settings tab on the Project settings page
  • [Transits] Made it possible to set a default spare capacity for new transits
Improvements
  • [Projects] Enabled the audit log option by default when creating a new project
  • [UI] Ensured text in select boxes on the Design page is vertically centered
Bug Fixes
  • [Navigation] Restored the Create project button in the empty-state text on the projects page
  • [Documents] Fixed document generation progress being over-reported, causing premature download attempts
  • [Transits] Prevented newlines in transit names, which could make documents invisible in downloaded ZIP files
  • [Packing] Improved the “Select all” checkbox behavior on the packing page to stay in sync
Changes
4.37.20 (2024-12-08)
Summary: Fixed project list scrolling and case-insensitive search.
Bug Fixes
  • [Projects] Fixed broken scrolling when there are many projects on the project list page
  • [Search] Restored case-insensitive project search on the project list page
4.37.19 (2024-12-05)
Summary: Consistent project list, improved transit weight calculation, and better logout behavior.
Improvements
  • [Projects] Used the same project list component on the dashboard and the projects page
  • [Documents] Included sleeve weight when calculating transit weight on generated drawings
  • [Auth] Improved logout to also sign out from the external login provider
Bug Fixes
  • [Documents] Restored the placement of the limited-badge in the Docs & Files dialog
4.37.18 (2024-11-19)
Summary: Default length unit based on country and improved validation for existing holes.
New Features
  • [Documents] Added a link to 3D CAD Libraries on roxtec.com in the solution customization step
Improvements
  • [Measurements] Set the default length unit for new users based on their country (inches for US, millimeters elsewhere)
  • [UI] Hid the contact link in the site header when the country’s support team has no phone contact
  • [Validation] Required width and height to be greater than zero in the Existing hole form
4.37.17 (2024-11-13)
Summary: Restored email verification handling and showed profile images in the header.
Improvements
  • [Account] Showed a user’s profile image from settings in the site header avatar
  • [Auth] Restored user-friendly handling when trying to use the application without verifying the email address
4.37.16 (2024-11-12)
Summary: Removed unnecessary animations, fixed sleeve material errors, and improved AD login support.
Improvements
  • [Account] Made user address, city, and zip code optional to prepare for the new Signup flow
  • [UI] Removed undesired animations when navigating to the Design page and in the Match hole panel
Bug Fixes
  • [Transits] Fixed an error when changing sleeve material directly after changing variant
  • [Packing] Updated the area cache after packing space correction to ensure the transit can be saved
Changes
  • [Account] Removed the Buy button for users in markets where e-commerce is not active
4.37.15 (2024-11-05)
Summary: Fixed corner module positioning and improved footer layout.
Bug Fixes
  • [Packing] Fixed corner modules not moving to the top of an opening when packing height changed
  • [UI] Moved the logo in the footer to the right when the chat is present
4.37.14 (2024-11-05)
Summary: New site header design, animated expand/collapse sections, and split-core improvements.
New Features
  • [Modules] Allowed changing the case of transit or location names on the project overview page
Improvements
  • [UI] Aligned the site header layout with Operate/Build and updated all dropdown menus to a new look
  • [UI] Animated expand/collapse sections in the Add transit and Add solution dialogs
  • [Transits] Set an area automatically when changing transit type to Cabinet
  • [Documents] Included custom solution and frame names on generated CAD detail pages
Bug Fixes
  • [Packing] Fixed an unexpected module count error when dragging from a single solution to an SRC solution
  • [Transits] Fixed an error when changing variant if sleeve material was changed first
Changes
  • [Account] Removed the user title field
4.37.13 (2024-10-08)
4.37.12 (2024-10-07)
Summary: Improved GK autopacking, snapping, and module selection inside corner modules.
Improvements
  • [Packing] Improved GK autopacking when a module has been placed inside a corner module
  • [Packing] Improved snapping of GK modules inside and around corner modules
  • [Packing] Made module size mix errors more consistent when modules are placed inside corner modules
Bug Fixes
  • [Packing] Fixed an issue where it was sometimes not possible to select a module inside a corner module
4.37.11 (2024-09-27)
Summary: Fixed an error when stacking modules in GK corner modules.
Bug Fixes
  • [Packing] Fixed an error when stacking two modules in a 2-corner GK module that extend above the corner
4.37.10 (2024-09-26)
Summary: Free module size mixing in GK RM frames, part/frame depth selection, and ghost solution improvements.
New Features
  • [Design] Added the ability to select part and frame depth when configuring a solution
Improvements
  • [Packing] Allowed mixing module sizes freely in GK RM frames without warnings
  • [Design] Preserved frame size when changing a configuration property or replacing a solution
  • [Design] Improved the display of mounting type in the Configure solution step and summary page
  • [Design] Improved the visualization of links in popup help boxes
Bug Fixes
  • [Packing] Fixed a bug where changing EMC type would not update modules in a spare-only solution
  • [Packing] Fixed the EMC type not updating the wedge when it should change
Changes
  • [Documents] Disabled Step and Revit file downloads for transits with ghost solutions
  • [Design] Hid irrelevant information for ghost solutions during configuration and on the summary page
4.37.9 (2024-09-27)
Summary: Ghost solution improvements and Chrome/Edge rendering workaround.
Bug Fixes
  • [UI] Added a workaround for broken rendering in the Add to Cart dialog in Chrome and Edge
Changes
  • [Design] Excluded cutout detail for ghost solutions when generating drawings
  • [Design] Hid mounting, material selection, and stock availability for ghost solutions
4.37.8 (2024-09-05)
Summary: Fixed EMC wedge updates and ghost solution display improvements.
Bug Fixes
  • [Packing] Fixed a regression where the EMC type change did not update the wedge properly
Changes
  • [Design] Hid solution characteristics for ghost solutions in the solution list
4.37.7 (2024-08-27)
Summary: Improved autopacking for EMC GK, better GK stayplate handling, and performance improvements.
Improvements
  • [Packing] Improved the autopacker for GK EMC to place multiple ZWP modules to fill openings
  • [Packing] Adjusted positions when dropping 60-spares at the bottom of a GK opening to avoid conflicts
  • [Performance] Improved the performance of the “Used in project” tab in the Add solution dialog
  • [Documents] Showed a specific error message when Push to RTO/RTB fails because the target asset was deleted
  • [Packing] Enabled horizontal scrolling for packing plan module lists with long names
  • [UI] Adjusted the Add solution dialog styling to remove excessive whitespace
  • [Design] Moved the Back and Choose buttons so they are visible on the installation instructions tab
Bug Fixes
  • [Packing] Fixed autopack for EMC SPK-S50 8x3 that would not fill all openings in some cases
  • [Packing] Fixed inconsistent grid snap behavior after using undo/redo
  • [Packing] Fixed missing stayplate above a module row near the wedge in certain GK frames
Changes
  • [Packing] Reported an error for three adjacent GK module rows in an opening
  • [Packing] Removed a false positive warning about wedge stayplate support
4.37.6 (2024-08-13)
4.37.5 (2024-08-13)
Summary: GK corner module improvements, “Number of openings” section fix, and better UX for EX modules.
Improvements
  • [Packing] Adjusted rules for EX module mixing to allow solid 30 modules next to 60 modules when supported
  • [Packing] Used corner modules that actually fit in the opening, even if others are preferred
  • [Packing] Supported opening GK transits with no room for stayplates next to the wedge and showed a warning
Bug Fixes
  • [Design] Fixed a regression where the “Number of openings” section was not open from the start
Changes
4.37.4 (2024-07-09)
Summary: Fixed SRC frame height change after moving the wedge.
Bug Fixes
  • [Packing] Fixed a bug preventing height changes for SRC frames after moving the wedge down
4.37.3 (2024-07-05)
Summary: Fixed broken styling when configuring solutions.
Bug Fixes
  • [Design] Fixed broken styling of images when configuring a solution in the Add solution dialog
4.37.2 (2024-07-05)
Summary: Fixed Design page errors and improved wedge/stayplate handling during changes.
Improvements
  • [Design] Kept the Additional materials section open after selecting a wedge or stayplate material
  • [Design] When changing solution size or opening count, tried to keep wedge and stayplate even if disconnected
  • [Import] When importing a transit with a discontinued stayplate, tried different wedges to find a suitable one
Bug Fixes
  • [Design] Fixed an error on the Design page when navigating quickly with a sleeve solution
4.37.1 (2024-07-02)
4.37.0 (2024-07-01)
Summary: Expanded wedge drawings, ghost solution improvements, and better GK stayplate handling.
Improvements
  • [Documents] “Expanded” the wedge when generating DXF drawings for small Roxtec and GK frames
  • [Design] Improved opening snapping during drag-and-drop, especially for GK frames
  • [Packing] Prioritized stayplates around the wedge, fixing two GK issues with ZWP module placement
  • [Packing] Ensured GK wedges and size 60+ modules are supported by stayplates on both sides
Bug Fixes
  • [Design] Fixed the sidebar not updating when changing from multi-solution to single-solution
  • [Documents] Added a workaround for text overflow in blueprint infodrawings
  • [Design] Fixed a bug with custom side names when using multiple back-to-back solutions
Changes
  • [Design] Hidden dimensions, aperture, and mounting information for ghost solutions
  • [Design] Limited transit type to single-solution when using a ghost solution
  • [Design] Hidden irrelevant information on the summary page for ghost solutions
4.36.8 (2024-05-17)
Summary: Fixed visual gaps in GK openings and restored the red line indicator.
Improvements
  • [Packing] Removed visual gaps between modules in GK openings caused by stayplate thickness
  • [UI] Made it possible to filter products on the customized product admin page
Bug Fixes
  • [Packing] Restored the red line on the opening toolbar below GK openings where minimum packing space was not reached
Changes
  • [Notifications] Disabled the chat functionality due to an upcoming system change
4.36.7 (2024-04-23)
4.36.6 (2024-04-23)
4.36.5 (2024-04-23)
Summary: Fixed tooltips after clicking links and mounting-related errors for H3 with existing holes.
Improvements
  • [Design] When filtering the solution list on Casting, kept Casting as the mounting when selecting a solution
  • [Performance] Changed activity signaling to be non-blocking, preventing resource loading delays
Bug Fixes
  • [UI] Fixed a rare issue where tooltips stayed visible after clicking links
  • [Design] Fixed multiple mounting-related errors when selecting H3 with an existing-hole transit
  • [Design] Fixed an error when creating an existing-hole transit, filtering by mounting, then selecting R UG
  • [Cables] Fixed a rare duplicate cable ID error being detected too late
4.36.4 (2024-03-21)
Summary: Fixed popover positioning and empty variant lists on the Design page.
Improvements
  • [Packing] Tried to keep cables together in a multi-cable module when modules were re-allocated
Bug Fixes
  • [UI] Tweaked popover positioning so the arrow doesn’t overlap the target element
  • [Design] Fixed empty or incomplete variant and size lists when no cable fit the variant
4.36.3 (2024-03-09)
Summary: Added fill-with-opposite option on the packing page and improved opening toolbar updates.
New Features
  • [Packing] Added an option to fill with the opposite of the default type on the packing page
Bug Fixes
  • [Packing] Updated the opening toolbar state when the transit changed due to undo/redo
4.36.2 (2024-03-06)
Summary: Fixed a drag-and-drop error on the packing page.
Bug Fixes
  • [Packing] Fixed an error during module drag-and-drop on the packing page
  • [Packing] Adjusted the visual appearance of the opening toolbar
4.36.1 (2024-03-05)
Summary: Enabled “Matching existing hole” transit type for all Roxtec users.
New Features
  • [Transits] Enabled the “Matching existing hole” transit type for all Roxtec users
4.36.0 (2024-02-29)
Summary: Allowed downloading drawings for transits with validation problems.
Improvements
  • [Documents] Allowed downloading a drawing document for a transit that has validation problems
Bug Fixes
  • [Packing] Fixed CSS needed for displaying H6 modules correctly on the packing page
4.35.0 (2024-02-26)
Summary: Improved the multi-import template and showed solution names on Design and Packing pages.
Improvements
  • [Design] Showed the name of the chosen solution on the Design and Packing pages
  • [Design] Removed the design stock status help text to make more room in the UI
  • [UI] Indicated that Kit model and Match existing hole features are limited to selected users
Bug Fixes
  • [Import] Fixed the multi-import template to specify the default pack algorithm correctly
4.34.0 (2024-02-18)
Summary: Replaced firestop solutions with grid solutions and improved CRL module snapping.
Improvements
  • [Design] Made it possible to replace a firestop solution with a grid solution
  • [Packing] Improved snapping of modules in openings that use 22/33/66 modules
Bug Fixes
  • [Packing] Fixed a bug where a stayplate could intersect a module inside a GK corner module
4.33.1 (2024-02-05)
Summary: Fixed Chinese text font on info drawings.
Bug Fixes
  • [Documents] Patched the font for Chinese text on some info drawings to use DengXian instead of Arial
4.33.0 (2024-01-30)
Summary: Improved GK autopacking and added unsaved changes warning on project settings.
New Features
  • [Settings] Added a warning when leaving the project settings page with unsaved changes
Improvements
  • [Packing] Improved autopacking for GK so 2-corner modules are used and filled better
Bug Fixes
  • [Packing] Fixed incorrect frame size behind openings on the packing page
  • [UI] Styled file inputs for the “Create project from backup” dialog
  • [Import] Showed a progress dialog when finishing a multi-import to prevent accidental button clicks
4.32.5 (2024-01-22)
Summary: Fixed solution replacement errors and removed broken animation.
Bug Fixes
  • [Packing] Fixed an error when replacing a solution with an added cover to one with corner modules
  • [Cables] Removed a broken estimate-row removal animation on the cables/pipes/conduits page
  • [Import] Fixed the “Security brake: Too much TRs” error when adding multiple transits from a large file
4.32.4 (2024-01-19)
Summary: Fixed GK transit completeness and added blueprint cable list scale settings.
New Features
  • [Settings] Added a tab in project settings to configure the blueprint cable list scale
Improvements
  • [Packing] Added support for breaking position texts into two lines for small modules on blueprint detail pages
  • [UI] Removed accidental title tooltips for section titles in the Design page sidebar
  • [Packing] Added WOC to the module preference label for customized WOC modules
Bug Fixes
  • [Transits] Fixed a full GK transit with round corners being incorrectly marked as incomplete
  • [Packing] Fixed incorrect frame size display behind openings on the packing page
Changes
  • [Help] Updated the conduit size table image in the help dialog
4.32.3 (2023-12-22)
4.32.2 (2023-12-22)
Summary: Improved autopacking preferences and fixed conduit drag-and-drop issues.
Improvements
  • [Packing] Preferred non-solid spares over solids when autopacking, unless configured otherwise
Bug Fixes
  • [Packing] Fixed dragging a CM 30 module with a conduit between different solution types
  • [Packing] Fixed module allocation for GK SPK-S50 with large 2-corner modules
  • [Packing] Fixed a false alert about an invalid packing plan for a specific R40 corner module
4.32.1 (2023-12-13)
Summary: Fixed broken dashboard feeds and improved admin media upload.
Improvements
  • [Packing] Opened up stayplate placement in 2-corner modules for non-GK frames
Bug Fixes
  • [Dashboard] Fixed broken dashboard feeds
4.32.0 (2023-12-11)
Summary: Added transit restoration, improved stayplate visibility, and stayplate placement in 2-corner modules.
New Features
  • [Packing] Improved stayplate visibility on the packing page by letting them extend on both sides
  • [Packing] Added stayplate placement in 2-corner GK modules where other modules can be placed
4.31.0 (2023-12-01)
Summary: Side names for back-to-back solutions, improved CAD drawing generation, and unlocked restricted solutions in Standalone.
New Features
  • [Design] Made it possible to set side names via a back-to-back details section on the Design page
  • [Standalone] Added support for unlocking restricted solutions in the Standalone license
Bug Fixes
  • [Documents] Fixed an issue generating CAD drawings with multiple info drawings of different scales but equally-named blocks
Changes
  • [Documents] Included mirrored back pages and side information when generating drawings for back-to-back solutions
4.30.2 (2023-11-25)
4.30.1 (2023-11-24)
Summary: Improved variant suggestions for single-solutions.
Improvements
  • [Design] When suggesting a variant for a single-solution, preferred non-WOC to avoid creating a hole
4.30.0 (2023-11-21)
Summary: Customized accessories import, better sidebar organization, and improved back-to-back drawings.
New Features
  • [Design] Added a Properties section in the sidebar for settings like custom name and rotation
  • [Design] Improved the appearance of checkboxes marked as problematic during frame configuration
Improvements
  • [Design] Improved the error message when the Standalone license has not been configured
  • [Design] Moved properties like custom name and rotation into a dedicated Properties section
  • [Design] Fixed alignment and size of sleeve and part images in the solution sidebar
  • [Documents] Included mirrored back pages and transit side information for back-to-back solution drawings
Bug Fixes
  • [Design] Fixed the wedge and stayplate material toggle in the Configure frame section
  • [Design] Fixed the visibility and placement of the problem popover in the Configure frame section
4.29.3 (2023-11-16)
Summary: Added document metadata to generated PDFs.
Improvements
  • [Documents] Set document info (Creator, Producer, Author, Title) in generated PDFs
Bug Fixes
  • [Documents] Fixed back-to-back single frames incorrectly doubling installation material in BOM
4.29.2 (2023-11-14)
4.29.1 (2023-11-13)
4.29.0 (2023-10-30)
Summary: Improved module system validation and added WOC flag for singles in config data.
4.28.7 (2023-10-20)
Summary: Updated casting aperture display and improved variant list on the Design page.
Improvements
  • [Design] Updated available sleeve depths when a new variant is selected
  • [Design] Used part name instead of geometry drawing in the variant list
  • [Design] Added a scrollbar inside the Accessories dialog instead of scrolling the whole page
Bug Fixes
  • [Design] Fixed showing 0/0 as recommended casting aperture on the Design and Summary pages
  • [Packing] Fixed an opening showing as incomplete when loading a filled GK transit
4.28.6 (2023-10-02)
4.28.5 (2023-09-28)
4.28.4 (2023-09-26)
4.28.3 (2023-09-20)
Summary: Improved blueprint cache management and project list stats display.
Improvements
  • [UI] Prevented stats in the project list from breaking to a new line on smaller windows
4.28.2 (2023-09-04)
Summary: Improved project list styling, import performance, and solution dialog usability.
Improvements
  • [Import] Improved project import performance by batch-creating locations and transits
  • [Design] Improved the Add solution dialog with aligned images, smaller oversized images, and usage counter tooltips
  • [Export] Omitted wedge and stayplate materials in exports when not relevant
  • [Export] Improved multi-import error messages for stayplate and wedge material issues
  • [Design] Omitted configurations in “Used in project” for solutions excluded from the current user
Bug Fixes
  • [Projects] Fixed styling on the project list so long project names are shown in full
4.28.1 (2023-08-20)
4.28.0 (2023-08-20)
Summary: Improved multi-import with customized parts, better project creation, and McAfee detection.
New Features
  • [Import] Allowed input of customized part numbers during multi-transit import
Improvements
  • [Import] Required a file to be selected when creating a project from backup
  • [Documents] Improved the “switch-to-landscape” page with new graphics, text, and styling
  • [Transits] Showed a special warning when opening a transit with an inaccessible solution
  • [Transits] Detected McAfee Web Gateway interference and alerted the user
Bug Fixes
  • [Projects] Fixed layout problems on the assigned customized products page
  • [Projects] Fixed alignment of content in project cards on the project list
  • [Projects] Disabled the Create project button when clicked to prevent double actions
  • [Projects] Handled file selection and clearing correctly in the create project dialog
  • [Documents] Handled missing certificates when requesting installation instructions
  • [Packing] Removed the “Grid-unadjusted position” error and set positions to adjusted values instead
Changes
  • [Collaborators] Cleared the email field after adding a collaborator in project settings
4.27.1 (2023-08-09)
4.27.0 (2023-07-08)
Summary: Added wedge material to multi-import and fixed project backup errors.
New Features
  • [Import] Allowed specifying wedge material when importing transits and exported it
Bug Fixes
  • [Projects] Fixed a history entry error when backing up a very old project
4.26.5 (2023-06-24)
Summary: Improved spare packing consistency and clipboard copy on the summary page.
Improvements
  • [Packing] Avoided using certain modules for packing spares and ensured consistent spare selection across browsers
  • [UI] Copied the sleeve article number to the clipboard automatically on the summary page
Bug Fixes
  • [Settings] Restored styling for sealing kit preferences on the project settings page
4.26.4 (2023-06-07)
4.26.3 (2023-06-07)
Summary: Added user deletion support for Standalone and improved installation instruction naming.
New Features
  • [Standalone] Added support for deleting users in Standalone
4.26.2 (2023-05-30)
4.26.1 (2023-05-21)
4.26.0 (2023-05-21)
Summary: Improved multi-import sleeve handling, dropped IE11 support, and added forum feeds.
New Features
  • [Dashboard] Showed user forum feeds on the dashboard page
Improvements
  • [Import] Took sleeve into account when choosing a solution during multi-transit import
Changes
  • [Access] Dropped support for Internet Explorer 11 and browsers not supporting ES6
4.25.1 (2023-05-15)
Summary: Fixed multi-import handling of empty frame part numbers.
Bug Fixes
  • [Import] Fixed handling of empty frame part number after sleeve part number in multi-transit import
4.25.0 (2023-05-14)
Summary: Added transit validation for adjusted sleeve properties and fixed incomplete transit detection.
Improvements
  • [Transits] Detected and reported problems when a sleeve doesn’t fit due to adjusted properties
Bug Fixes
  • [Transits] Fixed “Transit Incomplete” for transits with one opening with modules and one covered opening
4.24.14 (2023-05-05)
Summary: Fixed cable validation and improved translation import.
Improvements
  • [Transits] Detected and reported problems when a cable or pipe doesn’t fit due to module range adjustments
Bug Fixes
  • [Packing] Did not clear packing when changing cables for an existing-hole transit
4.24.13 (2023-04-29)
Summary: More lenient material comparison for wedges and stayplates.
Improvements
  • [Packing] Used more lenient material comparison for stayplates and wedges (e.g. “AISI304” matches “AISI 304”)
  • [Transits] Autofocused the transit name field in the Add transit dialog
4.24.12 (2023-04-26)
