TAF0000067 rev.1-optimized
TAF0000067
Roxtec Sleev-it Fire penetration seal
DNV GL class programme DNVGL-CP-0165 – Type approval – Cable and pipe penetrations
DNV GL rules for classification – Ships
DNV GL offshore standards
Approved for use as pipe, Spiro-duct penetration system in class B-15 bulkheads
(see restrictions under application/limitation).
This certificate is recognized by Transport Canada.
Product(s) approved by this certificate is/are accepted for installation on all vessels classed by DNV.
Issued at Høvik on 2021-06-07
This Certificate is valid until 2026-06-06. Digitally Signed By: Øyvind Hoff
DNV local station: Gothenburg FIS Location: DNV Høvik, Norway
on behalf of
Approval Engineer: Helge Bjørnarå
Sverre Olav Bergli
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 1 of 3
Job Id: 262.1-016326-6
Certificate No: TAF0000067
Revision No: 1
“Roxtec Sleev-It Fire penetration seal”
The pipe penetration system is made of collar casing housing different numbers of 60 mm wide layers of Sleev-It
graphite intumescent material (2.5 thick Intumex L or 2 mm thick TRP 345). The collars are fixed by bolt and nuts
through B-class bulkhead made without steel plates on both sides and fixed by steel screws in common B-class
bulkhead with steel plates on both sides.
Pipe collar types:
- “Sleev-It Spiral Collar”, composed of two tubular casing (60 mm or 120 mm long) made of 0.7 mm thick mild steel
welded on both side of a continuous 3 mm thick flange.
- “Sleev-It Fire Collar (MAR)”, composed of 60 mm long tubular casing of 0.7 mm thick stainless steel with one break
in the casing, welded to a splited 3 mm thick flange (3 mm thick), bolted with bolt and nuts through the bulkhead.
For further details see approved drawings listed below.
A – Plastic pipe penetration
Pipe outer Fitting of fire
Intumescent
Pipe material diameter
Material / Layers
[mm] bulkhead
Fire Collar
PE, PB, PPr, uPVC 125
(MAR)
Georg Fischer Multilayer Fire Collar
16 - 32 TRP 345 / 3 1)
Pipe (Pe/Alu) (MAR)
Fire Collar Unexposed
“Valsir” PVC pipe 20
(MAR) side
Fire Collar TRP 345 / 2 +
uPVC 16
(MAR) Sleev-It putty (red)
PPr 16
(MAR) side
  1. for 16 mm pipe, 2 layers may be used.
B – Steel spiral pipe penetration
Intumescent Fire
Material / Layers rating
[mm] bulkhead
Spiral steel pipe
250 Spiral Collar
(Spiro duct)
Spiral steel pipe
100 Spiral Collar Intumex L / 4 Either side B-15
(Spiro duct)
PB = Polybutylene, PPr = Polypropylene, PE = Polyethylene, uPVC = unplasticized polyvinyl chloride, ABS = Acrylonitrile Butadiene
Styrene
Approved for use as pipe, Spiro-ducts penetration system in class B-15 bulkheads.
Certification in accordance with Class Programme DNVGL-CP-0338, September 2018.
Test report No. VTT-S-5026-10 dated 10 February 2011 from VTT, Espoo, Finland.
Statement No. VTT-S-6599-10 dated 27 August 2010 from VTT, Espoo, Finland.
Statement No. VTT-S-1678-11 dated 15 March 2011 from VTT, Espoo, Finland.
Drawing No. SLV 324 DNV dated 20 March 2011 from Sleev-IT Fire System Ltd.
Tested according to IMO FTP Code Part 3 (IMO Res. A. 754(18)) and in compliance with IMO 2010 FTP Code Ch. 8.
The product is to be marked with name of manufacturer, type designation and fire-technical rating.
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 2 of 3
Revision No: 1
Transport Canada Approval
Based on the procedures laid down in the Transport Canada Publication entitled “Approval Procedures for, Life Saving
Equipment and Structural Fire Protection Products (TP 14612)”, DNV confirms that the products listed in this certificate
are in accordance with Transport Canada’s requirements.
certificate and at least every second year. The arrangement is to be in accordance with procedure described in DNVGL-
CP-0338 Section 4.
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 3 of 3
