TAF00000DH
That the Class H Penetration
ROXTEC SEALING SYSTEM WITH MULTIDIAMETER TECHNOLOGY, R-SERIES (CABLE)
DNV offshore standards
Approved as cable penetration in class H-120, H-60 and H-0 steel decks and bulkheads.
Issued at Høvik on 2022-03-08
This Certificate is valid until 2027-03-07.
Digitally Signed By: David-Andersen, Helene
DNV local station: Sweden CMC
Approval Engineer: Lars Erik Hallbeck Parelius
Helene David-Andersen
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-001101-19 | ||
| Certificate No: | TAF00000DH | ||
| Revision No: | 1 |
“Roxtec sealing system with multidiameter technology: R-series (steel)”
consisting of a steel sleeve welded or bolted to a steel decks and bulkheads. The sleeve is fitted with Roxtec R-frame
(standard or EMC) in sizes 50-200. The R-frame is filled with Roxtec (standard or EMC) halogen free RM modules.
For further details, see drawings listed under Type Approval documentation below.
Approved as cable penetration in class H-120, H-60 and H-0400 steel decks and bulkheads for approved ship cables as
specified in the below tables.
General application: Fire against either side*
- In areas with requirements to maximum steel temperature in load bearing constructions, the bulkhead is approved for
restricted application: Fire against insulated side
Table 1: Approved cable penetration in H-120 steel bulkhead
| Sleeve | Sleeve | |
| Type | Size | diameter |
| position | insulation | |
| [mm] | [mm] | [mm] |
| R | 50 - 200 | 62 |
Table 2: Approved cable penetration in H-120 steel deck
| Sleeve | Sleeve | |
| R | 50 - 200 | 88 |
Table 3: Approved cable penetration in H-60 steel bulkhead
| Sleeve | Sleeve | |
| R | 50 - 200 | 88 |
| R | 50 - 200 | 90 |
Table 4: Approved cable penetration in H-60 steel deck
| Sleeve | Sleeve | |
| R | 50 - 200 | 88 |
Table 5: Approved cable penetration in H-0400 steel bulkheads
| Sleeve | Sleeve | |
| R | 70 - 200 | 50 |
- The protective coating is not defined as non-combustible and should not be used in accommodation or in enclosed areas.
Approved for penetration in steel deck and bulkheads limited to a pressure of 4.00 bar water tightness and 2.67 bar gas
tightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.33 bar water tightness and 1.67 bar
gas tightness.
Each product is to be supplied with its manual for installation/application and maintenance.
Test report No. 22N007.12C dated 16 September 1999 from SINTEF, Trondheim, Norway.
Test report No. 22N007.12B dated 16 September 1999 from SINTEF, Trondheim, Norway.
Test report No. PG11087 dated 12 February 2003 from DIFT, Hvidovre, Denmark.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 2 of 3 |
| Revision No: | 1 |
Test report No. PG11088 dated 18 February 2003 from DIFT, Hvidovre, Denmark.
Test report No. P400835 dated 14 April 2004 from SP, Borås, Sweden.
Test report No. RS-19/B-036/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-037/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. PGB10120A dated 17 December 2021 from DBI, Hvidovre, Denmark.
Water tightness/gas tightness:
Test report No. MLM 010238 dated 30 August 2001 from DNV Malmö.
Test report No. MLM 020408 dated 3 June 2001 from DNV Malmö.
Test report No. 40007647-1 dated 13 December 2011 from DNV Malmö.
Drawing No. S1572496 Rev. A dated 26 October 2021 from manufacturer.
Drawing No. S1572485 Rev. B dated 18 February 2022 from manufacturer.
Drawing No. S1572516 Rev. B dated 18 February 2022 from manufacturer.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and with the hydrocarbon time-temperature curve
specified in ISO 834-3.
CP-0338 Section 4.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 3 of 3 |
