TAF00000DW
| TYPE APPROVAL CERTIFICATE | Revision No: |
| 2 |
That the Class H Penetration
ROXTEC SEALING SYSTEM WITH MULTIDIAMETER TECHNOLOGY, S-& EMC S-SERIES FRAMES
DNV offshore standards
Approved as penetration in
-class H-0/H-60/H-120 decks/bulkheads for approved ship cables
-class H60/H120 decks/bulkheads for steel pipes
Issued at Høvik on 2022-11-08
| This Certificate is valid until 2028-06-28. | Digitally Signed By: Permoda, Jowita |
DNV local unit: Malmö
Signing Date: 10.11.2022
Approval Engineer: Timo Linn
Jowita Permoda
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-001101-21 | ||
| Certificate No: | TAF00000DW | ||
| Revision No: | 2 |
“Roxtec Sealing System with Multidiameter Technology, S- & EMC S- Series”
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SR, SK, SRC r20, SRC r40 and SBTB) in sizes 1-8, and
combinations thereof, bolted or welded to a steel section. The S frame is filled with Roxtec (standard or EMC, PE, ES,
BG, BGB) halogen free RM modules. Assembled with Roxtec Wedge kit or Roxtec EMC Wedge kit.
Additional Place of Production:
Roxtec Sealing System (Shanghai) Co,.Ltd Lingang Branch
Ground Floor A, No.875 QiuXin Road Zhongqilian (Lingang) Global Auto Parts Innovation Center, Shanghai, China.
Approved as cable penetration in
- class H-0/H-60/H-120 decks/bulkheads
for approved ship cables including metal cables (CLX/TECK) up to OD 103 mm. (Ref. approved H-class as stated in the
drawings mentioned under Type Approval documentation below)
Approved as pipe penetrations in
- class H-60/H-120 decks and bulkheads
for steel pipes in sizes OD 14mm to OD 51 mm. (Ref. approved H-class as stated in the drawings mentioned under
Deck or bulkhead to be insulated according to classification covering the edge of the steel frame. The penetrations are
to be insulated in accordance with approved and stamped drawings listed under Type Approval documentation.
Cable and pipe penetrations approved for water- and gas tightness in steel bulkheads or decks, limited to a pressure of
4 bar water tightness and 2,67 bar gas tightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3,33 bar water tightness and 1,67 bar
gas tightness.
When pipe penetrations is requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships
(SPS), the pipe penetration system has to comply with the requirements given in SOLAS (2009) Ch. II-1 Reg. 13.2.3 c.f.
IMO Res. MSC.429(98) Reg. 13.2.3.4. Pipe penetrations passing through watertight bulkheads are subject for separate
examination.
When used in High Speed and Light Crafts the penetrations are subject for approval in each case.
Each product is to be supplied with its manual for installation/application and maintenance. The manual shall include the
relevant drawings listed under type approval documentation.
Test Report No (Cables):
| - | Test report No. 250000.20/90.313, dated 9 November 1990 from Sintef, Norway. |
| - | Test report No. 250000.47/94.062-A dated 20 June 1994 from Sintef, Norway. |
| - | Test report No. 10027 from Roxtec International AB, approved by DNV 20 November 2000 (SRCr20 and SRCr40 |
| frames). | |
| - | Test report No. 846007.06 dated 19 September 1997 from SINTEF Energy (deck). |
| - | Test report No. P400834 dated 31 March 2004 from SP, Sweden (S frame CLX cable). |
| - | Test report No. PX07235 dated 15 December 2010 from SP, Sweden (S frame CLX cable). |
| - | Test report No. P703775 dated 7 December 2007 from SP, Sweden (H-60/90 Steel Bulkhead). |
| - | Test report PG11199 Serial number 9138 dated 4 July 2003 from DIFT, Denmark (H-120 Steel Bulkhead) |
| - | Test report No. 22N007.12C dated 16 September 1999 from SINTEF, Norway (H-0/400 Steel Bulkhead) |
| - | Test report No. PGA10024 dated 21 December 2011 and PGA1025 dated 22 December 2011(Reference tests for |
| BG and BGB modules) | |
| - | Test report No. 4P02192 dated 2014-06-30 from SP (H0 steel deck, 11x multi-cable transits) |
| - | Test report No. 6P02536 dated 2016-07-12 from SP (H0 steel deck, 6x cable penetration seals) |
Test Report No (Steel pipes):
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 2 of 3 |
| Revision No: | 2 |
| - | Test report No. P601740 (H-60/H-120 deck) dated 28 June 2006 from SP Sweden (Steel pipe) |
| - | Test report No. 10528 (H-120 bulkhead) dated 18 April 2007 from Roxtec International AB, witnessed by DNV |
(Steel pipe).
Test Report No (Water and gas tightness):
| - | Test report No. MLM 020133 dated 2002-02-26, |
| - | Test report No. MLM 020400 and |
| - | Test report No. MLM 020401 dated 2002-03-25, |
| - | Test report No. MLM 050410 dated 2005-05-20, |
| - | Test report No. MLM 020106 dated 2001-12-19, |
| - | Test report No. MLM 020408 dated 2002-06-03 |
| - | Test report No. SKM 04-4088 dated 2004-06-16 from DNV Malmö. |
Drawings (Cable penetrations):
| - | Class H-60, H-120 Deck: | Drawing S1008896 |
| - | Class H-0 to H-120 Bulkhead: | Drawing S1019867 Rev. B. |
| - | Class H-60 Bulkhead: | Drawing S1022732, Rev. B (S frame CLX cable). |
| - | Class H-0 Steel deck: | Drawing S1514453 Rev C |
Drawings (Steel pipe penetrations):
| - | Class H-60 Deck/Bulkhead: | Drawing S1009999 |
| - | Class H-120 Deck/Bulkhead: | Drawing S1010000 |
Tested according to IMO FTP Code Part 3 (IMO Res. A.754 (18)) and with the hydrocarbon time-temperature curve
specified in ISO 834-3.
Pressure tests with water and Helium according to Type Approval Programme 8-471.19-1 dated May 2001.
DNV surveyor is to be given permission to perform Periodical Assessments at any time during the validity of this
CP-0338 Section 4.
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 3 of 3 |
