TAF00000HK-revision9-optimized
TAF00000HK
TYPE APPROVAL CERTIFICATE Revision No:
9
Roxtec sealing system: Sleev-it steel divisions
DNV statutory interpretations DNV-SI-0364 – SOLAS interpretations, Edition July 2021
DNV rules for classification – Ships
DNV offshore standards
Approved for use as a plastic pipe penetration system in class A-0 and A-60 steel bulkheads and decks.
Products approved by this certificate are accepted for installation on all vessels classed by DNV.
Issued at Høvik on 2023-04-11
This Certificate is valid until 2027-04-26. Digitally Signed By: Permoda, Jowita
DNV local unit: Malmö
DNV Gdynia, Poland
Approval Engineer: Marcin Tobiasz
Jowita Permoda
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 1 of 6
Job Id: 262.1-016326-11
Certificate No: TAF00000HK
Revision No: 9
“Roxtec sealing system: Sleev-it steel divisions”
consist of a steel collar casing lined with intumescent material on the inside and a flange. It is available in FC MAR (fire
penetration seal) and WT MAR (Fire/Watertight penetration seal) versions depending on application.
The Sleev-it is installed onto a steel division by welding (FC/WT MAR) or bolting (FC MAR) depending on version.
Marine graded sealant is applied during the installation to achieve a cold smoke seal.
Approved for use as a plastic pipe penetration system in class A-60 steel bulkheads and decks according to tables
below.
Approved for use in class A-0, A-15 and A-30 when the penetration system is insulated as A-60 and in addition the
division is to be insulated with A-60 insulation at least 200 mm around the penetration.
Other applications are subject to case-by-case approval.
Sleev-it size Pipe Pipe diameter Seal
Insulation drawing
(OD) [mm] material (OD) [mm] position
28 - 286 ABS 16 - 225 Uninsulated side
28 ABS 16 Insulated side
28 – 198 PB 16 - 160 Either
28 – 286 PE 16 - 225 Either
28 – 240 PP 16 - 200 Either
32 - 248 PVC 12 - 200 Either
207 PVDF 169 Either
102 - 125 Beverage multipipe 75 - 100 Either
28 - 48 PE/ALU/PE 16 - 32 Either
48 - 85 PE/ALU/PE 33 - 63 Either
248 - 350 PVC 201 - 271 Insulated side
286 - 391 PE 226 - 315 Insulated side
102 - 391 Pre-insulated pipe 75 - 315 Uninsulated side
Multi pipe1)
36 - 102 20 - 41 Either S1508739 Rev. A
PVC, PP
1) Penetration type FC MAR-75M
Insulation drawing
28 - 286 PE 25 - 225 Either
36 - 143 PP 20 - 110 Either
28 - 158 PB 25 - 125 Either
28 - 198 PVC 25 - 160 Either
69 - 213 PVDF 48 - 166 Either
28 - 85 PE/ALU/PE 16 - 63 Either
Multi pipe1)
36 - 69 22 - 50 Either S1508739 Rev. A 1
PP, PVC
36 - 69 PE/ALU/PE, PVC, PP 22 - 50 Either
198 - 400 PVC >160 - 321 Either
| Form code: TA 251 | Revision: 2022-12 | www.dnv.com | Page 2 of 6 |
| Job Id: | 262.1-016326-11 |
| Certificate No: | TAF00000HK |
| Revision No: | 9 |
| Sleev-it size | Pipe | Pipe diameter | Seal |
Insulation drawing
28 - 286 ABS 16 - 225 Underside
28 ABS 16 Either
28 - 41 PB 16 - 24 Underside
158 - 248 PB >125 - 200 Underside
28 - 41 PE 16 - 24 Underside
286 - 400 PE >225 - 320 Underside
28 - 36 PP 16 - 19 Underside
143 - 400 PP >110 - 320 Underside
28 - 41 PVC 16 - 24 Underside
102 - 391 Pre-insulated pipe 75 - 315 Underside
69 - 143 PP 50 - 110 Underside
  1. Penetration type FC MAR-75M
Table 3: Approved pipe penetration in A-0 steel bulkhead
Insulation drawing
28 - 198 PB 15 - 160 Insulated side
28 - 286 PE 16 - 225 Either
286 - 391 PE > 225 - 315 Either
36 - 207 PP 20 - 169 Either
36 PP 20 Either
28 - 56 PP 16 - 39 Either
207 - 248 PP 170 - 200 Either
28 - 198 PVC 16 - 160 Either
198 - 248 PVC > 160 - 200 Either
248 - 350 PVC > 200 - 271 Insulated side
102 - 391 Pre-insulated pipe 75 - 315 Uninsulated side S1552430 Rev. A
  1. Georg Fischer COOL-FIT 2.0 or equivalent
Table 4: Approved pipe penetration in A-0 steel deck
Insulation drawing
28 ABS 16 Either
28 - 69 PVC 16 - 50 Underside
| Form code: TA 251 | Revision: 2022-12 | www.dnv.com | Page 3 of 6 |
| Revision No: | 9 |
Insulation drawing
28 - 69 PVC 16 - 50 Either
85 PVC 63 Topside
69 - 400 PVC >50 - 321 Either
41 - 158 PB 25 - 125 Either
41 - 158 PE 25 - 225 Either
102 - 391 Pre-insulated pipe1) 75 - 315 Underside
Pipe reference list
ABS Acrylonitrile Butadiene Styrene
PB Polybutylene
PE Polyethylene
PP Polypropylene (including PP, PPr and three-layer PP)
PVC Polyvinyl Chloride (including PVC-C and PVC-U)
PVDF Polyvinylidene Fluoride
Composite pipes made of outer/inner PE layer and intermediate
PE/ALU/PE
Al thin-walled pipe.
Beverage multipipe Bundle of plastic pipes covered with thermal insulation
Pre-insulated pipe Thermoplastic pipe with integrated thermal insulation
Cold service piping insulated with Armaflex rubber insulation layer is to be locally interrupted through the penetration
system.
Standard design is one pipe is routed through each Roxtec Sleev-it penetration. For multi-pipe application, the
penetration type “SLV75M and FC-MAR75M” shall be used.
For applications where water and or gas tightness is requested Sleev-it type WT is to be used exclusively. This type is
approved for application in steel bulkheads or decks limited to a pressure of 2,33 bar water tightness and 0,67 bar gas
tightness.
The pipe penetrations are not approved for use in watertight bulkheads on passenger ships and special purpose ships
(SPS).
Installation instructions:
ASS2012012001201 D Installation instruction Roxtec Sleev-it – Waterproof penetration seal
ASS2012012001301 D Installation instruction Roxtec Sleev-it – Fire penetration seal
Bulkhead Class A-60:
Test report No. 164476A dated 2007-07-23 from Bodycote Warringtonfire, UK
Test report No. 164476B dated 2007-06-26 from Bodycote Warringtonfire, UK
Test report No. 180251A dated 2009-02-16 from Bodycote Warringtonfire, UK
Test report No. 177105A dated 2008-11-04 from Bodycote Warringtonfire, UK
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 4 of 6
Revision No: 9
Test report No. 183387A dated 2009-06-12 from Exova Warringtonfire, UK
Test report No. 309855A dated 2011-10-05 from Exova Warringtonfire, UK
Test report No. 303585A dated 2011-02-17 from Exova Warringtonfire, UK
Test report No. 198004A dated 2010-12-07 from Exova Warringtonfire, UK
Test report No. 303584A dated 2011-04-07 from Exova Warringtonfire, UK
Test report No. 316943 dated 2012-04-26 from Exova Warringtonfire, UK
Test report No. 314670 dated 2012-06-25 from Exova Warringtonfire, UK
Test report No. 324083 dated 2013-04-24 from Exova Warringtonfire, UK
Test report No. 30717A dated 2011-06-17 from Exova Warringtonfire, UK
Test report No. RS-18/B-264/E dated 2018-09-14 from CTO S.A, Poland
Test report No. RS-19/B-424/E dated 2019-11-27 from CTO S.A, Poland
Test report No. RS-21/B-241/E dated 2021-06-30 from CTO S.A, Poland
Test report No. PGB10030A dated 2020-07-16 from DBI, Denmark
Test report No. 881/07/A/NP/R 102 dated 2007-03-21 from DGA
Test report No. 5P08394 dated 2016-03-02 from SP, Sweden
Test report No. PGB10167A dated 2022-03-03 from DBI, Denmark
Deck Class A-60:
Test report No. 170080B dated 2008-01-21 from Bodycote Warringtonfire, UK
Test report No. 175486A dated 2008-08-11 from Bodycote Warringtonfire, UK
Test report No. 170080A dated 2008-01-21 from Bodycote Warringtonfire, UK
Test report No. 175486B dated 2008-08-11 from Bodycote Warringtonfire, UK
Test report No. 190890A_2 dated 2010-03-02 from Exova Warringtonfire, UK
Test report No. 309638A dated 2011-08-03 from Exova Warringtonfire, UK
Test report No. 325332 dated 2013-01-13 from Exova Warringtonfire, UK
Test report No. 188626 dated 2009-12-22 from Exova Warringtonfire, UK
Test report No. 314669 dated 2012-04-26 from Exova Warringtonfire, UK
Test report No. 320402A dated 2012-10-29 from Exova Warringtonfire, UK
Test report No. 329449 dated 2013-08-13 from Exova Warringtonfire, UK
Test report No. 334429 dated 2013-12-17 from Exova Warringtonfire, UK
Test report No. RS-18/B-265/E dated 2018-09-17 from CTO, Poland
Test report No. PGB10032A dated 2020-07-01 from DBI, Denmark
Test report No. PGB10047A dated 2020-11-30 from DBI, Denmark
Test report No. PGA10871A dated 2018-01-18 from DBI, Denmark
Test report No. 6P02249 dated 2016-05-17 from SP, Sweden
Test report No. 6P10022 dated 2017-03-07 from SP, Sweden
Test report No. 878/07/A/NP/R 102 dated 2007-03-28 from DGA
Test report No. PGA11611A dated 2020-01-11 from DBI, Denmark
Test report No. RS-22/B-153/E dated 2022-05-04 from CTO S.A, Poland
Test report No. PGB10172A dated 2022-06-17 from DBI, Denmark
Bulkhead Class A-0
Test report No. 337717 dated 2014-05-13 from Exova Warringtonfire, UK
Test report No. 307171/A dated 2011-05-26 from Exova Warringtonfire, UK
Test report No. 8P07092 Rev.1 dated 2020-01-16 from SP, Sweden
Test report No. RS-19/B-423/E dated 2019-11-19 from CTO, Poland
Test report No. RS-20/B-081/E dated 2020-03-31 from CTO, Poland
Deck Class A-0
Test report No. PGA11388A dated 2019-08-14 from DBI, Denmark
Test report No. PGB10110A dated 2021-04-27 from DBI, Denmark
Test report No. 8P07092, Rev.1 dated 2020-01-16 from RISE, Sweden
Miscellaneous documents:
Excel spread sheet “Test Review-Sleeve-it”, 2020
Indicative test No. 189958 dated 9 February 2010 (EDPM rubber seal)
Assessment No. 184391/A (Alu deck), 17 December 2009
(Sleev-it WT-MAR, type A)
Drawing 320420A,29 October 2012 and Assessment report No. 336024, 18 December 2013
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 5 of 6
Revision No: 9
Water and gas tightness reports
Survey report LDN-08-045 dated 2008-05-09 from DNV London
Test witness certificate no. SOU 0901586/1 dated 2010-01-08 from Lloyd’s Register
Drawing No. S1026329, Rev. H dated 2016-10-11
Drawing No. S1026339, Rev. E dated 2016-11-15
Drawing No. S1036341, Rev. A dated 2013-11-15
Drawing No. SLV 342A dated 2010-02-02
Drawing No. S1508739 Rev. A dated 2015-12-17
Drawing No. S1508747 Rev. A dated 2015-12-18
Drawing No. S1508746 Rev. A dated 2015-12-18
Drawing No. S1036417 Rev. A dated 2013-11-19
Drawing No. S1552357 Rev A dated 2020-02-12
Drawing No. S1552408 Rev A dated 2020-02-13
Drawing No. S1552430 Rev A dated 2020-02-13
Drawing No. S1508740 Rev. A dated 2015-12-17
Drawing No. S1508742 Rev. A dated 2015-12-18
Drawing No. S1508750 Rev. A dated 2015-12-18
Drawing No. S1508751 Rev. A dated 2015-12-18
Drawing No. S1553615 Rev. A dated 2020-03-13
Drawing No. S1516429 Rev. A dated 2016-10-17
Drawing No. S1585224 Rev. A dated 2022-11-08
Drawing No. S1586443 Rev. A dated 2022-11-29
Tested in accordance with IMO 2010 FTP Code Part 3.
certificate and at least every second year. The arrangement is to be in accordance with procedure described in Class
Programme DNV-CP-0338, Section 4.
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 6 of 6
