TAF00001E2-revision1-optimized
TAF00001E2
TYPE APPROVAL CERTIFICATE Revision No:
BUSBAR PENETRATION SYSTEM FOR CLASS A-60 and A-0 BULKHEADS AND DECKS
Roxtec GK Firestop Sealing Kit (GK FS SK) size 127-244
DNV statutory interpretations DNV-SI-0364 – SOLAS interpretations, Edition July 2021
DNV rules for classification – Ships
DNV offshore standards
Approved for use as a busbar penetration system for Schneider Electric Industries S.A.S. type KTA 1000-1600,
KSA 250-1000 and KNA 63-160 in class A-60 and A-0 steel bulkheads and decks.
Product(s) approved by this certificate is/are accepted for installation on all vessels classed by DNV.
Issued at Hamburg on 2022-03-21
This Certificate is valid until 2027-03-20. Digitally Signed By: Schaarmann, Arne
DNV local station: Sweden CMC
Signing Date: 2022-03-22
Approval Engineer: Carsten Hunsalz
Arne Schaarmann
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 1 of 3
Job Id: 262.1-033331-3
Certificate No: TAF00001E2
Revision No: 1
A-60 and A-0 steel bulkhead and deck penetration for “Schneider Electric Industries S.A.S.” busbar system type
KTA 1000-1600, KSA 250-1000 and KNA 63-160.
“GK FS SK sealing kit“ consisting of a fiberglass cloth with built in heat activated intumescent material to be wrapped
around busbar and fitted into circular or steel pipe sleeves. Folded back on each side with ends sealed off to create a
cold smoke tight seal and secured by metal cable ties.
The installation shall be made in symmetrically welded or bolted pipe sleeves.
Installation details according drawing Roxtec No. S1573045 Rev.A and S1572947 Rev.A
Table 1: Approved penetrations in A60 Bulkhead.
Sealing kits for Pipe sleeve depth Type of penetration Insulation Arrangement
round sleeves Min – Max [mm] drawing No. No.
GK FS SK 105 - 205 KTA1000 - KTA1600 S1572947 Rev. A 1
127-244 KSA250 - KSA1000
KNA63 - KNA160
GK FS SK 105 - 205 No service S1572947 Rev. A 2
127-244
Table 2: Approved penetrations in A60 Deck.
GK FS SK 105 - 205 KTA1000 - KTA1600 S1572947 Rev. A 3
KNA63 - KNA160
GK FS SK 105 - 205 No service S1572947 Rev. A 4
127-244
Table 3: Approved penetrations in A0 Bulkhead.
GK FS SK 105 - 205 KTA1000 - KTA1600 S1573045 Rev. A 1
KNA63 - KNA160
GK FS SK 105 - 205 No service S1573045 Rev. A 2
127-244
Table 4: Approved penetrations in A0 Deck.
GK FS SK 105 - 205 KTA1000 - KTA1600 S1573045 Rev. A 3
KNA63 - KNA160
GK FS SK 105 - 205 No service S1573045 Rev. A 4
127-244
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 2 of 3
Revision No: 1
Only the penetration system is covered by this type approval certificate. The busbars itself shall hold a valid Type
Approval Certificate.
Approved for Schneider busbar system KTA 1000-1600, KSA 250-1000 and KNA 63-160 in class A-60 and A-0 steel
bulkheads and decks. Other applications are subject to case-by-case approval. Approved for use in class A-15 and A-30
when the penetration system is insulated as A-60. In addition the division is to be insulated with
A-60 insulation at least 200 mm around the penetration.
Only one busbar system per GK FS SK sleeve is approved, the busbar system shall be arranged in the center of the
sleeve.
The systems must not be installed in bulkheads and decks if water- and gas- tightness is required.
The busbar trunking systems KTA, KSA and KNA shall be constructed in that way, that no smoke can pass through
them, at the locations of the bulkhead or deck penetrations.
Each product is to be supplied with its manual for installation, use and maintenance.
Test Reports A-60 Fire Class:
No. RS-20/B-083/E, dated 2020-04-20; No. PGA11611A, dated 2020-01-11
RS-21/B-242/E, dated 2021-06-30; RS-21/B-445/E, dated 2021-10-07; RS-19/B-255/E, dated 2019-08-20;
PGB10113A, dated 2021-07-23; PGB10118A, dated 2021-11-15; RS-19/B-225/E, dated 2019-08-01;
RS-19/B-256/E, dated 2019-08-20;
Test Reports A-0 Fire Class:
No. RS-19/B-423/E, dated 2019-11-19; No. PGA11610A, dated 2020-01-10
RS-21/B-240/E, dated 2021-06-30; RS-20/B-081/E, dated 2020-03-31; PGB10110A, dated 2021-04-27;
PGB10119A, dated 2021-11-15; RS-21/B-517/E, dated 2021-12-15;
Test Reports Cold Smoke:
Roxtec No. 29092016-01, dated 2016-09-29; No. 22032017-01, dated 2017-03-22; No. 14122016-01,
dated 2016-12-14; No. 25042017-01, dated 2017-04-25
Installation Drawing:
Roxtec No. S1573045 Rev.A and S1572947 Rev.A dated 2021-12-01
Fire Test acc. 2010 FTP Code, Annex 1: Part 3, IMO Resolution MSC.307(88)
The product or packing is to be marked with name of manufacturer, type designation and fire-technical
rating.
DNV’s surveyor is to be given permission to perform Periodical Assessments at any time during the
validity of this certificate and at least every second year. The arrangement is to be in accordance with
procedure described in DNV-CP-0338 Section 4.
Form code: TA 251 Revision: 2021-03 www.dnv.com Page 3 of 3
