TAF00001NK
That the Class H Penetration
ROXTEC SEALING SYSTEM WITH MULTIDIAMETER TECHNOLOGY, R-SERIES (PIPE)
DNV offshore standards
Approved as pipe penetration in class H-120 and H-60 steel decks and bulkheads.
Issued at Høvik on 2022-03-08
This Certificate is valid until 2027-03-07.
Digitally Signed By: David-Andersen, Helene
DNV local station: Sweden CMC
Approval Engineer: Lars Erik Hallbeck Parelius
Helene David-Andersen
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-001101-19 | ||
| Certificate No: | TAF00001NK |
“Roxtec sealing system with multidiameter technology: R-series (steel)”
consisting of a steel sleeve welded or bolted to a steel decks and bulkheads. The sleeve is fitted with Roxtec R-frame
(standard or EMC) in sizes 50-200. The R-frame is filled with Roxtec (standard or EMC) halogen free RM modules.
For further details, see drawings listed under Type Approval documentation below.
Approved as pipe penetration in class H-120 and H-60 steel decks and bulkheads as specified in the below tables.
Restricted application: Fire from insulated side only
Table 1: Approved pipe penetration in H-120 steel bulkhead
| Pipe | Sleeve | Sleeve |
| Type | Size | diameter |
| material | position | insulation |
| (OD) [mm] | [mm] | [mm] |
| R | 50 | Steel |
| R | 50 - 200 | Steel |
Table 2: Approved pipe penetration in H-120 steel deck
| R | 70 | Steel |
| R | 70 - 200 | Steel |
Table 3: Approved pipe penetration in H-60 steel bulkhead
| R | 50 - 70 | Steel |
Table 4: Approved pipe penetration in H-60 steel deck
Approved for penetration in steel deck and bulkheads limited to a pressure of 4.00 bar water tightness and 2.67 bar gas
tightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.33 bar water tightness and 1.67 bar
gas tightness.
Each product is to be supplied with its manual for installation/application and maintenance.
Test report No. P601740 dated 28 June 2006 from SP, Borås, Sweden.
Test report No. P601739 dated 28 June 2006 from SP, Borås, Sweden.
Test report No. RS-19/B-036/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-037/E dated 21 March 2019 from CTO, Gdansk, Poland.
Water tightness/gas tightness:
Test report No. MLM 020408 dated 3 June 2001 from DNV Malmö.
Test report No. MLM 010238 dated 30 August 2001 from DNV Malmö.
Test report No. 40007647-1 dated 13 December 2011 from DNV Malmö.
Drawing No. S1572462 Rev. A dated 1 November 2021 from manufacturer.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 2 of 3 |
Drawing No. S1572472 Rev. A dated 1 November 2021 from manufacturer.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and with the hydrocarbon time-temperature curve
specified in ISO 834-3.
CP-0338 Section 4.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 3 of 3 |
