1.24.3 - 2024-05-28
- Added a “Not set” option in the global filter for geolocations
- Improved the transit inspection log, making it much easier to read
- Fixed editing and focusing issues related to geolocations
- Fixed an issue where buttons would become jumbled up when decreasing the size to the geolocation information past a point
1.24.2 - 2024-05-17
- Added Front and Back tabs under Openings and tags for Back to Back solutions
1.24.1 - 2024-05-15
- Added new access profile for Surface treatment
- Fixed an issue that would generate empty insulation log entries
- Fixed Floor plan notifications not displaying correctly
1.24.0 - 2024-05-08
- Updated the access log to only display product type if there is a non default value
- Fixed an issue where the delete transit dialogue would reappear after successfully deleting a transit
- Fixed an issue where the latest changed date would display incorrectly
- Changed an error message that appeared when using a direct link to a transit that changed floor plans after the link was generated. Now a descriptive message will be shown instead
- Fixed an issue where location changes of a transit would not correctly update in the transit log
- Improved the visuals for multi-edit dialogues
- Moved the demand specification comment location to make it visually clear what the comment is about
- Updated translations for multi-edit dropdowns
- Added warnings when invalid emails are specified under collaborators
- Added a separate section for Safety and Compliance under transit information
- Added a new button for Safety demands when using multi-edit
- Moved all product related information to the same section in the transit information
1.23.1 - 2024-04-25
- Fixed unresponsive save button when editing custom data fields
- Improved the visual design of the status dialogue
- Updated the access log to include product types when granting access to assets
- Updated text colors for plots on floor plans to make them uniform with the rest of the application
- Fixed an issue where searching for users returned duplicate results
- Fixed an issue where components would load earlier then intended
- Pressing enter while typing in the customer administrator email field should no longer reload the page
1.23.0 - 2024-04-18
- Replaced the change status dialogue
- Moved Custom data fields to its own tab
- When a transit gets deleted, it will close open windows related to it
- Changed the color of text in status bubbles. These should now match through the application
- Removed sorting by last modified transit status date, as this option was confusing
- Fixed an issue where the edit asset dialogue would not update correctly
- Added a transit insulation status dialogue
- Added padding to tags
- Disabled geolocation selection when creating an item from the geolocations menu
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
- Updated the pricing model for both Transit Build & Operate. Both applications now share the same pricing model.
- Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
