Transit Build - New version 1.25.0 [2024-08-20]
1.25.0 - 2024-08-20
1.24.9 - 2024-07-04
1.24.8 - 2024-07-02
1.24.6 - 2024-06-11
1.24.5 - 2024-06-11
1.24.4 - 2024-06-10
1.24.3 - 2024-05-28
1.24.2 - 2024-05-17
1.24.1 - 2024-05-15
1.24.0 - 2024-05-08
1.23.1 - 2024-04-25
1.23.0 - 2024-04-18
  • Added padding to tags
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
  • Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
