Transit Build - New version 1.25.13 [2024-12-09]
1.25.13 - 2024-12-09
  • Fixed the descriptive text for collaborators when removing a product type
  • Improved the close button when downloading reports. It should now better indicate when it can be pressed
1.25.12 - 2024-11-29
  • Reduced the opacity when dragging items on the floor plan. This will make the underlying map visible and allow for more accurate placement
  • Fixed an issue where some PDF documents could not be uploaded
1.25.11 - 2024-11-22
  • Fixed an issue where it was not possible to create a customer account without having a company name set. The user name will be used if this is missing
  • Removed the “add multiple transits” button when editing a transit.
1.25.9 - 2024-11-19
1.25.8 - 2024-11-18
1.25.7 - 2024-11-12
1.25.6 - 2024-11-11
1.25.5 - 2024-11-04
1.25.4 - 2024-10-24
1.25.3 - 2024-10-15
1.25.2 - 2024-09-17
1.25.1 - 2024-09-10
1.25.0 - 2024-08-20
1.24.9 - 2024-07-04
1.24.8 - 2024-07-02
1.24.6 - 2024-06-11
1.24.5 - 2024-06-11
1.24.4 - 2024-06-10
1.24.3 - 2024-05-28
1.24.2 - 2024-05-17
1.24.1 - 2024-05-15
1.24.0 - 2024-05-08
1.23.1 - 2024-04-25
1.23.0 - 2024-04-18
  • Added padding to tags
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
  • Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
