1.25.2 - 2024-09-17
- Added autofocus to the first available text field when opening applicable dialogues
- Fixed an issue where geolocations would not display
- Fixed a camera movement bug that would occur when using certain camera actions in a specific order
- Fixed a broken translation related to collaborators
1.25.1 - 2024-09-10
- Changed the “Edit and Add customer” dialogue to the new UI standard
- Updated the “Current user” dialogues appearance and improved it for mobile devices
- Changed the “Add and Edit location” dialogue to the new UI standard
- Updated the reports to correctly reflect which product type that is selected
- Moved the cancel button under account options to be in line with the UI standard
- Improved the UI of the add / edit asset dialogue
- Improved the transit dialogue for mobile devices
- Improved the dashboard to no longer truncate asset names on mobile devices
- Updated the help messages for item placement
- Fixed an issue where tags would appear outside of their designated area
- Improved the accuracy of the customer search function
- Added a message in the reports when there is no status set
- Improved the reference location function, it should now be possible to remove a reference location independent of the primary location
- Fixed an issue where long words would become truncated and could cause the close button to not be visible
- Added a custom data fields button to the manage asset dropdown menu
- Fixed an issue where selecting a reference location would highlight the primary location
- Improved the animations when selecting items on a floor plan
- Added functionality to allow primary and reference locations to exist on the same floor plan
1.25.0 - 2024-08-20
- Added the option to manage collaborators from the asset list
- Made the location comment visible for other product types under the information tab
- Added information about which asset and product type is selected when managing collaborators, since this can now be done from multiple locations
- Changed the cursor to become a pointer when hovering over certain objects, to make it clear their clickable
- Disabled the download inspection reports function for inspections in a planned state
- Updated the warning that filter is active when downloading reports. This now includes a warning that the active selection also impacts this
- Improved the log entries when moving a transit between floor plans
- Fixed an issue where editing a multi-imported transit would generate incorrect log messages
- Added the option to filter on custom data fields that have not been filled in
- Added the option to filter on Product that has not been specified
- Added the option to filter on transits that have no tags set
- Removed quarters from relative timestamps, replaced with months
- Fixed an issue where the text for product types on hydraulic hoses would overlap other text
- Updated the legend in the excel reports to only include the statuses present in the report
- Changed the add inspection, edit inspection and get report dialogues, they will now generate as a drawer
- Fixed an issue where the latest modifying activity would not update correctly for all assets in an asset group
1.24.9 - 2024-07-04
- Added a notification when trying to download a report with a filter active. That this is active for the report
- Updated Asset admin notification emails to only be sent when a new administrator is added
- The select all button will no longer display in the collaborators list if its empty
- Added a filter option to display transits that have not yet been placed on a floor plan
- Fixed an issue with the manage collaborators list where information would disappear while scrolling
- Fixed an issue where certain PDF files were not recognized correctly when uploading them
1.24.8 - 2024-07-02
- When expanding menu options that open outside of the current view, it will now automatically scroll to display the information
- Updated the add document error message that occurs when trying to upload an unsupported file type. The message should now reflect what type of file is being uploaded
- Fixed an issue where an empty transit log entry was generated when setting the same demand specifications
- The select all button will no longer display if there are no items
- When changing a custom data field, the field label now displays while editing.
- The upload documents text is no longer displayed for users that do not have access to upload documents.
1.24.6 - 2024-06-11
- Updated “item” under manage item drop downs to now reflect the selected product type
- Allowed expired products to be selectable on transits that already contain them
- Updated the Download reports window to now reflect which product type is selected
1.24.5 - 2024-06-11
- Any change to an inspection will now count towards its activity
- Updated the navbars so the text is no longer selectable
1.24.4 - 2024-06-10
- Added a warning when decreasing the size of a transit to a smaller size then its original
- Fixed a sensitive information warning that would display incorrectly on lower resolutions
- The transits displayed under geolocations are now split into pages with the options 25, 50 or 100 items per page
- Fixed an issue where the transit drawer would display incorrectly on mobile devices
- Fixed an issue where the reports would contain statuses from all products. It will now only contain statuses for the selected product
- Improved the error message that is displayed when trying to view a deleted transit
- Updated the “Add item” and “Add multiple items” buttons to now reflect the selected product type
- It is no longer possible to change tabs/sides of a BTB transit while there are pending changes. Added a notification to make this clear
- Added a section under add/edit item for custom data fields
- Updated BTB transits so the selected status no longer carries over when switching tabs
- Fixed margins on the product tab
1.24.3 - 2024-05-28
- Added a “Not set” option in the global filter for geolocations
- Improved the transit inspection log, making it much easier to read
- Fixed editing and focusing issues related to geolocations
- Fixed an issue where buttons would become jumbled up when decreasing the size to the geolocation information past a point
1.24.2 - 2024-05-17
- Added Front and Back tabs under Openings and tags for Back to Back solutions
1.24.1 - 2024-05-15
- Added new access profile for Surface treatment
- Fixed an issue that would generate empty insulation log entries
- Fixed Floor plan notifications not displaying correctly
1.24.0 - 2024-05-08
- Updated the access log to only display product type if there is a non default value
- Fixed an issue where the delete transit dialogue would reappear after successfully deleting a transit
- Fixed an issue where the latest changed date would display incorrectly
- Changed an error message that appeared when using a direct link to a transit that changed floor plans after the link was generated. Now a descriptive message will be shown instead
- Fixed an issue where location changes of a transit would not correctly update in the transit log
- Improved the visuals for multi-edit dialogues
- Moved the demand specification comment location to make it visually clear what the comment is about
- Updated translations for multi-edit dropdowns
- Added warnings when invalid emails are specified under collaborators
- Added a separate section for Safety and Compliance under transit information
- Added a new button for Safety demands when using multi-edit
- Moved all product related information to the same section in the transit information
1.23.1 - 2024-04-25
- Fixed unresponsive save button when editing custom data fields
- Improved the visual design of the status dialogue
- Updated the access log to include product types when granting access to assets
- Updated text colors for plots on floor plans to make them uniform with the rest of the application
- Fixed an issue where searching for users returned duplicate results
- Fixed an issue where components would load earlier then intended
- Pressing enter while typing in the customer administrator email field should no longer reload the page
1.23.0 - 2024-04-18
- Replaced the change status dialogue
- Moved Custom data fields to its own tab
- When a transit gets deleted, it will close open windows related to it
- Changed the color of text in status bubbles. These should now match through the application
- Removed sorting by last modified transit status date, as this option was confusing
- Fixed an issue where the edit asset dialogue would not update correctly
- Added a transit insulation status dialogue
- Added padding to tags
- Disabled geolocation selection when creating an item from the geolocations menu
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
- Updated the pricing model for both Transit Build & Operate. Both applications now share the same pricing model.
- Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
