Transit Build - New version 1.25.33 [2025-04-17]
1.25.33 - 2025-04-17
  • Fixed an issue where updating collaborator access would generate an 403 error
  • Fixed an issue where maintenance statistics where shown for all users. Its now only visible for users with maintenance access
1.25.31 - 2025-04-11
  • Added the option to delete tags in the tag manager
1.25.30 - 2025-04-08
  • Improved visuals for the dialogue drawer
  • Fixed an issue with the image gallery not correctly resolving the image source
  • Added text to the “Not found” page
  • Improved the error message when trying to access items you lack access to
1.25.28 - 2025-04-07
  • Fixed an issue where incorrect values could be used in the multi import without generating an error message
  • Fixed an issue where transit locations became incorrect when performing a floor plan swap
1.25.27 - 2025-04-02
  • Added a caption to editing dialogues
  • Geolocation actions are no longer visible if the user has no access to them
  • Fixed an issue where long names / emails would cause the user avatar to shrink
  • Added the option to assign multiple tags
1.25.25 - 2025-03-14
  • Significantly improved the performance of large database operations
1.25.23 - 2025-03-03
  • Added a button to copy the Transit Designer URL
  • Added components for a tag manager
1.25.21 - 2025-02-21
  • Improved shadow visuals
  • Added a button to open transits that have been pushed from Transit Designer
  • Disabled changing names on transits pushed from Transit Designer
  • Removed whitespace in places where an icon was missing
  • Added an access role to allow editing tags
  • Removed null values from being displayed
  • Fixed an issue where mouse wheel scrolling did not work
  • Removed error messages that were not indicating actual errors
  • Added the option to associate multiple items with a geolocation in one action
  • Removed labels from multiselect
  • Changed the Transit Designer URL to display as “Link”
  • VAT number is no longer required to start a subscription
1.25.20 - 2025-02-04
  • When clicking the Transit Designer URL from pushed transits, this will now open in a new tab
  • Changed the multi import to no longer allow negative numbers as these are not supported
  • Fixed an issue where error messages would not be presented to the user
  • Added the X, Y, Z fields to transit information
1.25.18 - 2025-01-28
  • Fixed an issue where the save button was disabled when editing transits pushed from Transit Designer
  • Forced the x,y, z fields to only contain whole numbers in the multi import. As decimal numbers are not supported by the application
1.25.17 - 2025-01-21
  • Updated the transit drawer to close when selecting an option from the multi edit dropdown to force a reload.
1.25.16 - 2025-01-14
  • Improved the warning regarding sensitive uploads to be better displayed across different resolutions
  • Fixed an issue where it was not possible to close the transit drawer after clicking on another transit
  • Improved the appearance of the set status dialogue
  • Fixed the last modified date on differing product types. The date should now correctly reflect the last modifying activity
1.25.14 - 2024-12-20
  • Fixed an issue where it was not possible to open a new page by clicking the Roxtec logo
  • Fixed an issue where applied filters would not persists in certain scenarios
  • Removed the “apply filter” buttons from dropdown menus in favor of the global filter
1.25.13 - 2024-12-09
  • Fixed the descriptive text for collaborators when removing a product type
  • Improved the close button when downloading reports. It should now better indicate when it can be pressed
1.25.12 - 2024-11-29
  • Reduced the opacity when dragging items on the floor plan. This will make the underlying map visible and allow for more accurate placement
  • Fixed an issue where some PDF documents could not be uploaded
1.25.11 - 2024-11-22
  • Fixed an issue where it was not possible to create a customer account without having a company name set. The user name will be used if this is missing
  • Removed the “add multiple transits” button when editing a transit.
1.25.9 - 2024-11-19
1.25.8 - 2024-11-18
1.25.7 - 2024-11-12
1.25.6 - 2024-11-11
1.25.5 - 2024-11-04
1.25.4 - 2024-10-24
1.25.3 - 2024-10-15
1.25.2 - 2024-09-17
1.25.1 - 2024-09-10
1.25.0 - 2024-08-20
1.24.9 - 2024-07-04
1.24.8 - 2024-07-02
1.24.6 - 2024-06-11
1.24.5 - 2024-06-11
1.24.4 - 2024-06-10
1.24.3 - 2024-05-28
1.24.2 - 2024-05-17
1.24.1 - 2024-05-15
1.24.0 - 2024-05-08
1.23.1 - 2024-04-25
1.23.0 - 2024-04-18
  • Added padding to tags
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
  • Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
