1.25.39 - 2025-05-23
- Added search functionality for tags
- Added the ability to close drawers using the escape key
- Added a message to clarify that a user has no access when managing the user profile
- Hid the second address field when its empty
- Changed position of the timestamp in the log to add more room for the log message
- Its now possible to highlight reference locations
- Included the transit seral tag in the message when deleting a transit
1.25.37 - 2025-05-06
- Fixed dropdown animations
1.25.36 - 2025-05-02
- Aligned the appearance of cancel buttons
- Fixed the page for “Email not verified”
1.25.35 - 2025-04-30
- Added a new forbidden message when trying to access items that do you do not have access to
- Added a home button to the “Not found” page
- Fixed an issue with filtering collaborators on an asset
1.25.34 - 2025-04-25
- Added customer name in the header when editing account
- Fixed the alignment of asset toolbar buttons
- Centered the checkboxes in the collaborator access view
- Created component for cable management
- Removed bold status on certain elements when setting status
- Fixed the width of dropdown items
- Fixed an issue where orientation on items changed when swapping floor plans
1.25.33 - 2025-04-17
- Fixed an issue where updating collaborator access would generate an 403 error
- Fixed an issue where maintenance statistics where shown for all users. Its now only visible for users with maintenance access
1.25.31 - 2025-04-11
- Added the option to delete tags in the tag manager
1.25.30 - 2025-04-08
- Improved visuals for the dialogue drawer
- Fixed an issue with the image gallery not correctly resolving the image source
- Added text to the “Not found” page
- Improved the error message when trying to access items you lack access to
1.25.28 - 2025-04-07
- Fixed an issue where incorrect values could be used in the multi import without generating an error message
- Fixed an issue where transit locations became incorrect when performing a floor plan swap
1.25.27 - 2025-04-02
- Added a caption to editing dialogues
- Geolocation actions are no longer visible if the user has no access to them
- Fixed an issue where long names / emails would cause the user avatar to shrink
- Added the option to assign multiple tags
1.25.25 - 2025-03-14
- Significantly improved the performance of large database operations
1.25.23 - 2025-03-03
- Added a button to copy the Transit Designer URL
- Added components for a tag manager
1.25.21 - 2025-02-21
- Improved shadow visuals
- Added a button to open transits that have been pushed from Transit Designer
- Disabled changing names on transits pushed from Transit Designer
- Removed whitespace in places where an icon was missing
- Added an access role to allow editing tags
- Removed null values from being displayed
- Fixed an issue where mouse wheel scrolling did not work
- Removed error messages that were not indicating actual errors
- Added the option to associate multiple items with a geolocation in one action
- Removed labels from multiselect
- Changed the Transit Designer URL to display as “Link”
- VAT number is no longer required to start a subscription
1.25.20 - 2025-02-04
- When clicking the Transit Designer URL from pushed transits, this will now open in a new tab
- Changed the multi import to no longer allow negative numbers as these are not supported
- Fixed an issue where error messages would not be presented to the user
- Added the X, Y, Z fields to transit information
1.25.18 - 2025-01-28
- Fixed an issue where the save button was disabled when editing transits pushed from Transit Designer
- Forced the x,y, z fields to only contain whole numbers in the multi import. As decimal numbers are not supported by the application
1.25.17 - 2025-01-21
- Updated the transit drawer to close when selecting an option from the multi edit dropdown to force a reload.
1.25.16 - 2025-01-14
- Improved the warning regarding sensitive uploads to be better displayed across different resolutions
- Fixed an issue where it was not possible to close the transit drawer after clicking on another transit
- Improved the appearance of the set status dialogue
- Fixed the last modified date on differing product types. The date should now correctly reflect the last modifying activity
1.25.14 - 2024-12-20
- Fixed an issue where it was not possible to open a new page by clicking the Roxtec logo
- Fixed an issue where applied filters would not persists in certain scenarios
- Removed the “apply filter” buttons from dropdown menus in favor of the global filter
1.25.13 - 2024-12-09
- Fixed the descriptive text for collaborators when removing a product type
- Improved the close button when downloading reports. It should now better indicate when it can be pressed
1.25.12 - 2024-11-29
- Reduced the opacity when dragging items on the floor plan. This will make the underlying map visible and allow for more accurate placement
- Fixed an issue where some PDF documents could not be uploaded
- Fixed an issue where logging out from the application would not correctly log you out
1.25.11 - 2024-11-22
- Fixed an issue where it was not possible to create a customer account without having a company name set. The user name will be used if this is missing
- Removed the “add multiple transits” button when editing a transit.
1.25.9 - 2024-11-19
- Fixed the measurements to automatically set to inches for US users
1.25.8 - 2024-11-18
- Fixed an issue where the loading indicator would not display properly when working with floor plans
- Created a filter that removes “mailto:” prefixes when trying to add collaborators.
- Updated the log message when removing a custom data field value to better reflect that the value was removed
1.25.7 - 2024-11-12
- When uploading a floor plan image, applying a rotation would not render correctly in the browser window.
- Fixed an issue that caused geolocations to not be visible
1.25.6 - 2024-11-11
- Fixed an issue where it was not possible to scroll when a dialogue was open
- Improved tooltips for items when moving them on a floorplan
- Improved the performance of the global filter on assets with thousands of items using custom data fields. This would cause the UI to momentarily be unresponsive.
- Fixed an issue where users with the Inspection viewer role could not access inspection reports or asset documents
- Fixed an issue where the rotation of reference locations would not match the primary location
1.25.5 - 2024-11-04
- Disabled the add button in add transit when product group / solution contains incomplete information
- Fixed an issue where the preview of PDF files would not display correctly
- Improved the appearance of the global filter and transit drawer
- Updated the text in the global filter from “Press enter to remove” to “Press enter to deselect” to properly reflect that nothing is removed
1.25.4 - 2024-10-24
- Fixed an issue where an iframe was shown unintentionally
- Updated the add floor plan dialogue to match company branding
- Fixed an issue where the icons for collapse and expand were inverted
- Fixed an issue where “mixed” could not be used as a value in custom data fields
1.25.3 - 2024-10-15
- Fixed an issue where a floor plan information window could not be closed
- Enabled editing multiple custom data fields in one operation. Available through the dropdown menu when multiple items are selected
- Updated the breadcrumbs navigation
- Introduced a new top navigation bar
- Removed title from user settings
1.25.2 - 2024-09-17
- Added autofocus to the first available text field when opening applicable dialogues
- Fixed an issue where geolocations would not display
- Fixed a camera movement bug that would occur when using certain camera actions in a specific order
- Fixed a broken translation related to collaborators
1.25.1 - 2024-09-10
- Changed the “Edit and Add customer” dialogue to the new UI standard
- Updated the “Current user” dialogues appearance and improved it for mobile devices
- Changed the “Add and Edit location” dialogue to the new UI standard
- Updated the reports to correctly reflect which product type that is selected
- Moved the cancel button under account options to be in line with the UI standard
- Improved the UI of the add / edit asset dialogue
- Improved the transit dialogue for mobile devices
- Improved the dashboard to no longer truncate asset names on mobile devices
- Updated the help messages for item placement
- Fixed an issue where tags would appear outside of their designated area
- Improved the accuracy of the customer search function
- Added a message in the reports when there is no status set
- Improved the reference location function, it should now be possible to remove a reference location independent of the primary location
- Fixed an issue where long words would become truncated and could cause the close button to not be visible
- Added a custom data fields button to the manage asset dropdown menu
- Fixed an issue where selecting a reference location would highlight the primary location
- Improved the animations when selecting items on a floor plan
- Added functionality to allow primary and reference locations to exist on the same floor plan
1.25.0 - 2024-08-20
- Added the option to manage collaborators from the asset list
- Made the location comment visible for other product types under the information tab
- Added information about which asset and product type is selected when managing collaborators, since this can now be done from multiple locations
- Changed the cursor to become a pointer when hovering over certain objects, to make it clear their clickable
- Disabled the download inspection reports function for inspections in a planned state
- Updated the warning that filter is active when downloading reports. This now includes a warning that the active selection also impacts this
- Improved the log entries when moving a transit between floor plans
- Fixed an issue where editing a multi-imported transit would generate incorrect log messages
- Added the option to filter on custom data fields that have not been filled in
- Added the option to filter on Product that has not been specified
- Added the option to filter on transits that have no tags set
- Removed quarters from relative timestamps, replaced with months
- Fixed an issue where the text for product types on hydraulic hoses would overlap other text
- Updated the legend in the excel reports to only include the statuses present in the report
- Changed the add inspection, edit inspection and get report dialogues, they will now generate as a drawer
- Fixed an issue where the latest modifying activity would not update correctly for all assets in an asset group
1.24.9 - 2024-07-04
- Added a notification when trying to download a report with a filter active. That this is active for the report
- Updated Asset admin notification emails to only be sent when a new administrator is added
- The select all button will no longer display in the collaborators list if its empty
- Added a filter option to display transits that have not yet been placed on a floor plan
- Fixed an issue with the manage collaborators list where information would disappear while scrolling
- Fixed an issue where certain PDF files were not recognized correctly when uploading them
1.24.8 - 2024-07-02
- When expanding menu options that open outside of the current view, it will now automatically scroll to display the information
- Updated the add document error message that occurs when trying to upload an unsupported file type. The message should now reflect what type of file is being uploaded
- Fixed an issue where an empty transit log entry was generated when setting the same demand specifications
- The select all button will no longer display if there are no items
- When changing a custom data field, the field label now displays while editing.
- The upload documents text is no longer displayed for users that do not have access to upload documents.
1.24.6 - 2024-06-11
- Updated “item” under manage item drop downs to now reflect the selected product type
- Allowed expired products to be selectable on transits that already contain them
- Updated the Download reports window to now reflect which product type is selected
1.24.5 - 2024-06-11
- Any change to an inspection will now count towards its activity
- Updated the navbars so the text is no longer selectable
1.24.4 - 2024-06-10
- Added a warning when decreasing the size of a transit to a smaller size then its original
- Fixed a sensitive information warning that would display incorrectly on lower resolutions
- The transits displayed under geolocations are now split into pages with the options 25, 50 or 100 items per page
- Fixed an issue where the transit drawer would display incorrectly on mobile devices
- Fixed an issue where the reports would contain statuses from all products. It will now only contain statuses for the selected product
- Improved the error message that is displayed when trying to view a deleted transit
- Updated the “Add item” and “Add multiple items” buttons to now reflect the selected product type
- It is no longer possible to change tabs/sides of a BTB transit while there are pending changes. Added a notification to make this clear
- Added a section under add/edit item for custom data fields
- Updated BTB transits so the selected status no longer carries over when switching tabs
- Fixed margins on the product tab
1.24.3 - 2024-05-28
- Added a “Not set” option in the global filter for geolocations
- Improved the transit inspection log, making it much easier to read
- Fixed editing and focusing issues related to geolocations
- Fixed an issue where buttons would become jumbled up when decreasing the size to the geolocation information past a point
1.24.2 - 2024-05-17
- Added Front and Back tabs under Openings and tags for Back to Back solutions
1.24.1 - 2024-05-15
- Added new access profile for Surface treatment
- Fixed an issue that would generate empty insulation log entries
- Fixed Floor plan notifications not displaying correctly
1.24.0 - 2024-05-08
- Updated the access log to only display product type if there is a non default value
- Fixed an issue where the delete transit dialogue would reappear after successfully deleting a transit
- Fixed an issue where the latest changed date would display incorrectly
- Changed an error message that appeared when using a direct link to a transit that changed floor plans after the link was generated. Now a descriptive message will be shown instead
- Fixed an issue where location changes of a transit would not correctly update in the transit log
- Improved the visuals for multi-edit dialogues
- Moved the demand specification comment location to make it visually clear what the comment is about
- Updated translations for multi-edit dropdowns
- Added warnings when invalid emails are specified under collaborators
- Added a separate section for Safety and Compliance under transit information
- Added a new button for Safety demands when using multi-edit
- Moved all product related information to the same section in the transit information
1.23.1 - 2024-04-25
- Fixed unresponsive save button when editing custom data fields
- Improved the visual design of the status dialogue
- Updated the access log to include product types when granting access to assets
- Updated text colors for plots on floor plans to make them uniform with the rest of the application
- Fixed an issue where searching for users returned duplicate results
- Fixed an issue where components would load earlier then intended
- Pressing enter while typing in the customer administrator email field should no longer reload the page
1.23.0 - 2024-04-18
- Replaced the change status dialogue
- Moved Custom data fields to its own tab
- When a transit gets deleted, it will close open windows related to it
- Changed the color of text in status bubbles. These should now match through the application
- Removed sorting by last modified transit status date, as this option was confusing
- Fixed an issue where the edit asset dialogue would not update correctly
- Added a transit insulation status dialogue
- Added padding to tags
- Disabled geolocation selection when creating an item from the geolocations menu
1.22.3 - 2024-03-26
1.22.2 - 2024-03-26
1.22.1 - 2024-03-20
1.22.0 - 2024-03-15
1.21.0 - 2024-02-29
1.20.1 - 2024-02-27
1.20.0 - 2024-02-27
1.19.1 - 2024-01-30
1.19.0 - 2024-01-30
- Updated the pricing model for both Transit Build & Operate. Both applications now share the same pricing model.
- Changed certain icons
1.18.2 - 2024-01-10
1.18.1 - 2024-01-10
1.18.0 - 2024-01-05
1.17.5 - 2023-11-30
1.17.4 - 2023-11-24
1.17.3 - 2023-11-16
1.17.1 - 2023-10-30
1.17 - 2023-10-30
1.16 - 2023-10-17
1.15.1 - 2023-09-14
1.15 - 2023-09-12
