4.33.1 - 2024-02-05
4.33.0 - 2024-01-30
Added a warning when trying to close / reload the page while there is unsaved data
Improved the “Create project from backup” dialogue
Added a popup window while the multi import is running to prevent user interaction that could cause issues.
Fixed frame sizes in the packing editor so they now align correctly
Improved auto packing of GK frames.
4.32.5 - 2024-01-22
Fixed an issue where a solution with a cover would create an error message when replaced with a corner solution
Removed transition animations when removing a row of cables
Fixed an issue that occurred when a large file was used for the multi import.
4.32.4 - 2024-01-19
Fixed an issue where GK solutions would incorrectly display the “Transit incomplete” status
The WOC (WithOut Core) descriptor was missing on certain CRF modules under module preferences
Improved the placement of module IDs on blueprints
Added a project setting that allows for scaling of the cable list in blueprints
Corrected the size of a table image in the help dialog
4.32.2 - 2023-12-22
Set the preference for CRF multidiameter solutions to prefer spare modules instead of solid spares.
When dragging a module between solutions, the module will be automatically changed if it does not fit in the solution it is dragged to.
Fixed an issue that occurred when adding corner modules on a SPK-S50 solution
Updated documentation for the standalone version
Fixed an issue where corner modules would display incorrectly in the packing editor.
4.32.1 - 2023-12-13
4.32.0 - 2023-12-11
Fixed that stayplates did not correctly place for modules with more then 4 corners
Improved the visual layout for the packaging editor. Stayplates no longer look like they might be overlapping.
4.31.0 - 2023-12-01
Fixed an issue where transits with multiple solutions would generate incorrect drawings
Added an option to select custom names for each side of a back to back frame
4.28.7 - 2023-10-20
Removed 0/0 as a recommended casting apeture on the Design and Summary steps
Available sleeve depth should now update when a new variant is selected in the Design step
Changed the display name of items in the Variants list in the Design step. The names should now describe the measurements more accurately.
Added a scrollbar to the Accessories dialog instead of using a full page scroll.
Fixed a bug where GK transits incorrectly showed as incomplete
Fixed a misaligned toolbar
