4.36.4 - 2024-03-24
- Fixed an issue where popover windows would display over the target element
- Fixed an issue where the variant list would not display any options
- When changing the module safety margin, designer will now try and keep cables in multi modules together
4.36.3 - 2024-03-09
Fixed a bug where menu options in the packaging step would display incorrectly when undo/redo was used
Added a new option to Edit opening. There are now separate buttons to fill the opening with either spares or solids
4.36.2 - 2024-03-06
4.36.1 - 2024-03-05
4.36.0 - 2024-02-29
4.35.0 - 2024-02-26
4.34.0 - 2024-02-18
4.33.1 - 2024-02-05
4.33.0 - 2024-01-30
4.32.5 - 2024-01-22
4.32.4 - 2024-01-19
4.32.2 - 2023-12-22
4.32.1 - 2023-12-13
4.32.0 - 2023-12-11
4.31.0 - 2023-12-01
4.28.7 - 2023-10-20
- Fixed a misaligned toolbar
