Transit Designer - New version 4.37.20 [2024-12-08]
4.37.20 - 2024-12-08
  • Fixed the search function in the project list. It should now be case insensitive
  • Fixed the scroll function in the project list
4.37.19 - 2024-12-05
  • Updated the dashboard to be able to facilitate company accounts
  • Included the sleeve in transit weight calculations
  • Fixed the position of the limited label when getting documents
4.37.18 - 2024-11-19
  • Added a 3D CAD libraries link when selecting a solution
  • Removed the clickable help link for countries where no support contact is available
  • Fixed an issue where the measurement units did not update correctly depending on the users country on signup
  • It is no longer possible to specify 0 mm width or height for existing holes
4.37.17 - 2024-11-13
  • Fixed an issue where certain user avatar images would not render correctly
4.37.16 - 2024-11-12
  • Improved animations when loading the design page
  • Fixed an error that occurred when changing sleeve material
  • Made Address, Zip and City optional for sign ups
  • Removed the Buy button if the user belongs to a market where e-commerce is not available
  • Fixed an issue where cached information would prevent a transit from being saved
4.37.15 - 2024-11-05
  • Improved the auto packing logic, corner modules and wedges will now move automatically when underlying configuration is changed
  • Moved the Roxtec logo due to the placement of the new chat function
4.37.14 - 2024-11-05
  • Added animations for certain expand toggles
  • Fixed the visibility of an iframe that was not supposed to be shown
  • Added custom solution names to blueprints to prevent confusion
  • When changing to a cabinet solution, an area will not be added automatically
  • Fixed an issue where it was not possible to change the case of letters in transit names
  • Fixed an issue that would occur when trying to place modules in certain solutions
  • Aligned the appearance of the top navigation bar with Transit Build and Operate
  • Removed “title” from user settings
4.37.12 - 2024-10-07
  • Fixed various snapping and module placement issues for GK frames
4.37.11 - 2024-09-27
  • Fixed an error that occurred when placing a larger module on top of a smaller one in GK frames
4.37.10 - 2024-09-26
  • Added a part depth selector
  • Removed irrelevant warning messages for GK frames
  • Removed irrelevant details and options for ghost solutions
  • Corrected certain text to now start with a capital letter
  • Fixed an issue where the frame size would change when changing part depth
  • Updated the popup help message
  • Fixed an issue where GK frames would warn about adjacent modules without a stayplate
4.37.9 - 2024-09-10
  • Fixed an issue where “Add to cart” content would not properly generate in Chrome / Edge
4.37.8 - 2024-09-05
  • Fixed an issue where spare modules and wedge would not convert to EMC when this option was selected
  • Removed irrelevant solution characteristics for ghost solutions
4.37.7 - 2024-08-27
  • Adjusted the styling of the Add solution dialogue to remove whitespace.
  • Fixed missing buttons on the installation instructions tab
  • Improved the autopack algorithm to handle certain scenarios where it would pack incorrectly
  • Fixed an issue with grid snapping that would occur after using undo/redo
  • Fixed an issue where the stayplate was missing on GK solutions
  • Added an error message when modules are placed without stayplate support for GK solutions
  • Fixed an incorrect warning regarding stayplate support
  • Fixed an issue that would occur when trying to drag a row of 60-spares into a GK solution
  • Improved the packing algorithm for GK solutions to handle scenarios where multiple top-up modules are needed
  • Added horizontal scrolling for the modules list on the packing page when the names do not fit
  • Improved the error message that appears when trying to push a transit to a deleted Transit Build / Operate asset
  • Improved the performance of the Used in project tab
4.37.5 - 2024-08-13
  • Updated the module rules for EX modules
  • Fixed an issue where the number of openings option was not opened by default on the design page
  • Fixed an issue where too large corner modules were used in GK solutions
  • Fixed an issue with wedge overlap in GK solutions and added an error message when the wedge does not have stayplate support. The message now describes what measures need to be taken
4.37.4 - 2024-07-09
  • Fixed an issue that prevented users from resizing SRC frames
4.37.3 - 2024-07-05
  • Fixed an issue with images when configuring frames
4.37.2 - 2024-07-05
  • Fixed an issue where an error was generated if a user navigated a sleeve solution quickly
  • Fixed an issue where the materials section would close when selecting a different stayplate or wedge material
  • Fixed an issue with discontinued stayplates / wedges for GK solutions
  • Improved the multi-import to always find a suitable stayplate for the wedge chosen
4.37.0 - 2024-07-01
  • Fixed an issue where certain small and GK frames would leave a gap under the wedge on drawings
  • Fixed an issue where empty fields on a drawing would result in overlapping text
  • Fixed an issue where the component managing custom side names on back to back frames would not update correctly when using multiple solutions
  • Added warnings for GK modules when they are designed in such a way that it negatively impact the transits performance
  • Improved snapping of modules when placing them in a transit
  • Ghost solutions can now only be used with a single/same solution type
  • Fixed stayplate placement in GK solutions
4.36.8 - 2024-05-17
  • Improved the visuals for GK openings
4.36.5 - 2024-04-23
  • Fixed an issue with H3 seals when using the existing-hole function
  • Fixed a sync problem that could lead to duplicate IDs
  • Fixed a bug where mounting Casting was not transfered to the solution configuration page
  • Fixed an issue where R UG frames would incorrectly display under Existing hole
4.36.4 - 2024-03-24
  • Fixed an issue where popover windows would display over the target element
  • Fixed an issue where the variant list would not display any options
  • When changing the module safety margin, designer will now try and keep cables in multi modules together
4.36.3 - 2024-03-09
  • Fixed a bug where menu options in the packaging step would display incorrectly when undo/redo was used
  • Added a new option to Edit opening. There are now separate buttons to fill the opening with either spares or solids
4.36.2 - 2024-03-06
  • Improved the edit opening toolbar
4.36.1 - 2024-03-05
  • Enabled the “Match existing hole” feature for Roxtec users
4.36.0 - 2024-02-29
  • Fixed H6 frames not rendering correctly
  • Added a download drawing option to transits that no longer have certificates associated with them
4.35.0 - 2024-02-26
  • Added a limited tag to certain features to better indicate that these are not available for all users
  • Selected solution name is now shown during the design step
4.34.0 - 2024-02-18
  • Fixed an issue that occurred when swapping between a firestop and grid solution
  • Fixed an issue where the stayplate would place incorrectly in GK modules
  • Improved snapping when placing modules in GK openings
4.33.1 - 2024-02-05
  • Fixed Chinese text not generating correctly on info drawings
4.33.0 - 2024-01-30
  • Added a warning when trying to close / reload the page while there is unsaved data
  • Improved the “Create project from backup” dialogue
  • Added a popup window while the multi import is running to prevent user interaction that could cause issues.
  • Fixed frame sizes in the packing editor so they now align correctly
  • Improved auto packing of GK frames.
4.32.5 - 2024-01-22
  • Fixed an issue where a solution with a cover would create an error message when replaced with a corner solution
  • Removed transition animations when removing a row of cables
  • Fixed an issue that occurred when a large file was used for the multi import.
4.32.4 - 2024-01-19
  • Fixed an issue where GK solutions would incorrectly display the “Transit incomplete” status
  • The WOC (WithOut Core) descriptor was missing on certain CRF modules under module preferences
  • Improved the placement of module IDs on blueprints
  • Added a project setting that allows for scaling of the cable list in blueprints
  • Corrected the size of a table image in the help dialog
4.32.2 - 2023-12-22
  • Set the preference for CRF multidiameter solutions to prefer spare modules instead of solid spares.
  • When dragging a module between solutions, the module will be automatically changed if it does not fit in the solution it is dragged to.
  • Fixed an issue that occurred when adding corner modules on a SPK-S50 solution
  • Updated documentation for the standalone version
  • Fixed an issue where corner modules would display incorrectly in the packing editor.
4.32.1 - 2023-12-13
  • Fixed broken forum feeds on the dashboard
4.32.0 - 2023-12-11
  • Fixed that stayplates did not correctly place for modules with more then 4 corners
  • Improved the visual layout for the packaging editor. Stayplates no longer look like they might be overlapping.
4.31.0 - 2023-12-01
  • Fixed an issue where transits with multiple solutions would generate incorrect drawings
  • Added an option to select custom names for each side of a back to back frame
4.28.7 - 2023-10-20
  • Removed 0/0 as a recommended casting apeture on the Design and Summary steps
  • Available sleeve depth should now update when a new variant is selected in the Design step
  • Changed the display name of items in the Variants list in the Design step. The names should now describe the measurements more accurately.
  • Added a scrollbar to the Accessories dialog instead of using a full page scroll.
  • Fixed a bug where GK transits incorrectly showed as incomplete
  • Fixed a misaligned toolbar
