4.37.25 - 2025-02-13
- Fixed an issue where dropdown menus would not display correctly on lower resolutions
4.37.23 - 2025-02-10
- Added support for rectangular logos for company accounts
- Fixed an issue where the save button would not always light up after selecting an Build or Operate asset to connect to in project settings
4.37.22 - 2025-01-28
- Fixed an issue where the solutions text would overlap the drawing head in cases where custom names or many solutions where included in the transit
4.37.21 - 2025-01-21
- Enabled the audit log by default
- Removed the option to turn off audit logging for company accounts
- Improved the appearance of the smaller selection boxes on the design page
- Fixed an issue where the generation of DXF/PDF files would show a completed progress bar before the documents were ready
- Fixed an issue where the generated ZIP file would not contain all documents
- Improved the “Select all” button on the packing page, it should now be checked only when all modules are selected.
- Added a new transit settings tab under project settings.
- Added the option to change the default space capacity to transit settings.
- Fixed an issue where the “Create new project” button did not work in the notification window that shows when you have no projects
4.37.20 - 2024-12-08
- Fixed the search function in the project list. It should now be case insensitive
- Fixed the scroll function in the project list
4.37.19 - 2024-12-05
- Updated the dashboard to be able to facilitate company accounts
- Included the sleeve in transit weight calculations
- Fixed an issue where logging out from the application would not correctly log you out
- Fixed the position of the limited label when getting documents
4.37.18 - 2024-11-19
- Added a 3D CAD libraries link when selecting a solution
- Removed the clickable help link for countries where no support contact is available
- Fixed an issue where the measurement units did not update correctly depending on the users country on signup
- It is no longer possible to specify 0 mm width or height for existing holes
4.37.17 - 2024-11-13
- Fixed an issue where certain user avatar images would not render correctly
4.37.16 - 2024-11-12
- Improved animations when loading the design page
- Fixed an error that occurred when changing sleeve material
- Made Address, Zip and City optional for sign ups
- Removed the Buy button if the user belongs to a market where e-commerce is not available
- Fixed an issue where cached information would prevent a transit from being saved
4.37.15 - 2024-11-05
- Improved the auto packing logic, corner modules and wedges will now move automatically when underlying configuration is changed
- Moved the Roxtec logo due to the placement of the new chat function
4.37.14 - 2024-11-05
- Added animations for certain expand toggles
- Fixed the visibility of an iframe that was not supposed to be shown
- Added custom solution names to blueprints to prevent confusion
- When changing to a cabinet solution, an area will not be added automatically
- Fixed an issue where it was not possible to change the case of letters in transit names
- Fixed an issue that would occur when trying to place modules in certain solutions
- Aligned the appearance of the top navigation bar with Transit Build and Operate
- Removed “title” from user settings
4.37.12 - 2024-10-07
- Fixed various snapping and module placement issues for GK frames
4.37.11 - 2024-09-27
- Fixed an error that occurred when placing a larger module on top of a smaller one in GK frames
4.37.10 - 2024-09-26
- Added a part depth selector
- Removed irrelevant warning messages for GK frames
- Removed irrelevant details and options for ghost solutions
- Corrected certain text to now start with a capital letter
- Fixed an issue where the frame size would change when changing part depth
- Updated the popup help message
- Fixed an issue where GK frames would warn about adjacent modules without a stayplate
4.37.9 - 2024-09-10
- Fixed an issue where “Add to cart” content would not properly generate in Chrome / Edge
4.37.8 - 2024-09-05
- Fixed an issue where spare modules and wedge would not convert to EMC when this option was selected
- Removed irrelevant solution characteristics for ghost solutions
4.37.7 - 2024-08-27
- Adjusted the styling of the Add solution dialogue to remove whitespace.
- Fixed missing buttons on the installation instructions tab
- Improved the autopack algorithm to handle certain scenarios where it would pack incorrectly
- Fixed an issue with grid snapping that would occur after using undo/redo
- Fixed an issue where the stayplate was missing on GK solutions
- Added an error message when modules are placed without stayplate support for GK solutions
- Fixed an incorrect warning regarding stayplate support
- Fixed an issue that would occur when trying to drag a row of 60-spares into a GK solution
- Improved the packing algorithm for GK solutions to handle scenarios where multiple top-up modules are needed
- Added horizontal scrolling for the modules list on the packing page when the names do not fit
- Improved the error message that appears when trying to push a transit to a deleted Transit Build / Operate asset
- Improved the performance of the Used in project tab
4.37.5 - 2024-08-13
- Updated the module rules for EX modules
- Fixed an issue where the number of openings option was not opened by default on the design page
- Fixed an issue where too large corner modules were used in GK solutions
- Fixed an issue with wedge overlap in GK solutions and added an error message when the wedge does not have stayplate support. The message now describes what measures need to be taken
4.37.4 - 2024-07-09
- Fixed an issue that prevented users from resizing SRC frames
4.37.3 - 2024-07-05
- Fixed an issue with images when configuring frames
4.37.2 - 2024-07-05
- Fixed an issue where an error was generated if a user navigated a sleeve solution quickly
- Fixed an issue where the materials section would close when selecting a different stayplate or wedge material
- Fixed an issue with discontinued stayplates / wedges for GK solutions
- Improved the multi-import to always find a suitable stayplate for the wedge chosen
4.37.0 - 2024-07-01
- Fixed an issue where certain small and GK frames would leave a gap under the wedge on drawings
- Fixed an issue where empty fields on a drawing would result in overlapping text
- Fixed an issue where the component managing custom side names on back to back frames would not update correctly when using multiple solutions
- Added warnings for GK modules when they are designed in such a way that it negatively impact the transits performance
- Improved snapping of modules when placing them in a transit
- Ghost solutions can now only be used with a single/same solution type
- Fixed stayplate placement in GK solutions
4.36.8 - 2024-05-17
- Improved the visuals for GK openings
4.36.5 - 2024-04-23
- Fixed an issue with H3 seals when using the existing-hole function
- Fixed a sync problem that could lead to duplicate IDs
- Fixed a bug where mounting Casting was not transfered to the solution configuration page
- Fixed an issue where R UG frames would incorrectly display under Existing hole
4.36.4 - 2024-03-24
- Fixed an issue where popover windows would display over the target element
- Fixed an issue where the variant list would not display any options
- When changing the module safety margin, designer will now try and keep cables in multi modules together
4.36.3 - 2024-03-09
Fixed a bug where menu options in the packaging step would display incorrectly when undo/redo was used
Added a new option to Edit opening. There are now separate buttons to fill the opening with either spares or solids
4.36.2 - 2024-03-06
4.36.1 - 2024-03-05
4.36.0 - 2024-02-29
4.35.0 - 2024-02-26
4.34.0 - 2024-02-18
4.33.1 - 2024-02-05
4.33.0 - 2024-01-30
4.32.5 - 2024-01-22
4.32.4 - 2024-01-19
4.32.2 - 2023-12-22
4.32.1 - 2023-12-13
4.32.0 - 2023-12-11
4.31.0 - 2023-12-01
4.28.7 - 2023-10-20
- Fixed a misaligned toolbar
