1.36.1 - 2024-01-30
1.36.0 - 2024-01-30
Updated the pricing model for both Transit Build & Operate. They now share the same pricing model.
Changed certain icons
Changed the spacing on certain buttons
Moved notifications that were partially blocked by the LiveChat icon
Removed the perspective dropdown menu for non transit products
Changed the behavior of select / deselect all buttons. The behavior should now be consistent for all buttons.
1.35.2 - 2024-01-10
1.35.1 - 2024-01-10
Fixed an issue where users would get email notifications regarding access changes but no changes had occurred
Changed “Remove Asset” to “Remove Product Type” to better reflect new functionality
Removed the Sandbox asset tour as it was not used
Added the option to filter on water / gas tightness in the global demand specification filter
1.35.0 - 2024-01-05
Updated the color scheme of drop down menus
Fixed an issue where clicking Edit location would generate an error message
Removed “Openings” from non transit products
When selecting a floor plan the application will automatically set the filter to that floor plan
Fixed an issue where EMC and EX labels would not display correctly when editing multiple demand specifications
Removed the geolocation field from Add transit on Marine & Offshore assets
Non-transit products will now have their properties shown in the item list
Changed the “Transit Openings” tab to “Openings and tags” for transits and “Tags” for other products
Updated the delete asset component to support other product types
1.34.5 - 2024-01-05
1.34.4 - 2024-01-05
1.34.3 - 2024-01-05
Fixed an issue where the global filter would not update correctly when using the free text search
Added a “Get Reports” button to the dropdown menu when transits have been selected in the list
1.34.1 - 2023-10-30
When hoovering over an item that can be dragged onto a floor plan, the cursor will change to reflect this
Removed the function to add multiple transits using a mobile device
1.34 - 2023-10-30
Fixed that the “Remove collaborator” button was visible even if the user lacked access to it
Fixed alignment of text in the asset overview
Fixed a bug that occurred when deleting assets with no collaborators.
Improved several UI elements for mobile devices
Fixed a bug where the “back” button was missing
Added a function to change the size of the Transits icons displayed on the floor plan
Fixed the sorting of solution product groups
Modified the global filter to allow filtering based on each individual transit opening
Fixed a bug where certain actions would not generate a transit log post
Fixed a bug where the asset dashboard would not properly load the latest transit status
Changed the filter option “per opening” from a checkbox to a toggle
Various bug fixes and backend improvements
1.33 - 2023-10-17
Added a save button when editing custom data fields while removing the autosave.
Enabled auto-focus when editing custom data field
It is now possible to place transits on floor plans in the web interface
Added a select all function when working with the people list
Long floor plan names are now truncated under the transits page. The full name is displayed as a tooltip when hovering.
Updated the transit log to only show demand specifications when they change
Adjusted the button padding for a confirmation dialog
Fixed the Trail / Training asset alignment in the assets list
Removed duplicate images from the transit log. Only unique images will be shown.
Added a “Select all button” in the transits list.
Added a tab for the “Place Transits” function that shows transits on other floor plans.
Added a dropdown menu in the transits list that allows editing of multiple transits. Currently available options “Edit Demand Specifications” “Attach Documents” “Tag Items”
Various backend and security improvements
1.32.1 - 2023-09-14
Image serial numbers are now correctly carried over to the next log entry on grouped entries.
Fixed Geolocations bug where the add locations button did not work.
Image serial numbers should now be included in all transit log entries with images.
1.32 - 2023-09-12
Added a progress bar when opening the people tab, as this can take a moment to load if there are many collaborators.
Included the name of whoever closes an inspection in the notification email
Moved the “Reference Location” toggle to the floor plan view
Added tooltips when you hover over an icon in the Floor Plan view
Added an error message where a blank screen was shown previously
The transit log now displays the Floor plans display name instead of the filename.
Fixed table column headers of transit and inspection reports. They should now correctly reflect the content.
Fixed the position of the “Download reports” button on lower resolutions
Fixed transparent table headers that appeared when scrolling through the Asset access list.
Added notification that users will be notified via email when changing asset access.
The application no longer saves if the user edits a transit without making any changes
Added number of openings / collaborators statistics to the asset overview
Changed the display of images filenames in the transit log to a serial number.
