1.38.0 - 2024-02-29
1.37.1 - 2024-02-27
1.37.0 - 2024-02-27
1.36.1 - 2024-01-30
1.36.0 - 2024-01-30
- Updated the pricing model for both Transit Build & Operate. They now share the same pricing model.
- Changed certain icons
1.35.2 - 2024-01-10
1.35.1 - 2024-01-10
1.35.0 - 2024-01-05
1.34.5 - 2024-01-05
1.34.4 - 2024-01-05
1.34.3 - 2024-01-05
1.34.1 - 2023-10-30
1.34 - 2023-10-30
1.33 - 2023-10-17
1.32.1 - 2023-09-14
1.32 - 2023-09-12
