Transit Operate - New version 1.42.20 [2025-02-04]
1.42.20 - 2025-02-04
  • When clicking the Transit Designer URL from pushed transits, this will now open in a new tab
  • Changed the multi import to no longer allow negative numbers as these are not supported
  • Fixed an issue where error messages would not be presented to the user
  • Added the X, Y, Z fields to transit information
1.42.18 - 2025-01-28
  • Fixed an issue where the save button was disabled when editing transits pushed from Transit Designer
  • Forced the x,y, z fields to only contain whole numbers in the multi import. As decimal numbers are not supported by the application
1.42.17 - 2025-01-21
  • Updated the transit drawer to close when selecting an option from the multi edit dropdown to force a reload.
1.42.16 - 2025-01-14
  • Improved the warning regarding sensitive uploads to be better displayed across different resolutions
  • Fixed an issue where it was not possible to close the transit drawer after clicking on another transit
  • Improved the appearance of the set status dialogue
  • Fixed the last modified date on differing product types. The date should now correctly reflect the last modifying activity
1.42.14 - 2024-12-20
  • Fixed an issue where it was not possible to open a new page by clicking the Roxtec logo
  • Fixed an issue where applied filters would not persists in certain scenarios
  • Removed the “apply filter” buttons from dropdown menus in favor of the global filter
1.42.13 - 2024-12-09
  • Fixed the descriptive text for collaborators when removing a product type
  • Improved the close button when downloading reports. It should now better indicate when it can be pressed
1.42.12 - 2024-11-29
  • Reduced the opacity when dragging items on the floor plan. This will make the underlying map visible and allow for more accurate placement
  • Fixed an issue where some PDF documents could not be uploaded
1.42.11 - 2024-11-22
  • Fixed an issue where it was not possible to create a customer account without having a company name set. The user name will be used if this is missing
  • Removed the “add multiple transits” button when editing a transit.
1.42.9 - 2024-11-19
1.42.8 - 2024-11-18
1.42.7 - 2024-11-12
1.42.6 - 2024-11-11
1.42.5 - 2024-11-04
1.42.4 - 2024-10-24
1.42.3 - 2024-10-15
1.42.2 - 2024-09-17
1.42.1 - 2024-09-10
1.42.0 - 2024-08-20
1.41.9 - 2024-07-04
1.41.8 - 2024-07-02
1.41.6 - 2024-06-11
1.41.5 - 2024-06-11
1.41.4 - 2024-06-10
1.41.3 - 2024-05-28
1.41.2 - 2024-05-17
1.41.1 - 2024-05-15
1.41.0 - 2024-05-08
1.40.1 - 2024-04-25
1.40.0 - 2024-04-18
  • Added padding to tags
1.39.3 - 2024-03-26
1.39.2 - 2024-03-26
1.39.1 - 2024-03-20
1.39.0 - 2024-03-15
1.38.0 - 2024-02-29
1.37.1 - 2024-02-27
1.37.0 - 2024-02-27
1.36.1 - 2024-01-30
1.36.0 - 2024-01-30
  • Updated the pricing model for both Transit Build & Operate. They now share the same pricing model.
  • Changed certain icons
1.35.2 - 2024-01-10
1.35.1 - 2024-01-10
1.35.0 - 2024-01-05
1.34.5 - 2024-01-05
1.34.4 - 2024-01-05
1.34.3 - 2024-01-05
1.34.1 - 2023-10-30
1.34 - 2023-10-30
1.33 - 2023-10-17
1.32.1 - 2023-09-14
1.32 - 2023-09-12
