Transit Operate - New version 1.42.39 [2025-05-23]
1.42.39 - 2025-05-23
  • Added search functionality for tags
  • Added the ability to close drawers using the escape key
  • Added a message to clarify that a user has no access when managing the user profile
  • Hid the second address field when its empty
  • Changed position of the timestamp in the log to add more room for the log message
  • Its now possible to highlight reference locations
  • Included the transit seral tag in the message when deleting a transit
1.42.37 - 2025-05-06
  • Fixed dropdown animations
1.42.36 - 2025-05-02
  • Aligned the appearance of cancel buttons
  • Fixed the page for “Email not verified”
1.42.35 - 2025-04-30
  • Added a new forbidden message when trying to access items that do you do not have access to
  • Added a home button to the “Not found” page
  • Fixed an issue with filtering collaborators on an asset
1.42.34 - 2025-04-25
  • Added customer name in the header when editing account
  • Fixed the alignment of asset toolbar buttons
  • Centered the checkboxes in the collaborator access view
  • Created component for cable management
  • Removed bold status on certain elements when setting status
  • Fixed the width of dropdown items
  • Fixed an issue where orientation on items changed when swapping floor plans
1.42.33 - 2025-04-17
  • Fixed an issue where updating collaborator access would generate an 403 error
  • Fixed an issue where maintenance statistics where shown for all users. Its now only visible for users with maintenance access
1.42.31 - 2025-04-11
  • Added the option to delete tags in the tag manager
1.42.30 - 2025-04-08
  • Improved visuals for the dialogue drawer
  • Fixed an issue with the image gallery not correctly resolving the image source
  • Added text to the “Not found” page
  • Improved the error message when trying to access items you lack access to
1.42.28 - 2025-04-07
  • Fixed an issue where incorrect values could be used in the multi import without generating an error message
  • Fixed an issue where transit locations became incorrect when performing a floor plan swap
1.42.27 - 2025-04-02
  • Added a caption to editing dialogues
  • Geolocation actions are no longer visible if the user has no access to them
  • Fixed an issue where long names / emails would cause the user avatar to shrink
  • Added the option to assign multiple tags
1.42.25 - 2025-03-14
  • Significantly improved the performance of large database operations
1.42.23 - 2025-03-03
  • Added a button to copy the Transit Designer URL
  • Added components for a tag manager
1.42.21 - 2025-02-21
  • Improved shadow visuals
  • Added a button to open transits that have been pushed from Transit Designer
  • Disabled changing names on transits pushed from Transit Designer
  • Removed whitespace in places where an icon was missing
  • Added an access role to allow editing tags
  • Removed null values from being displayed
  • Fixed an issue where mouse wheel scrolling did not work
  • Removed error messages that were not indicating actual errors
  • Added the option to associate multiple items with a geolocation in one action
  • Removed labels from multiselect
  • Changed the Transit Designer URL to display as “Link”
  • VAT number is no longer required to start a subscription
1.42.20 - 2025-02-04
  • When clicking the Transit Designer URL from pushed transits, this will now open in a new tab
  • Changed the multi import to no longer allow negative numbers as these are not supported
  • Fixed an issue where error messages would not be presented to the user
  • Added the X, Y, Z fields to transit information
1.42.18 - 2025-01-28
  • Fixed an issue where the save button was disabled when editing transits pushed from Transit Designer
  • Forced the x,y, z fields to only contain whole numbers in the multi import. As decimal numbers are not supported by the application
1.42.17 - 2025-01-21
  • Updated the transit drawer to close when selecting an option from the multi edit dropdown to force a reload.
1.42.16 - 2025-01-14
  • Improved the warning regarding sensitive uploads to be better displayed across different resolutions
  • Fixed an issue where it was not possible to close the transit drawer after clicking on another transit
  • Improved the appearance of the set status dialogue
  • Fixed the last modified date on differing product types. The date should now correctly reflect the last modifying activity
1.42.14 - 2024-12-20
  • Fixed an issue where it was not possible to open a new page by clicking the Roxtec logo
  • Fixed an issue where applied filters would not persists in certain scenarios
  • Removed the “apply filter” buttons from dropdown menus in favor of the global filter
1.42.13 - 2024-12-09
  • Fixed the descriptive text for collaborators when removing a product type
  • Improved the close button when downloading reports. It should now better indicate when it can be pressed
1.42.12 - 2024-11-29
  • Reduced the opacity when dragging items on the floor plan. This will make the underlying map visible and allow for more accurate placement
  • Fixed an issue where some PDF documents could not be uploaded
1.42.11 - 2024-11-22
  • Fixed an issue where it was not possible to create a customer account without having a company name set. The user name will be used if this is missing
  • Removed the “add multiple transits” button when editing a transit.
1.42.9 - 2024-11-19
1.42.8 - 2024-11-18
1.42.7 - 2024-11-12
1.42.6 - 2024-11-11
1.42.5 - 2024-11-04
1.42.4 - 2024-10-24
1.42.3 - 2024-10-15
1.42.2 - 2024-09-17
1.42.1 - 2024-09-10
1.42.0 - 2024-08-20
1.41.9 - 2024-07-04
1.41.8 - 2024-07-02
1.41.6 - 2024-06-11
1.41.5 - 2024-06-11
1.41.4 - 2024-06-10
1.41.3 - 2024-05-28
1.41.2 - 2024-05-17
1.41.1 - 2024-05-15
1.41.0 - 2024-05-08
1.40.1 - 2024-04-25
1.40.0 - 2024-04-18
  • Added padding to tags
1.39.3 - 2024-03-26
1.39.2 - 2024-03-26
1.39.1 - 2024-03-20
1.39.0 - 2024-03-15
1.38.0 - 2024-02-29
1.37.1 - 2024-02-27
1.37.0 - 2024-02-27
1.36.1 - 2024-01-30
1.36.0 - 2024-01-30
  • Updated the pricing model for both Transit Build & Operate. They now share the same pricing model.
  • Changed certain icons
1.35.2 - 2024-01-10
1.35.1 - 2024-01-10
1.35.0 - 2024-01-05
1.34.5 - 2024-01-05
1.34.4 - 2024-01-05
1.34.3 - 2024-01-05
1.34.1 - 2023-10-30
1.34 - 2023-10-30
1.33 - 2023-10-17
1.32.1 - 2023-09-14
1.32 - 2023-09-12
